Recommend a motor
Yep, we've decided that the Rover is the next on the fleet to be replaced, and MrsH isn't sure what to go for. We've got a criteria (who doesn't?) but as usual, we'll bend the rules for the right motor:
- Max of £1000 - ideally around the £800 mark.
- No saloons, we have a spaniel and a baby.
- Petrol or diesel - we prefer older diesels if we had to go that way. Her trip to work is a 24 mile round one and I don't think new fangled common rails are good at that short a distance. Doesn't need to do 60MPG but at the same time can't do 12mpg
- No VAG products. Neither of us like them.
- Bigger than a Rover 200. I suggested a Streetwise but she hit me
- Mildly interesting/shite (that's for me)
- relatively safe in a smash
Any advice? So far I've been looking at Accord estates, Volvo's etc, but don't want to miss the chance of anything decent.
The FatHarris fleet:
'98 BMW 728i (Herman)
'99 Rover 220Di (Herbert)
'98 Mazda MX-5
'92 Honda Beat (Rotten project)
'91 Rover Mini Neon (Long term rotten project
'07 Kia Magentis (MIA)
The Rover /may/ be offered for ROFFLE on here once we have a new motor - we will see how much MOT is left on it by the time we actually replace it.
'98 Mazda MX-5
Rover 400 tourer, or 75 tourer ?
400 tourers only come up every so often as rare, however.
One on Facefart in Scotchland : https://www.facebook.com/marketplace/item/1868797623176111
Or buy a diesel Streetwise anyway - she'll quickly fall in love with it, honest, but too smoll for your needs really (same size as 200)
Is this just a way of getting loads of people to extol the virtues of bloody Rover 75s and ZT-Ts
Edited to add: See! Before I'd even managed to type it.
As if....
(realises too late to delete previous post)
Yeah, I went left field with the 400 tourer though so
Seeing as he's all the way down in the SW of England, do we try getting him into an utterly ridiculous collection mission?
R8 400 Tourers were definitely in my vision as MrsH loves her Rover, but finding one at a decent price was a challenge.
I'll have a look at that advert thought, ta
I could likely view if needed although there are other shiters closer (assuming it's the black scotchland one)
£650 - 96,000m
https://www.ebay.co.uk/itm/subaru-legacy-96000-miles-mot/264116260293?hash=item3d7e8e4dc5:g:XqgAAOSwe9VcLfEL:rk:6:pf:0
This is a new service. Complete a quick survey to help us improve.
X213BYD SUBARU LEGACY
Check another vehicle
Colour Red
Fuel type Petrol
Date registered 1 September 2000
MOT valid until 7 October 2019
Get an MOT reminderwhen the vehicle's MOT is near its time for renewal. (Opens in a new Window) by email or text.
If you think the MOT expiry date or any of the vehicle details are wrong, contact DVSA.
Check mileage recorded at test, MOT expiry date, defects and advisories
Date tested 8 October 2018 Pass
Mileage 94,404 miles
MOT test number 8661 4483 2350
Test locationView test location
Expiry date 7 October 2019
  • rear subframe corrdoding
  • underside corrosion
  • exhaust corroded
  • rear inner wheels arches corroding
  • Rear Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
  • headlamps slightly deteriorated
What are advisories?
Date tested 5 October 2018 Fail
Mileage 94,401 miles
MOT test number 6182 5935 5161
Do not drive until repaired (dangerous defects):
  • Offside Front Hydraulic brake calliper leaking and braking performance affected (1.1.16 (B) (ii))
  • Service brake efficiency below requirements (1.2.2 (a) (i))
  • exhaust corroded
What are defects and advisories?
The MOT test changed on 20 May 2018
Defects are now categorised according to their severity – dangerous, major, and minor. Find out more
Date tested 29 October 2010 Pass
Mileage 93,439 miles
MOT test number 4041 8290 0370
Expiry date 28 October 2011
Advisory notice item(s)
  • Rear Anti-roll bar has slight play in a pin/bush (2.4.G.2)
Date tested 29 October 2010 Fail
MOT test number 6721 1230 0367
Reason(s) for failure
  • Offside Front Front suspension has excessive play in a lower suspension ball joint (2.5.B.1a)
  • Offside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
  • Nearside Front Tyre worn close to the legal limit (4.1.E.1)
  • n/s inner cv boot split
What are failures and advisories?
Date tested 24 September 2010 Fail
Mileage 93,350 miles
MOT test number 4846 2716 0297
  • Offside Front suspension has excessive play in a lower suspension ball joint (2.5.B.1a)
  • Offside Rear Anti-roll bar has slight play in a pin/bush (2.4.G.2)
Date tested 25 September 2009 Pass
Mileage 85,144 miles
MOT test number 5805 0886 9254
Expiry date 29 September 2010
Date tested 24 September 2009 Fail
Mileage 85,143 miles
MOT test number 1247 3796 9293
  • Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
  • Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
What are failures?
Date tested 30 September 2008 Pass
Mileage 78,408 miles
MOT test number 2632 0437 8252
Expiry date 29 September 2009
Date tested 29 September 2008 Fail
Mileage 78,399 miles
MOT test number 7610 9397 8288
  • Nearside Rear Anti-roll bar linkage has excessive play in a pin/bush (2.4.G.2)
  • Offside Rear Anti-roll bar linkage has excessive play in a pin/bush (2.4.G.2)
What are failures?
Date tested 26 September 2007 Pass
Mileage 72,739 miles
MOT test number 6611 0996 7209
Expiry date 27 September 2008
Date tested 22 September 2006 Pass
Mileage 63,465 miles
MOT test number 4340 8556 6203
Expiry date 27 September 2007
Date tested 28 September 2005 Pass
Mileage 59,333 miles
MOT test number 3218 8167 5201
Expiry date 27 September 2006
Check if SUBARU LEGACY X213BYD has outstanding recalls
No outstanding safety recalls found
There are no outstanding manufacturer's safety recalls for SUBARU LEGACY X213BYD.
There can be a delay before we receive information about safety recalls. If you are concerned, contact your vehicle manufacturer’s dealership.
Was this vehicle recall information useful to you? Tell us your views so we can improve the service.
Since you own an E38, getting an E39 Touring will complement it very nicely. Just out for leaky rear airbags. Get an early (up to 9/98) 6-cyl petrol for the most reliable models.
c725e3936917dfd2ff499e116b710f6907f2b0d0
I'd just posted this in the Ebay thread
£399 - Mazda 626 GLX 2.0 PETROL MANUAL, 1999/V REG, 128000 MILES, SHORT MOT
https://www.ebay.co....bjpBl:rk:1:pf:0
I'd already run the MOT history on this - can't remember why I didn't go for it, think it might have expired. Will double check.
Ran out at the end of September, which shows how long it's been sitting for if the seller is still advertising it as "short mot".
This is where I suggest a Saab 9000...
Comfy, reliable, spacious, about 30mpg in 2.0 flavour....
What’s not to love...
No cheaper ones on eBay at the mo, but there will be...
If tomorrow's collection goes well I may have a 2005 Avensis for sale in 1.8 petrol flavour, FSH with 4 new Nexen all seasons on it, it will be at your max budget though.
I bought some wheels off a Russian bloke with an Avensis. He had the seats down and the loadspace was fucking enormous.
The petrols are belting cars, I'd run away from a diesel though.
You start this thread when I'm stuck writing dissertation stuff at my dad's?
*huffs in Autotrader*
Sent from my GT-I9505 using Tapatalk
It is huge, I can get 2 full sized armchairs in the back of it easily and regularly do!
Your ideal car is my Volvo V70 tdi. It would be even more ideal because I’m looking for an excuse to sell it.
Less ideal is I’ve got no idea no clue what to replace it with and there’s no way I’m walking the 22 miles to work every day
There isn't a great rush to find anything yet - the Rover still works well and has MOT till May
