MJK 24 Posted April 10, 2021 Share Posted April 10, 2021 Incredible! howe 1 Link to comment Share on other sites More sharing options...
dozeydustman Posted April 13, 2021 Share Posted April 13, 2021 What a lovely looking old Hector, I don't think I've ever seen one of these in the flesh. All the best with your project howe 1 Link to comment Share on other sites More sharing options...
howe Posted May 18, 2021 Author Share Posted May 18, 2021 Progress is coming along, a bit... I went to have some new tyres fitted only to find the other ones are shagged and very rusty inside, and a PO drilled them out to fit inner tubes with a fat valve stem so it's a pain getting new ones in. I'm going to be buying new wheels to replace these, any suggestions on suitable 6x5.5 steels? I picked up some replacement rear lights and a battery that I now realize may be too large... Doesn't fit in my battery tray Distributor is also out of the engine for a full refurb + electronic ignition fitment. On the carb front the big solex is coming off and being replaced with the 32/34 Weber DMTL that I had on my Samara - rejetting and setup will be done by Dennis Vessey once I've made an adapter. Lacquer Peel, Yoss, BlankFrank and 17 others 20 Link to comment Share on other sites More sharing options...
somewhatfoolish Posted May 19, 2021 Share Posted May 19, 2021 Depending on how unobtanium the wheels are and the construction, perhaps new rims could be welded on to the hubs? The popularity of 'banding' with dubbers etc means that seems to be a commercially available service now. Link to comment Share on other sites More sharing options...
howe Posted June 29, 2021 Author Share Posted June 29, 2021 Small joy and small progress later the Cabstar is on a new set of tyres and wheels. Not the first choice I would have gone with but the original wheels are totally fucked and it was a pain finding someone to replace the barrels, these came off a blokes Chevy C10. Apparently steels in this pcd and size are more expensive because of freight delays, or something. Distributor is also finished and refurbed, that's been put back on now. I'm taking it to have the brakes overhauled soon, and after that the Weber will be put on! I'm no longer in a mad rush for this at the moment as the worsened covid situation has made it prohibitively expensive to get over to Morocco until later in the year, the plan still is and will remain to drive down for full restoration in Africa. It'll be returned to mechanical tidiness here of course. Fumbler, Isopon, Lacquer Peel and 12 others 15 Link to comment Share on other sites More sharing options...
howe Posted October 6, 2021 Author Share Posted October 6, 2021 Back at it again with this. I've been out the country for a while so it sat about, as of today it's in the process of being set up with a Weber 32/34 and a new EI dizzy by a bloke just outside Carlisle, tuned on a rolling road. Also looking to swap out for discs all round, likely need to get ordering from the US soon for Shiny New Bits. aldo135, Dyslexic Viking, timolloyd and 16 others 19 Link to comment Share on other sites More sharing options...
mitsisigma01 Posted October 6, 2021 Share Posted October 6, 2021 On 6/29/2021 at 12:11 PM, howe said: Apparently steels in this pcd and size.... Can you tell me what the pcd, offset and c/bore is... I might ha... But I'll have to check first 🤞🤞🤞🤞🤞 Link to comment Share on other sites More sharing options...
DavidB Posted October 6, 2021 Share Posted October 6, 2021 Nice, my dad had a green Cabstar for years he used for work. It had those mudflaps with the zig zag cut on the bottom. He used to pick us up from school and we would ride in the pick up. I saw a few of these in Thailand, they’re still in use over there. I remember that dashboard so vividly as well!! Lacquer Peel, Low Horatio gearbox and howe 3 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted October 6, 2021 Share Posted October 6, 2021 Are the wheels 6x5.5" PCD? Very common to Asian 4x4s. The Cabstar is amazing, I can't wait to see what you do with it. Link to comment Share on other sites More sharing options...
howe Posted October 7, 2021 Author Share Posted October 7, 2021 17 hours ago, mitsisigma01 said: Can you tell me what the pcd, offset and c/bore is... I might ha... But I'll have to check first 🤞🤞🤞🤞🤞 17 hours ago, Lacquer Peel said: Are the wheels 6x5.5" PCD? Very common to Asian 4x4s. The Cabstar is amazing, I can't wait to see what you do with it. They are 6x5.5 yeah, I'm very happy with the choice of wheels I've now put on the truck - I'll be keeping hold of the original steels with the intention to refurb them with new barrels further down the line. Very excited for this project coming together 😁 Lacquer Peel 1 Link to comment Share on other sites More sharing options...
MJK 24 Posted October 7, 2021 Share Posted October 7, 2021 How does it know when it needs an oil change? Link to comment Share on other sites More sharing options...
mk2_craig Posted October 7, 2021 Share Posted October 7, 2021 3 hours ago, MJK 24 said: How does it know when it needs an oil change? Gotta be a combined Oil and Charge lamp, no? Low Horatio gearbox 1 Link to comment Share on other sites More sharing options...
MJK 24 Posted October 7, 2021 Share Posted October 7, 2021 8 minutes ago, mk2_craig said: Gotta be a combined Oil and Charge lamp, no? That’s gotta be a strong possibility! I couldn’t fathom how on earth it would know when it’s next oil change was due! mk2_craig 1 Link to comment Share on other sites More sharing options...
artdjones Posted October 7, 2021 Share Posted October 7, 2021 49 minutes ago, MJK 24 said: That’s gotta be a strong possibility! I couldn’t fathom how on earth it would know when it’s next oil change was due! It probably doesn't. When you change the oil you press a reset button and after 6000 miles or whatever the interval is some mechanism on the odometer switches the light on. 90 Series Land Cruisers have one for the timing belt. MJK 24 1 Link to comment Share on other sites More sharing options...
Zelandeth Posted October 7, 2021 Share Posted October 7, 2021 Our neighbours 1988-93 had a flatbed one of these. It was half white, half dayglo orange, split diagonally from the driver's side sill to passenger side roof gutter. It was hard to miss! howe 1 Link to comment Share on other sites More sharing options...
Faker Posted October 8, 2021 Share Posted October 8, 2021 On 5/18/2021 at 6:37 PM, howe said: I'm going to be buying new wheels to replace these, any suggestions on suitable 6x5.5 steels? From memory (way back when I was a fitter) these rims had a big valve hole, the same as the old Austin FX4 Black Taxi. I don’t believe they have been drilled out. The valves are still available online. howe, mitsisigma01, groovylee and 1 other 4 Link to comment Share on other sites More sharing options...
DavidB Posted June 19, 2022 Share Posted June 19, 2022 Whatever happened to this, did you get any further? Looking at this photo, it looks like the chassis had been shortened by a few feet, which would look quite nice! I found that photo of the one I saw in Thailand - I was sure it was a Cabstar but I think it's an Isuzu Elf, it's amazingly knackered though. Dick Longbridge, BlankFrank, howe and 5 others 7 1 Link to comment Share on other sites More sharing options...
Crackers Posted June 20, 2022 Share Posted June 20, 2022 19 hours ago, DavidB said: Whatever happened to this, did you get any further? Freaky, I was thinking about this exact thread just a couple of days ago... howe 1 Link to comment Share on other sites More sharing options...
howe Posted June 28, 2022 Author Share Posted June 28, 2022 On 19/06/2022 at 20:46, DavidB said: Whatever happened to this, did you get any further? Looking at this photo, it looks like the chassis had been shortened by a few feet, which would look quite nice! I found that photo of the one I saw in Thailand - I was sure it was a Cabstar but I think it's an Isuzu Elf, it's amazingly knackered though. I ended up working in Belgium for a bit and having a massive life shake up living/work/career wise so this stalled for a while but it's still 100% ongoing, just after a brief hiatus. I'm moving down south shortly and will be taking this down with me a short while after to start work on welding up the cab. The little H20 it came with is sat a Weber 32/34 on an adapter plate and a fresh EI kit, the previous owner had slapped on a Solex carb with a crude bit of pipe that made it run like a bag of shite. I still need to shave down the inlet manifold to separate it from the section where it sits on the exhaust manifold to avoid vapour lock as it doesn't suit running modern fuel with such a hot setup, apparently. There's also brakes to contend with still, in the short time I was looking I didnt have much luck finding disk hubs/components I could swap on, at least within Europe so it may just be a case of an overhaul and new cylinders for the time being. The cab will be good fun to weld up and I'm blasting the frame at some point before painting, then it's ready for a demountable camper back! Once all is complete I plan on running a PD130 on a Borg Warner T5 box for a bit more comfort hauling the heavier load. I'm going to be living in this once its complete so it's being done with a lot of attention paid to minor details. The fella who's workshop it's at is also making a new, larger aluminium fuel tank to replace the old one as we speak. Cracking pic of the Isuzu, I love these small jap trucks. There are some excellent photos of these Cabstars falling to pieces while still in use on Flickr etc. Scruffy Bodger, Rightnider, Datsuncog and 9 others 12 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted June 28, 2022 Share Posted June 28, 2022 What, no LD23? howe 1 Link to comment Share on other sites More sharing options...
howe Posted June 28, 2022 Author Share Posted June 28, 2022 18 minutes ago, Lacquer Peel said: What, no LD23? My life has been tremendously improved in the past few days via the loss of an LD23 powered vehicle, loaded up I've never driven anything as sluggish Low Horatio gearbox and Lacquer Peel 2 Link to comment Share on other sites More sharing options...
howe Posted July 18, 2022 Author Share Posted July 18, 2022 Updates! During the time it sat it's acted as a home for some birds who've since grown up and flown off: After a long time searching for replacement brake/suspension bits, I popped round one day to find that another bloke had brought in a Datsun truck with disk brake hubs, a reasonable master cyl and some other bits I can pilfer - that he's getting rid of entirely! He's going with S15 running gear and suspension on his so I now have a reasonable option after thinking I'd be out of luck. Carb wise we stole some bits from the old Samara carb and adapted them to sort the linkage for the new 32/34 that allowed it to be fitted well enough - along with the previous adapter plate. Set up all the kit and after some fiddling about, it now runs and drives!! First ever drive after being sat for many years below: Next will be brakes and aluminium tank, then onto bodywork and the engine etc in time. After more reading on my options and ratios, I've settled on going with a PD130 mated with a Toyota W58 box using an adapter, into a Chevy C10/Blazer rear axle (same PCD) This will be something that takes a little to get going through through the next few months, given I'm moving about and such but it won't be a particularly long time till it's driving about on the road! CGSB, puddlethumper, Back_For_More and 27 others 30 Link to comment Share on other sites More sharing options...
howe Posted July 20, 2022 Author Share Posted July 20, 2022 New gasket popped on as the old one was gimped, found one of the manifold bolts was already snapped on the left hand side in the head, will be fun getting that out... All that's left to do as it sits is sand back some top layer corrosion on the roof and coat to prevent any futher deterioration, along with ordering all the bits I need from the US and elsewhere. Found a reasonably straightforward way to beef up the front brakes on the hubs I'll be getting, so it'll hopefully have some D21 V6 front brakes on in time to deal with the more powerful setup it's getting. Dick Longbridge, Dyslexic Viking, puddlethumper and 9 others 12 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted July 21, 2022 Share Posted July 21, 2022 Great to see it on the move. Is there an off the shelf kit you can use to adapt the VW TDI to a Toyota box? I think it's a reasonably popular conversion in the US. If you don't have the gearbox already there are RWD Volvos that use VW diesels and a TDI will bolt right on to their gearboxes I believe. aldo135 and howe 1 1 Link to comment Share on other sites More sharing options...
howe Posted July 21, 2022 Author Share Posted July 21, 2022 8 hours ago, Lacquer Peel said: Is there an off the shelf kit you can use to adapt the VW TDI to a Toyota box? I think it's a reasonably popular conversion in the US. If you don't have the gearbox already there are RWD Volvos that use VW diesels and a TDI will bolt right on to their gearboxes I believe. I found an off the shelf kit made by ACME in the US that comes with the flywheel, plate etc. Their kit allows it to bolt up to a G, L or W series gearbox as long as I have the bellhousing for the 22R engine, they also have adapters for a few Suzukis but the W58 fits my application better. I'll be ordering it along with the other parts parts through a company I've used before called Stackry that repackage the items and send it all in one shipment to reduce costs a little. Interesting about the Volvos, which particular models? Lacquer Peel 1 Link to comment Share on other sites More sharing options...
Lacquer Peel Posted July 21, 2022 Share Posted July 21, 2022 8 minutes ago, howe said: I found an off the shelf kit made by ACME in the US that comes with the flywheel, plate etc. Their kit allows it to bolt up to a G, L or W series gearbox as long as I have the bellhousing for the 22R engine, they also have adapters for a few Suzukis but the W58 fits my application better. I'll be ordering it along with the other parts parts through a company I've used before called Stackry that repackage the items and send it all in one shipment to reduce costs a little. Interesting about the Volvos, which particular models? 740, 760 and 940 diesels, also 240 diesels but they weren't sold in RHD. howe 1 Link to comment Share on other sites More sharing options...
SilverMachine Posted January 21 Share Posted January 21 this thing is cool, but no updates in a while? still working away i guess? hope its still a project though! Link to comment Share on other sites More sharing options...
grogee Posted January 21 Share Posted January 21 If anyone is looking for HOT 80s JAPANESE VAN ACTION I will be inspecting this one's bottom soon. Keep an eye out on my spannering thread. scdan4, Dyslexic Viking, Dick Longbridge and 4 others 7 Link to comment Share on other sites More sharing options...
500tops Posted January 21 Share Posted January 21 30 minutes ago, grogee said: If anyone is looking for HOT 80s JAPANESE VAN ACTION I will be inspecting this one's bottom soon. Keep an eye out on my spannering thread. I had a bid on that when it was on eBay back in November! Glad to see it's made it here Link to comment Share on other sites More sharing options...
grogee Posted January 21 Share Posted January 21 2 minutes ago, 500tops said: made it here Yes and no. It actually belongs to our cleaner, Carly. She said she bought it on a bit of a punt and intends to use it for some festivals. She's asked me to 'look it over' so I'll be mainly just checking it's safe and not too rusty. It is a lovely thing though, I hope it's as good as it looks in the pictures 500tops 1 Link to comment Share on other sites More sharing options...
