13 hours ago, RoverFolkUs said:
With the current prices of fuel, a small economical vehicle would be the perfect choice. But if you're looking for the complete opposite of that, I present to you a fine* Chevrolet Tacuma.
Eye watering £340 VED (lucky it's not an Auto)
I had its older brother, and something of a unicorn now, a DAEWOO Tacuma a number of years ago, with the same engine + box. Apart from the usual GM/Vauxhall traits (eating lambda sensors and ignition coils like they were going out of fashion) it was a very good vehicle for what it was and I would recommend!
I used to squeeze 30 MPG out of mine around the doors, and 40 MPG at a push on a run. So wasn't too bad for what it was
1733472091_Screenshot_20220313-2345262.thumb.png.a9b96c115844fc425a6c14e255cc6c4c.png
https://www.gumtree.com/p/cars-vans-motorbikes/chevrolet-tacuma-16-sx-5-door-hatchback-2006/1427508472?
I forgot about those Tacumas. Never see them anymore!
That is something to be thankful for.
22 hours ago, wesacosa said:
Did they make an estate Crusader? Late registration madness
No MOT and history shows it has an issue with the screen wash, for some reason.
Typically the  engine and gearbox have been changed. The lines denoting that this is a Crusader have gone too.
Has someone sold this car for scrap?As  the seller is We Want Your Motorcar LTD.
My dad's Cortina 1.6L estate was a Y reg. But it was a bulk buy company car. Also estate may live longer than saloon as I imagine Sierra hatch preceded the estate by 6-12 months
Yes they did!
Owner of a local Spar corner shop (remember them?) had a Y- reg late 82 2.0 Crusader estate bought new in dark brown with beige lower panels.
The Crusader was a sort of cross between a 1600L and the rest of the range with some Ghia trim bits on it. (Just buy a Ghia).
No 2-doors though.
Wasn't the estate a carosel or chasseur ? The brown on beige Granada was a chasseur maybe the Cortina was too.
1 hour ago, wuvvum said:
@Will on Syros Fancy another?
or @EmperorPigeon or @coalnotdole :)
its pleasantly surprising how many of them have been coming out of the woodwork of late
tho sadly most seem to be in quite the state
if I had the means I could see myself ending up with one!
this particular one would go well with @Zelandeth's Cav! :)
52 minutes ago, D.E said:
Massive WANT
Partly because I've never seen a 25 in that colour, partly because of the BRM interior, partly because I want to see what the 1.1 K-Series in the 25 is like and whether they're as bad of an idea as they sound!
Edit - I need to read adverts properly! It's had an engine upgrade. Original 1.1 included though.
I'm sure* it didn't have OMGHGF and that was the real reason it was swapped 🙃
Nope,  brown over gold was a crusader colour scheme and definitely available on a Y plate. See @DodgyBastardfor his latest purchase, Crusader estate on a Y.
If I had the pennies? Sure. Wouldn't go more than a grand, as it would take at least that to recommission her at a basic but mechanically sound level. All the original glass and intact and it looks like one of the early ones. I did laugh at the description "might make a good go kart" 🤣 "worth a bit more than that mate" I thought!
Be an idea to get the reg plate for the E8000 database!
