Dyslexic Viking Posted May 16, 2024 Posted May 16, 2024 I don't know if I'm imagining this but have the pictures on the forum gone back to being small again? And content I started is empty so I have difficulty finding threads I have started.
loserone Posted May 16, 2024 Posted May 16, 2024 1 hour ago, Dyslexic Viking said: And content I started is empty so I have difficulty finding threads I have started. Guessing there's an indexing issue as the 'unread content' filter is empty for me too.
Dave_Q Posted May 16, 2024 Posted May 16, 2024 Seem to be getting quite a bit of "bad gateway" and failed/multiple posts this morning, on both mobile and PC.
SiC Posted May 16, 2024 Posted May 16, 2024 When I moved the server to have more CPU cores and RAM dedicated to it, I switched back on the elasticsearch service. That allows the entire forum content to be indexed and show up in the search. The forum also uses this index on page generation too, so it makes the whole site more responsive. However elasticsearch has a tendency to randomly crash (I blame crappy code compounded being written in Java...). It appeared to have done that last night and made a multi-gigabyte crash dump file. That was so large, it completely filled up the storage associated with the elasticsearch service. I split them out separately so if something like this goes wrong, it doesn't fill the main disk. If that gets full, all sorts of bad things happen. Basically I've set it up to go into a kind of "limp mode" where things still work just not great, rather than the whole thing falling over dead. Anyway I've just cleared out the dump file and hit reindex on the search. On this new setup I've noticed it only takes an hour or so to finish that job rather than the ~18 hours on the old setup (much faster cores). So hopefully within an hour it should all be back to normal. Next thing I've got to figure out is how to stop elasticsearch shitting the bed. It's kludgy but my best thought right now is to restart that service in the early hours of the morning. Basically switching it off and on again. Only takes a few minutes to do it and no one should be affected if it's the early hours. Unfortunately in the current version of the forum software there are really only two options for search services. The older method (stores data in the main database) which the forum is too big to do (locks up the server on searches with large number of results) or this elasticsearch method. Right now there isn't a magic bullet but I'm hoping I can make it stable with a regular restart at night. mercedade, LightBulbFun, Snake Charmer and 5 others 3 5
Remspoor Posted May 16, 2024 Posted May 16, 2024 I get my notifications by email. The timing per day changes. Then occasionally it misses a day. That is not an issue. The solution may help those who are loosing their activity feed on the forum is to save the first page on any post as a fav in your browser. Head there and go to last page. Job Jobbed.
SiC Posted May 17, 2024 Posted May 17, 2024 Just had to poke the search service again this morning as it fell over consuming all the space again 🫤 So you might have had a few errors when navigating around in the last half hour when I restarted it. You'll see when it has fallen over right now as the unread notifications have an empty period of no updates when the service was down. I'll rebuild the index in a bit which will fix that blank period. I'm still going to poke around to see if I can find an option to disable these crash dumps, so you might see a few more errors randomly come up. Reckoned it'd be better for people to see random errors and still be able to use the forum, rather than taking it down for hours on end. Remspoor, Snake Charmer, LightBulbFun and 2 others 1 3 1
bunglebus Posted May 17, 2024 Posted May 17, 2024 I've got a really weird glitch, and I don't know if it's the site or my phone - let's say I quote someone but want to delete a part of that quote. Holding delete, each time I reach the end of a line of text, the letter to the right of the cursor disappears, so it's deleting one letter to the right each time I delete a full line to the left (hope that makes sense). This is on my phone, android using Google Chrome
Zelandeth Posted May 17, 2024 Posted May 17, 2024 1 hour ago, bunglebus said: I've got a really weird glitch, and I don't know if it's the site or my phone - let's say I quote someone but want to delete a part of that quote. Holding delete, each time I reach the end of a line of text, the letter to the right of the cursor disappears, so it's deleting one letter to the right each time I delete a full line to the left (hope that makes sense). This is on my phone, android using Google Chrome I've seen that one as well. Pretty sure it's just the Invision editor being itself. Which should be read as "a buggy piece of garbage." SiC and bunglebus 1 1
SiC Posted May 17, 2024 Posted May 17, 2024 Looks like they're completely replacing it in version 5. Thank goodness. https://invisioncommunity.com/news/invision-community/invision-community-5-the-all-new-editor-r1301/ bunglebus 1
Zelandeth Posted May 17, 2024 Posted May 17, 2024 2 hours ago, SiC said: Looks like they're completely replacing it in version 5. Thank goodness. https://invisioncommunity.com/news/invision-community/invision-community-5-the-all-new-editor-r1301/ I'll believe it when I see it! Probably be exactly the same thing with a different skin thrown on top of it. Or knowing Invision, will be even worse than the old one!
Cookiesouwest Posted May 21, 2024 Posted May 21, 2024 Searching for my own content. What am I doing wrong? I use to find it under my own activity, But its not on the list and I have to scroll down on the main page to find it So, what am I doing wrong?
EyesWeldedShut Posted May 22, 2024 Posted May 22, 2024 Today I go to https://autoshite.com/discover/unread/ and I get What have I broken?
loserone Posted May 22, 2024 Posted May 22, 2024 On 17/05/2024 at 08:13, SiC said: You'll see when it has fallen over right now as the unread notifications have an empty period of no updates when the service was down. I'll rebuild the index in a bit which will fix that blank period. 1 hour ago, EyesWeldedShut said: Today I go to https://autoshite.com/discover/unread/ and I get What have I broken? Think it's this ↑↑ EyesWeldedShut 1
Spiny Norman Posted May 22, 2024 Posted May 22, 2024 Just a personal opinion but for me, how quickly/efficiently the website performs under regular thread reading conditions is far more important than a search function I might use once a week, and it's still slow enough on occasion (eg last night) for me to open another site on another tab to be sure it's not my internet connection. beko1987 and mercedade 1 1
Zelandeth Posted May 22, 2024 Posted May 22, 2024 2 hours ago, Spiny Norman said: Just a personal opinion but for me, how quickly/efficiently the website performs under regular thread reading conditions is far more important than a search function I might use once a week, and it's still slow enough on occasion (eg last night) for me to open another site on another tab to be sure it's not my internet connection. One of the big headaches here (assuming my understanding of the architecture is right) is that the service involved in providing the search functionality doesn't *only* provide the ability to search for things. It's also behind the scenes tied into a number of other functions. So you can't just turn it off or use any off-the-shelf service such as a customised Google search (as a couple of other forums I'm on do) as it Will Break Things. You're stuck with a couple of choices for supported services, and they're both as bad as each other albeit in different ways I don't quite understand how or why Invision have managed to make the service in question so heavily integrated into things...but then again I don't understand why Invision make a LOT of design decisions, so that's not saying much. SiC 1
mercedade Posted May 24, 2024 Posted May 24, 2024 It's all gone ballz again. Chrome, 10.30am Other sites behaving.
MorrisItalSLX Posted May 24, 2024 Posted May 24, 2024 Forum is running as slow as a wet week, getting a number of bad gateway errors. Jenson Velcro 1
Scruffy Bodger Posted May 24, 2024 Posted May 24, 2024 Someone needs to give the hamster a poke. The Dark Wob is positively lightening compared to AS at the mo.
danthecapriman Posted May 24, 2024 Posted May 24, 2024 Everything is running mega slow this evening… Dyslexic Viking 1
Scruffy Bodger Posted May 24, 2024 Posted May 24, 2024 3 hours ago, danthecapriman said: Everything is running mega slow this evening… It sped up massively this afternoon for me. I assumed Si had done his magic in the background?
danthecapriman Posted May 24, 2024 Posted May 24, 2024 26 minutes ago, Scruffy Bodger said: It sped up massively this afternoon for me. I assumed Si had done his magic in the background? It seems pretty good now. I won’t even pretend to know why or what causes it of course! Hit it with a hammer and harsh language??😄
rantingYoof Posted May 28, 2024 Posted May 28, 2024 I was trying to find @NorthernMonkey's thread about the Forum's performance and mobile options (I think he started a thread? Or did I dream it). The forum has become progressively slower and slower for me over the last few days. This evening it's 5-10 seconds between page loads. And Tapatalk is royally fucking me off now that every time I open it it insists on a full-page advert which is only skippable if you press a faded out 'X' after five or ten seconds - only subscribing to it will overcome this and I'm not paying for it (/tightarse). Should I empty cache or do something my end, or is this something other people are experiencing too?
rantingYoof Posted May 28, 2024 Posted May 28, 2024 Holy shit, and just like that it's now instant page loads every time! Thanks to whoever gave the server box a virtually kicking!
Tickman Posted May 30, 2024 Posted May 30, 2024 Don't know what's going on with the site. It has been so slow it is almost unusable, 30 seconds to load a page type of slow, and it was unavailable about an hour ago.
mercedade Posted May 30, 2024 Posted May 30, 2024 Yeah, getting the same problem. Was super speedy during the day, now grinding hard
dome Posted May 30, 2024 Posted May 30, 2024 Yep, same for me. I might have to venture into the real world as it's so frustrating
