mat_the_cat Posted April 4, 2016 Author Share Posted April 4, 2016 Spring is in the air! And that means time to MOT the van, as we're off to Holland in a few weeks. I pulled the cover off and thought how nice it looks in the evening sunshine: I took it for a quick test drive tonight before the test on Wednesday, and the only problem I noticed was a slight scraping from a front brake. Turns out the dust shield has corroded through and was dragging on the disc, so I'm on the lookout for a replacement pair. John F, Vince70, Lacquer Peel and 2 others 5 Link to comment Share on other sites More sharing options...
John F Posted April 5, 2016 Share Posted April 5, 2016 I'll be waking my LT up in a short while... I went to see it a month or so ago to turn the engine over, it smelt a bit musty but seemed generally OK. Link to comment Share on other sites More sharing options...
jonny69 Posted April 5, 2016 Share Posted April 5, 2016 ^ My car smells like that every morning. Nothing to worry about John F 1 Link to comment Share on other sites More sharing options...
wuvvum Posted April 5, 2016 Share Posted April 5, 2016 I'd love another of these vans, but the chances of a useable one turning up now at sensible money are pretty much zilch. I don't know if it's scene tax or export tax or a combination of both, but they seem to have gone daft (and rare). Link to comment Share on other sites More sharing options...
dollywobbler Posted April 5, 2016 Share Posted April 5, 2016 If anything, I'd say it's the lack of scene tax. Stupidly high values mean all the Transporters seem to get saved. There was never as much love for the chunky, great LT, but they were still just as good at rotting. Lacquer Peel 1 Link to comment Share on other sites More sharing options...
mat_the_cat Posted April 5, 2016 Author Share Posted April 5, 2016 I'm a bit out of touch with the prices, but every time I catch one for sale it seems more and more! I'm not liking the fact that a scene seems to be starting, but the only consolation is that bits might get re-manufactured if demand is there. This makes me sad But on the bright side I've got two disc shields on order - easier than I thought to find a set! Link to comment Share on other sites More sharing options...
mat_the_cat Posted April 6, 2016 Author Share Posted April 6, 2016 It passed Although it got an advisory for play in a ball joint, but only £18 for a Febi Bilstein replacement. Might wait for drier weather before fitting as there's no huge rush. The brake shields arrived, and I managed to pull one of the old ones off by hand! I'd noticed they were looking a bit thin when I greased the front wheel bearings last year, and that would have been the ideal time to change them whilst everything was apart. But I needed to use the van shortly afterwards, and then forgot all about it Bucketeer, Lacquer Peel, Richard and 2 others 5 Link to comment Share on other sites More sharing options...
John F Posted April 6, 2016 Share Posted April 6, 2016 Nice one, Mat! My LT's due for its MOT shortly, hopefully it'll all go as smoothly as yours. I still need to sort out the gearchange linkage at some point though. mat_the_cat 1 Link to comment Share on other sites More sharing options...
uk_senator Posted April 7, 2016 Share Posted April 7, 2016 Sounded superb and felt massively robust, in just the way a Fiat Seicento doesn't.A Seicento doesnt sound superb? You sir, are a philistine.. If you want to describe cars that sound less than impressive, mainstream Japanese cars are most fitting.. Link to comment Share on other sites More sharing options...
mat_the_cat Posted April 7, 2016 Author Share Posted April 7, 2016 Nice one, Mat! My LT's due for its MOT shortly, hopefully it'll all go as smoothly as yours. I still need to sort out the gearchange linkage at some point though. I got a bit worried a few years ago when people were saying they couldn't get hold of the bushes for the long rod any more, so did a bit of searching and managed to obtain just one. So as I needed a second I got a batch made up, but unfortunately they've all sold now. And to make matters worse, nobody seems interested in making up more. But...one of the guys I sold a pair to is pretty clued up, and has made some more. I can pass on contact details if needed? The ball at the bottom of the gear lever (where most of the wear occurs) is shared with the T5, so is likely to remain available for a good while. The short rod bushes *were* still available, but not sure any more. Part nos. for info: Ball - 015311544Short rod - 282711119Long rod - 281711209 John F and nacho man 2 Link to comment Share on other sites More sharing options...
John F Posted April 8, 2016 Share Posted April 8, 2016 Is that LTCamper98 on Brick Yard that had the bushes made? I think I might have read something on there about it. TBH I've not even worked out how the linkage set-up operates yet, I need to get the van onto the ramp & have a good look at it. I'll probably make some time for it in early to mid-May, is it OK if I drop you a PM for contact details (if needed) around then? Link to comment Share on other sites More sharing options...
mat_the_cat Posted April 8, 2016 Author Share Posted April 8, 2016 That's the one, yes. Met him a few times and he's an all round decent chap. Drop me a PM whenever John F 1 Link to comment Share on other sites More sharing options...
mat_the_cat Posted April 14, 2016 Author Share Posted April 14, 2016 Last night was dry (at least when I started) so I had a play with the van. First job was disc shields, and the mounting bolts looked a bit crusty: Fortunately all undid without sheering, although one needed a torx bit hammering into it to get a grip. Shiny shiny! The other side was much the same, but I also had to undo the upper ball joint. Unfortunately it is bigger than all 3 of my BJ splitters, so I had to improvise. By loosening the top nut, it pushes against the bolt and spacer, which is hard up against the lower BJ. So the upper joint is pushed apart. Job done! Lacquer Peel, fatharris and John F 3 Link to comment Share on other sites More sharing options...
mat_the_cat Posted April 25, 2016 Author Share Posted April 25, 2016 We had a weekend away in the flatlands of Holland, and it all went well. We caught an overnight ferry so only slept in the van one night, but it was good to have the space for bikes, cooking and getting changed etc. Not quite the oldest vehicle on the ferry! I must admit after doing a few miles in a modern car recently I've been spoilt by the sound insulation. So I'm researching soundproofing methods and materials, in the hope that I can improve the refinement before the summer holiday. Bucketeer, Vince70, Christine and 1 other 4 Link to comment Share on other sites More sharing options...
mat_the_cat Posted May 10, 2016 Author Share Posted May 10, 2016 We're going away in a few weeks, so I've bought some sound dampening material for the van. It is insanely heavy for the thickness - a 6 metre roll weighed around 45 kg! It's a rubbery, stretchy material but whatever it is it blunts cutting tools very quickly. I've covered the whole can floor and engine hump with it, as well as extending it up the front panel to the dashboard. Then the inside of the doors, taking the opportunity to soak the seams in cavity wax again. I've not been for a drive yet as I discovered the gear lever gaiter has a split, so as RHD ones are unavailable I've repaired this with superglue and will reinforce with PU adhesive tomorrow. Vince70, John F, Lacquer Peel and 1 other 4 Link to comment Share on other sites More sharing options...
dollywobbler Posted May 10, 2016 Share Posted May 10, 2016 Weight is a shame. I'm determined to quieten the 2CV once it is rot free, before my hearing suffers any further damage. Link to comment Share on other sites More sharing options...
John F Posted May 10, 2016 Share Posted May 10, 2016 I look forward to reading your feedback on the soundproofing, Mat - my LT is noisy too. Link to comment Share on other sites More sharing options...
twosmoke300 Posted May 11, 2016 Share Posted May 11, 2016 I've not been for a drive yet as I discovered the gear lever gaiter has a split, so as RHD ones are unavailable I've repaired this with superglue and will reinforce with PU adhesive tomorrow. Yeh I couldnt drive a van with such an horrendous defect either Link to comment Share on other sites More sharing options...
dean36014 Posted May 11, 2016 Share Posted May 11, 2016 When I built my LDV camper I went overboard stuffing every cavity with insulation and sound deadening. The result was the quietest, rattle free van I've ever drove. If you thumped your hand against the side it just went a solid thud. god help the poor sods who owned it in later life if they had to do any welding! Link to comment Share on other sites More sharing options...
John F Posted May 11, 2016 Share Posted May 11, 2016 dean36014, on 11 May 2016 - 1:29 PM, said:When I built my LDV camper I went overboard stuffing every cavity with insulation and sound deadening. The result was the quietest, rattle free van I've ever drove. If you thumped your hand against the side it just went a solid thud. god help the poor sods who owned it in later life if they had to do any welding! mat_the_cat, dean36014, nacho man and 1 other 4 Link to comment Share on other sites More sharing options...
dean36014 Posted May 11, 2016 Share Posted May 11, 2016 An ex citylink pug powered convoy no less. It ended up with a full conversion with shower, cassette loo, cooker, heater etc. Just wish I'd painted it white! In my defence it was many years ago, and a rusty transit didn't appeal...plus the convoy was bigger! Wish i could remember the reg number and see if iy survived. Link to comment Share on other sites More sharing options...
Jifflemon Posted May 11, 2016 Share Posted May 11, 2016 Flashing tape (http://www.wickes.co.uk/Wickes-Self-Adhesive-Hi-Tack-Flashing-Strip-100mmx10m/p/243009) is pretty good for the insides of doors, not tried it on floors though, Vince70 1 Link to comment Share on other sites More sharing options...
3VOM Posted May 11, 2016 Share Posted May 11, 2016 Flashing tape (http://www.wickes.co.uk/Wickes-Self-Adhesive-Hi-Tack-Flashing-Strip-100mmx10m/p/243009) is pretty good for the insides of doors, not tried it on floors though,The audio types don't recommend it as the bitumen will soften and melt, and the tape will slip down or fall off. What is the damping mat stuff mat_the _cat has used? Link? Link to comment Share on other sites More sharing options...
mat_the_cat Posted May 13, 2016 Author Share Posted May 13, 2016 It was Tecsound SY50; more info here:http://www.domesticsoundproofing.co.uk/soundproofing/t50.htm Delivery is the killer, as it was almost as much for that as for a roll! But I'm pleased to say it's made a difference. More for road/tyre noise rather than engine noise I would say. I wish I'd done a before and after decibel measurement to quantify it, but it was certainly easier for a handsfree call today. Link to comment Share on other sites More sharing options...
mat_the_cat Posted June 1, 2016 Author Share Posted June 1, 2016 We're 800 miles into our England/France road trip now, and currently at a camp site near Orleans. Before we set off I loaded up with fuel due to the strikes, and a very heavy transformer which I had sold on eBay. The fuel has not been needed yet, as the panic seems finished over here. But I met the transformer buyer on the way down, and he turned up in possibly the least suitable car for the job... It took 4 of us to load it into where the passenger seat had been, and it didn't fall through the floorpan! We stopped overnight in a scenic car park on Saturday, and decided to have a barbecue as the weather was so nice. Then this happened. Fortunately the awning kept the rain off. The tunnel crossing went smoothly, the only point to note was seeing this in the car park. We've had a bit a a wet day today, and loads of roads are closed due to flooding. We're camped next to the Loire and it looks rather full! But at least the can us going well and doing a reasonable 25 mpg. Seeing as this is supposed to be a blog about the vehicle, have a photo: Skizzer, Vince70, The Moog and 11 others 14 Link to comment Share on other sites More sharing options...
mat_the_cat Posted August 14, 2016 Author Share Posted August 14, 2016 Minor update...been used for plenty of weekends away this summer - here is a photo from down in Herefordshire last night: Exiled_Tat_Gatherer, Vince70, loserone and 10 others 13 Link to comment Share on other sites More sharing options...
dollywobbler Posted August 14, 2016 Share Posted August 14, 2016 The first Autoshite vehicle I saw in my new Rover. That was a nice surprise on the run home. mat_the_cat 1 Link to comment Share on other sites More sharing options...
mat_the_cat Posted April 2, 2017 Author Share Posted April 2, 2017 It's been a while since I updated this - in the meantime it's been going well but not used much over the winter (although was very welcome after my work's Christmas do, 40 miles from home). We had a nice weekend away in it a couple of weeks back, visiting Ludlow. Parked in a quiet car park in the middle of town, only to be awoken at 5-something AM by the Sunday market setting up We've booked our French holiday this year, which will be fairly far south and in July. Last time we went in midsummer the temperatures were scorching - worryingly so for our dog who was panting quite a bit during the journey. Not too comfortable for us either, but at least we can sweat to regulate our body temperature! So I've decided to bite the bullet and fit air con to the van; it's one thing that really makes a difference to me on a journey. Maybe I'm spoilt by driving the BX? So at the moment I'm researching and pricing up retro-fit systems...watch this space! chodweaver, Lacquer Peel, JayW and 4 others 7 Link to comment Share on other sites More sharing options...
mat_the_cat Posted April 4, 2017 Author Share Posted April 4, 2017 Question is, do I go for something like this?http://www.ebay.co.uk/itm/Universal-air-con-kit-DAF-truck-excavator-forestry-agricultural-camper-/302215603153 Which would be great whilst driving along, but of little use on a campsite. Although the van is reasonably well insulated (meaning it takes a while for the sun to heat it up), the downside of the cab over engine is that heat soak after a journey warms the inside for hours. Some nights it's a struggle to sleep, and I can't really leave the engine idling all night, even when wild camping. Or something like this: Ideal while on a campsite and connected to the mains, but no good whilst driving - even if I hammered the inverter (which would probably need to be a hefty pure sine wave type to run the motor) and alternator, the cool air is going to be chilling the back of the van leaving us cooking up front. Plus all the weight is high up so not ideal in terms of weight distribution. But two separate systems could be considered overkill! I think that some fridge van systems run either from an engine-driven compressor, or hooked up to the mains. So a dual purpose system would seem to exist... Jim Bell 1 Link to comment Share on other sites More sharing options...
mat_the_cat Posted April 16, 2017 Author Share Posted April 16, 2017 A lucky find on eBay, and a 300 mile trip in the BX to collect (which cost me almost as much in LHM as fuel thanks to a leaky PAS ram) resulted in this! A standalone AC unit, together with a matching inverter and all manuals & wiring. The cold air is ducted to wherever I want it, and the inverter is a pure sine wave output with enough surge capacity to start the compressor. It will draw about 55 amps @ 12 V when the AC is on, so seeing as I fitted a 90 amp alternator a few years back to replace the standard 55 amp unit I should be OK. Problem is space! Underneath one front seat is a leisure battery and various wiring, which was the initial installation when I first kitted out the van. And underneath the other is a pair of leisure batteries I added about 6 or 7 years ago to increase capacity.But I reckon I can shift the batteries around, and in the process neaten up the wiring seeing as there have been a few additions over the years. First job was to shift the batteries behind the driver's seat. Once they were out I started to dismantle the seat and it looks like it should fit! Could have been made to measure cobblers, Vince70, UltraWomble and 6 others 9 Link to comment Share on other sites More sharing options...
