11 hours ago, bezzabsa said:
would perform certain acts in return for the keys to this....IF the owner is Female of course!!!!!
50 minutes ago, cpjitservices said:
Manual tranny?
A tranny might look Female enough for certain manual acts to be performed
In the oul days, this was known as transubstantiation.
1 hour ago, Supernaut said:
I've never seen a carb/intake layout like that before!
Definitely an interesting one. With old American V8s I always expect them to just be sitting in the valley.
They had the same layout on some of the Chrysler 300 letter cars
think it’s something to do with the way the torque is delivered at low rpms , my brother told me years ago
Yes, AFAIK that's right, it's called a Cross-Ram inlet.  When I was first model-building in the 60s it was one of the options on my Airfix-MPC 1/25 1966 Dodge Charger.
2 hours ago, sdkrc said:
https://www.carandclassic.co.uk/car/C1369411
@eddyramrod beautiful but also a touch too expensive
Absolutely, but HFM?  It had better be the best example on the planet for that!
2 hours ago, wuvvum said:
@brownnova - cheap 9000 on your manor (ish)
Would you believe this is the fourth 9000 which I’ve been alerted to today alone!!
Will watch with interest…
That Corolla is too close to ignore....
Dammit!
4 hours ago, eddyramrod said:
....Absolutely, but HFM?  It had better be the best example on the planet for that!
DD Classics prices are a joke. That is what happens when you operate in that London.
3 hours ago, flat4alfa said:
Citroen Saxo 1.5 Diesel
Bosch pump, it will run on anything
IF IT DOESN'T SELL..................... I'LL TURN IT IN TO A LAWNMOWER
EFTalbot
21 hours ago, MarvinsMom said:
proper Crown Vic P71 interceptor.
shame its got a shagged transmission.
Image 31 - Ford Crown Victoria Police Interceptor Californian Highway Patrol P71 V8
It's got cop tyres, cop suspension, cop shocks but sadly just a stock gearbox.
21 hours ago, morrisoxide said:
Nice.
What is that silver box to the left of the wiper motor, a replacement air blower/heater or a CB radio?
Also that fuel pump will leave you stranded. Edit it has no Jubilee clips!
https://www.ebay.co.uk/itm/265325175835?hash=item3dc69ce41b:g:hRsAAOSwdO1hSzFU
21 hours ago, Asimo said:
Possibly an old part of radio equipment, it looks like an antenna plug on the side, has vent holes. Did some valve car radios come in two boxes, part in the dash, part elsewhere?
The heater won’t work too well without it’s fan and ducting…
I thought it could be more oil related. The tubing exiting from the front is solid, like fuel or brake line. It has a  joint which is similar to one I have on my Westminster. That is on the line for the pressure gauge. If I recall correctly.
Skudder Octavious, looks like minor damage, £499.....
Image 1 - Skoda Octavia SE Plus TDI CR 14Airbag deployed, but looks minor yeah?
Image 3 - Skoda Octavia SE Plus TDI CR 14Errr...... hello, is that DA SHITE POLIS?
Image 9 - Skoda Octavia SE Plus TDI CR 14FFS I've raced straighter cars than this.... and brought them home straighter too.
Quote
13 March 2021
PASS
View test certificate
Mileage229,668 miles
MOT test number4182 9939 8711
Test location
View test location
Expiry date12 March 2022
  • Front Brake pad(s) wearing thin (1.1.13 (a) (ii))
  • Oil leak, but not excessive (8.4.1 (a) (i))
  • Offside Front Suspension arm ball joint has slight play (5.3.4 (a) (i))
  • Offside Front Tyre worn close to legal limit/worn on edge (5.2.3 (e))
Get (moar) bent.
https://www.ebay.co.uk/itm/114996163231?hash=item1ac64e329f:g:JOAAAOSwRpphRMyz
