4 minutes ago, grogee said:
£5k seems a good price but if it's as good as the advert suggests, why hasn't it got an MoT?
Show's as MOT'd for me.
Landsails are off putting though.
2 hours ago, grogee said:
It must be an optical illusion but I always imagined the Mk3 was a bit bigger than the Mk4.
Are there any classic Ford lickers that can put me right?
Mk3-4-5 all use same shell on est ( only back wings differ on est & scuttle swage lines).
2 hours ago, mat777 said:
I'm still trying to work out how a 2002 van is  remotely approaching compliant in the first place?!
08 reg, I think all diesels from 2006 are compliant.
Picture 1 of 5
Euro cargo | eBay
'This lorry has never failed an MOT'
U WOT M8, 59% OFF | www.ssa-school.org
5 February 2024
FAIL
Mileage
118,662 km
Test location
SM Shepherd CVR Ltd
Test certificate number
X21I34457
  • For vehicles required to be fitted with a tachograph: tachograph installation/calibration plaque out of date. (26.3.c)
  • offside rear Actuators, hydraulic master & wheel cylinders, valves and servos: leaking air or fluid, fractured, cracked, excessively damaged or corroded. Brake chamber cracked (59.5.c.i)
Repair as soon as possible (minor defects):
  • nearside axle 2 A tyre: obviously underinflated. (8.1.f)
  • A tyre: Axle 2 n/s inner tyre wall cracked (8.1)
  • Any oil leak which can deposit PTO pump area (44.1)
  • Engine MIL Engine warning light staying on (5.5)
?imw=5000&imh=5000&ima=fit&impolicy=Lett
7 minutes ago, Pat Earrings said:
Must be interesting for the driver, sitting inches away from a dead body in a woven (and therefore presumably not airtight) coffin.  I hope they have a LOT of Magic Trees in there.
Not in the slightest.
ULEZ is Eu6 diesels from circa 2015. Even if it somehow was 2008, the van is from 2002 despite the later reg.
I'll have some of what the seller is smoking....
to be fair to him it does come up as Ulez complaint on the website. I suspect it must have been registered to someone disabled or otherwise exempt or its a glitch in the system
There are a few anomalies like that with ULEZ.  My 2007 Hyundai Getz is ULEZ compliant, despite being Euro 4.
I'll second that, my 1998 little Suzuki Swift is compliant in all but Birmingham clean air zones around the country, work that one out!
