Zelandeth Posted June 17, 2025 Posted June 17, 2025 4 minutes ago, adw1977 said: Allegedly the budget only stretched to changing one panel for the Vanden Plas version, so they changed the bonnet to allow for the more traditional style grille. That sounds very much like BL thinking. Especially where anything related to the Allegro is concerned! lesapandre and Richard_FM 2
N Dentressangle Posted June 17, 2025 Posted June 17, 2025 coachie, yes oui si, privatewire and 5 others 3 5
adw1977 Posted June 17, 2025 Posted June 17, 2025 1 minute ago, Zelandeth said: That sounds very much like BL thinking. Especially where anything related to the Allegro is concerned! They did seem strangely obsessed with minimising the amount of tooling for body panels, even when that really compromised their designs, e.g. Maxi having to use the 1800's doors, Marina 2 door having to use the front doors of the 4 door. lesapandre and Richard_FM 2
lesapandre Posted June 17, 2025 Posted June 17, 2025 36 minutes ago, adw1977 said: They did seem strangely obsessed with minimising the amount of tooling for body panels, even when that really compromised their designs, e.g. Maxi having to use the 1800's doors, Marina 2 door having to use the front doors of the 4 door. Goes right back to the early days of Austin. I haven't checked - but certainly some of these used the same doors - Devon A40/Hampshire A70; Somerset A40/Hereford A70; I think the Cambridge and Westminster did too. The 3-litre used the 1800 doors and central body tub etc. There was even this Austin Sheerline replacement prototype using Somerset doors. That's quite a beast - pity it never made production. Yoss, adw1977, HMC and 1 other 4
HMC Posted June 17, 2025 Author Posted June 17, 2025 40 minutes ago, wuvvum said: Oh dear. Manual or Mills-o-Matic? Both Baders lesapandre, MorrisItalSLX, yes oui si and 2 others 5
tooSavvy Posted June 17, 2025 Posted June 17, 2025 Why we're all here #popcorn#.... 👍♥️ 🚙💨 privatewire and lesapandre 2
DodgeRover Posted June 17, 2025 Posted June 17, 2025 2 hours ago, HMC said: @LightBulbFun i noticed that too. Wonder whats going on there? At a guess parked up and dropped off the system, reregistered again in 2020 retaining it's original number.
HMC Posted June 17, 2025 Author Posted June 17, 2025 4 hours ago, HMC said: I havent taken any photos, but the white VDP is up on stands, the hoses to the rear displacers have had their connections doused in plus gas. And some second hand replacement hoses have arrived from the hydrogas specialist people. The underside looks really sound, wants a bit of wire brush and por15 or something like that. “better than it looks” definitely applies to this little allegro. They seem to have bred as theres another on its way oh dear! Pass the meds, matron! From the garage update- i changed the split flexi hose and used a £40 hand pump i got off e bay about 7 years ago. Looks like its been made diy in a shed, out of a grease gun. It was partly seized up. Not a good start. After one million hand cranks from zero pressure- one side is now at the regulation ride height. Half way there! Wibble, lesapandre, Dyslexic Viking and 11 others 14
LightBulbFun Posted June 17, 2025 Posted June 17, 2025 3 hours ago, DodgeRover said: 5 hours ago, HMC said: @LightBulbFun i noticed that too. Wonder whats going on there? At a guess parked up and dropped off the system, reregistered again in 2020 retaining it's original number. PFE984P is a modern age relates plate, coupled with the fact that it has an actual date of first registration record of 4th of August 1975, I would say, its an import from either Ireland or one of the channel islands? (its a P suffix car, so it would of been computerised from new, thus there would of been a record in the archives as they say, even if it was laid up the day after it was registered, there would still be a record that could be revived with a V62, so I would not expect a laid up vehicle to have an age related plate like this and separated "date of first registration" & "Date of first registration with the DVLA" listings, thus I dont think its a laid up car situation) tbh I was kinda hoping HMC would know the story to fill in the gaps! tooSavvy, Zie, HMC and 2 others 5
Andyrew Posted June 17, 2025 Posted June 17, 2025 It was previously advertised on here with a dicky gearbox LightBulbFun 1
HMC Posted June 18, 2025 Author Posted June 18, 2025 8 hours ago, Andyrew said: It was previously advertised on here with a dicky gearbox The gearbox shifts happily now (for now at least!) but reverse is a fiddle sometimes. lesapandre, tooSavvy and N Dentressangle 3
Hertz Posted June 18, 2025 Posted June 18, 2025 re the 2020 reg date. Could it be imported from Sothern Ireland or Isle Of Man maybe?
Peter C Posted June 18, 2025 Posted June 18, 2025 Values of these gorgeous cars are going up! lesapandre and HMC 1 1
HMC Posted June 18, 2025 Author Posted June 18, 2025 Swapped the other flexihose over and started with one million cranks needed to pressurise the system on the opposite side with my feeble modified grease gun . Gym membership not necessary. Nothing doing. Had a look underneath and the metal front to back hydraulic pipe is leaking - looks like corrosion. Progress, and a diagnosis. I wonder if these are even available? 2024 photo when it was decomposing on wasteland (looks the same, minus bush and with it listing over to one side) lesapandre and privatewire 2
N Dentressangle Posted June 18, 2025 Posted June 18, 2025 13 minutes ago, HMC said: Swapped the other flexihose over and started with one million cranks needed to pressurise the system on the opposite with my feeble modified grease gun . Nothing doing. Had a look underneath and the metal front to back hydraulic pipe is leaking - looks like corrosion. Progress, and a diagnosis. I wonder if these are even available? These guys will know https://hahsltd.co.uk/about-us/ If you can find out the diameter of the pipework, or just take a piece in, I would think your local hydraulic hose company will be able to make you something up which would do the job. Pirtek are quite pricey, but they have branches everywhere and might be able to sort a piece of pipe and inline couplers out? Another possibility is using MGF / Metro stuff, although that may be metric. The Kennedys will know. High Jetter, cbowditch, lesapandre and 1 other 3 1
SiC Posted June 18, 2025 Posted June 18, 2025 Plumbing copper pipe works well iirc Our resident hydrolastic experts will know more @BeEP @sharley17194 tooSavvy, lesapandre, HMC and 1 other 2 2
tooSavvy Posted June 18, 2025 Posted June 18, 2025 37 minutes ago, SiC said: Plumbing copper pipe works well iirc Our resident hydrolastic experts will know more @BeEP @sharley17194 Good old c/h sorted my Autobox cooler mod... 🔧👍 🚙💨 lesapandre and Stinkwheel 2
BeEP Posted June 18, 2025 Posted June 18, 2025 I think the club still have pipes in stock (we've had them made in small batches) but providing the problem area is easily accessible a bit of 10mm copper pipe and compression fittings works perfectly well, whatever the 'experts'may say! N Dentressangle, lesapandre and HMC 2 1
bezzabsa Posted June 18, 2025 Posted June 18, 2025 nice bit of dead cow & tree .. I can almost smell that interior
Mally Posted June 18, 2025 Posted June 18, 2025 I may* have used brake airline plastic tubing from a now defunct HGV manufacturer. 3/8"/10mm I forget. Anyway it was yellow. High Jetter and tooSavvy 2
flat4alfa Posted June 18, 2025 Posted June 18, 2025 On 17/06/2025 at 19:55, DodgeRover said: At a guess parked up and dropped off the system, reregistered again in 2020 retaining it's original number. I had a Conwy car just like that. Fell off radar, DVLA insisted on a ‘new’ plate issue. Must be something in the water up there
brownnova Posted June 18, 2025 Posted June 18, 2025 2 minutes ago, flat4alfa said: Conwy Twinned with the Bermuda Triangle privatewire 1
HMC Posted June 19, 2025 Author Posted June 19, 2025 Progress! Brakes bled and serviced, Rotten hydragas line section replaced (thanks @BeEP for the inspiration!) tyres checked…. And an exploratory run round the block for a pizza…. Semi-C, Wibble, BeEP and 44 others 43 4
DSdriver Posted June 19, 2025 Posted June 19, 2025 8 minutes ago, HMC said: Progress! Brakes bled and serviced, Rotten hydragas line section replaced (thanks @BeEP for the inspiration!) tyres checked…. And an exploratory run round the block for a pizza…. Pizza shop staff must think you're down on your luck rocking up in that after the mazzer. dome, cbowditch, Wibble and 2 others 1 3 1
High Jetter Posted June 19, 2025 Posted June 19, 2025 Double jeopardy, if it doesn't make it back the pizza will be cold! HMC, Matty and tooSavvy 3
Bear Posted June 19, 2025 Posted June 19, 2025 12 minutes ago, High Jetter said: Double jeopardy, if it doesn't make it back the pizza will be cold! This is why there are picnic tables in the back worldofceri, Matty, Scruffy Bodger and 15 others 5 13
HMC Posted June 19, 2025 Author Posted June 19, 2025 48 minutes ago, High Jetter said: Double jeopardy, if it doesn't make it back the pizza will be cold! Made it back! Shite Ron, adw1977, TrabbieRonnie and 12 others 13 2
