Are you sure you have a wife?
I still want to see what she looks like.
If she was ever going to drive that, hopefully not very tall.
I hate to admit it but that looks alright actually. I hope I am not turning into a crusty juggler.
I've known Charlie for a few years, he's a complete dick but quite useful/amusing at the same time. He does have a wife, Bev, and she's not very tall. But she is recently confined to a wheelchair so the chances of her getting to drive this went from slim to none.
https://www.ebay.co.uk/itm/Renault-trafic-campervan/123026280371?hash=item1ca4f00fb3:g:2a8AAOSwHqdarR~u
'Just when you think you've heard it all, a camper van with an upstairs toilet.
'We have converted the van on the inside so that you can seep in the pop up section freeing up the seating area'
I'm a bit concerned with Eddyramrod's cardiovascular veins by posting this.
https://www.ebay.co.uk/itm/1955-Chrysler-Windsor-Town-Country-Wagon-american-V8-auto-ps-pb-cadillac-chevy/132541620632
I AM THE ONE who wants to deliver this car. To fucking Syria, if need be.
How much more confirmation do you need that life is way overrated?
https://www.ebay.co.uk/itm/Cadiliac-Hearse-Funeral-Vehicle-MUST-SEE/263555291932
 Mr Ramrod to the white courtesy phone, it has been located.
All you need is to collect it !
And about GBP5000 plus costs of about the same.
https://www.trademe.co.nz/motors/specialist-cars/other/auction-1569506306.htm?rsqid=90312786b9a7411e917b0cc9eb39e43c
Yes, yes and yes, unanimously.
29197196_10211618501326359_4784607788380
fiat x19 bertone resto project
£1,350
Bolton
Found this little fiat in a garage yesterday it does need a little bit of work but good all around car I have put a battery in it and it does turn over and runs on easy start the fuel tank is currently not fitted but hopefully have it back in and the car driving today please inbox me for more details thanks
Robert Harris
https://www.facebook.com/groups/176622142477438/permalink/1148557291950580/?sale_post_id=1148557291950580
Yellow X1/9 was last tested in 2013 when
Reason(s) for failure
  • Speedometer cannot be illuminated. (6.7.3)
  • Windscreen has damage to the swept area in excess of a 40mm circle outside zone 'A' (8.3.1d)
  • Windscreen washer provides insufficient washer liquid (8.2.3)
  • Battery insecure (1.9.1)
  • Front Electrical wiring damaged and bare wires exposed (1.9.2c)
  • Nearside Front position lamp(s) not working (1.1.A.3b)
  • Nearside Headlamp not working on dipped beam (1.7.5a)
  • Offside Headlamp not working on dipped beam (1.7.5a)
  • Nearside Headlamp not working on main beam (1.7.5a)
  • Offside Headlamp not working on main beam (1.7.5a)
  • Nearside Front Direction indicator not working (1.4.A.2c)
  • Offside Rear position lamp(s) not working (1.1.A.3b)
  • Offside Indicator tell tale inoperative (1.4.A.2a)
  • Rear fog lamp not working (1.3.2b)
  • Fuel cap/sealing device does not fasten securely maintaining the sealing arrangement (7.2.4b)
  • Fuel cap/sealing device does not fasten securely by positive means (7.2.4b)
  • Fuel cap/sealing device sealing washer missing (7.2.4c)
  • Offside Rear Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
  • Nearside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
  • Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
  • Nearside Rear Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
  • Offside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
  • Nearside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
  • Parking brake lever has no reserve travel (3.1.6b)
  • Offside rear brake recording little or no effort (3.7.B.5a)
  • Nearside rear parking brake recording little or no effort (3.7.B.6a)
  • Offside rear parking brake recording little or no effort (3.7.B.6a)
  • Nearside Rear wheel bearing rough when rotated (2.6.1)
  • Nearside Rear Wheel bolt(s) missing (4.2.A.1e) Dangerous
  • Offside Front Wheel bolt(s) missing (4.2.A.1e) Dangerous
  • Nearside Front Wheel bolt(s) missing (4.2.A.1e) Dangerous
  • Offside Rear Wheel bolt(s) missing (4.2.A.1e) Dangerous
  • Exhaust emissions carbon monoxide content excessive (7.3.B.1a)
  • Service brake: efficiency below requirements (3.7.B.7) Dangerous
  • Parking brake: efficiency below requirements (3.7.B.7) Dangerous
  • Brakes imbalanced across an axle (3.7.B.5b) Dangerous
Advisory notice item(s)
  • nearside floor pan has a hole caused by corrosion but is not within a perscribed area
  • offside floor pan has a hole caused by corrosion but is not within a perscribed area
  • nearside parking brake cable snapped
  • nearside rear cv boot is insecure
  • nearside rear cv boot is damaged
" it does need a little bit of work but good all around car"
Old Fiat possibly stolen from garage won't see the road again in quite a while [because the owner probably wants it back].
Old Fiat requires a few insignificant niggly bits sorting shocker.
its not fucked then :)
Best colour, too! That ended up quite cheap, probably due to the appalling advert. Would have been worth buying, then getting one of the 2T 172 conversions and serving myriad Lambretta owners.
I thought so - if I had had a bag spare i'd have lobbed a bid in.
Current eye on a H100 that looks very minty with only one owner from new.
https://www.gumtree.com/p/cars-vans-motorbikes/vauxhall-zafira-was-running-until-robbed-by-local-garage-300-of-new-parts-on-it/1288225979
Clear and comprehensive pictures.... Nope
A well written and detailed description.... Nope
Summary of car's important history.... Nope
Reasonably priced.... Nope
Incomprehensible rant about being swindled by some garage.... Yep
