2 hours ago, ProgRocker said:
....Pass the point of no return?
1978 V8
Image 1 - Rover sd1 v8
Serviced by Moss?
This vehicle's MOT has expiredYou can be fined up to £1000 for driving without a valid MOT
This vehicle may be MOT exempt, for more information refer to MOT exemption guidance
K577XJBPEUGEOT 205
Check another vehicle
ColourBlue
Fuel typeDiesel
Date registered26 March 1993
MOT expired on6 March 2021
Get an MOT reminderwhen the vehicle's MOT is near its time for renewal.(Opens in a new Window) by email or text.
If you think the MOT expiry date or any of the vehicle details are wrong, contact DVSA.
Open All
MOT history
Check mileage recorded at test, MOT expiry date, defects and advisories, and view test certificate
Date tested7 March 2020
PASS
View test certificate
Mileage118,525 miles
MOT test number3803 7878 3937
Test location
View test location
Expiry date6 March 2021
Repair as soon as possible (minor defects):
  • Battery insecure but not likely to fall from carrier (4.13 (a) (i))
  • Fuel Pipe/s corroded ()
  • Nearside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c))
  • Offside Front Suspension component mounting prescribed area is corroded but not considered excessive inner arch (5.3.6 (a) (i))
  • Nearside Front Brake hose slightly deteriorated (1.1.12 (b) (ii))
  • Offside Front Brake hose slightly deteriorated (1.1.12 (b) (ii))
What are advisories?
Date tested18 December 2019
FAIL
Mileage118,521 miles
MOT test number4648 1126 4864
Test location
View test location
  • Service brake efficiency below requirements (1.2.2 (a) (i))
  • Parking brake efficiency below requirements (1.4.2 (a) (i))
  • Front Brakes imbalanced across an axle Axle 1 (1.2.1 (b) (i))
  • Offside Front Service brake excessively binding (1.2.1 (f))
  • Nearside Rear Brake hose excessively deteriorated (1.1.12 (b) (ii))
  • Offside Rear Brake hose excessively deteriorated (1.1.12 (b) (ii))
  • Nearside Rear Brake pipe excessively corroded (1.1.11 (c))
  • Offside Rear Brake pipe excessively corroded (1.1.11 (c))
  • Nearside Brake pipe excessively corroded front to rear (1.1.11 (c))
  • Windscreen washer not working (3.5 (a))
  • Nearside Windscreen wiper does not clear the windscreen effectively (3.4 (b) (ii))
  • Offside Windscreen wiper does not clear the windscreen effectively (3.4 (b) (ii))
  • Offside Front Position lamp not working (4.2.1 (a) (ii))
  • Offside Side repeater not working (4.4.1 (a) (ii))
  • Nearside Front Seat belt buckle not functioning as intended (7.1.2 (d))
  • Offside Front Seat belt buckle not functioning as intended (7.1.2 (d))
  • Coolant leak ()
Here's an oddity... what appears to be a low mileage, clean VW Vento. But it's had a Mk3 Golf front end fitted - this was once a popular modification among the dUbBerZ, but the rest of the car looks largely unmodded and original. Weird that anyone would swap the front end and do nothing else! Maybe it had a smack on the nose at some point and the Golf panels were easier to get than Vento ones?
Whatever the reason, I rather like it.
https://www.facebook.com/marketplace/item/593605441769023
May be an image of car and outdoors
43 minutes ago, sickboy said:
"This is an unrepeatable chance to buy a piece of Bavarian motoring history. "
In that case I’m obviously wrong 🙄 I see it as this: What you’re actually buying will fit in your pocket, don’t worry about a trailer because  the rest is literally 💩
2 hours ago, Rod/b said:
Fuck me, I don’t know about the deathcopter but the trailer made out of a sawn off Luton van is epic shite.
That trailer HAS to win the Internet....ex BT with a dick on its forehead!!!!
12 hours ago, NorfolkNWeigh said:
In the ad. it mentions lots of spots on Google. This includes a 2018 one on AS by @RobT.
As far as I’m concerned , the Palio will always be the car that inspired the famous feminist graffiti.
Ah, I did wonder if that's the Palio I spotted in Clapham once.  Couldn't be arsed searching my thread.  On my watchlist already, just in case the bidding stays sensible.
19 hours ago, wuvvum said:
Cheap old ERF - running but needs a clutch.
That's a few miles from home now, John Somerscales are still a timber merchant, but have gone into the heavy/abnormal load business
Somerscales
From the advert.
Quote
water cooled trailer fully inclosed
Now that is something.
6 minutes ago, sheffcortinacentre said:
That isn't as it's a cut up van the genuine bantam bakkies use a STD height roof not the higher van one.
I was wondering if it was a converted van but if that is the case then it is professionally done as this looks original.
