tooSavvy Posted September 9, 2019 Posted September 9, 2019 On 9/4/2019 at 9:18 PM, busmansholiday said: Do they have enough bits for you to be able to build one for us ? I think you are refering to Mk2 Escrotes.....
dollywobbler Posted September 9, 2019 Author Posted September 9, 2019 Oh wow. Have just learned that there is no separate rear washer. Apparently you hold the fronts on until the rear joins in. That's deliciously half-arsed! GrumpyCat, Cavcraft, LightBulbFun and 12 others 8 7
ETCHY Posted September 9, 2019 Posted September 9, 2019 12 minutes ago, dollywobbler said: Oh wow. Have just learned that there is no separate rear washer. Apparently you hold the fronts on until the rear joins in. That's deliciously half-arsed! That's mental, has any other car ever done it that way ? As said earlier, if Rover had sold this at Dacia type prices they may have had a hope. The more I see it though the more I do Iike the looks, it's just a very clean shape. LightBulbFun 1
egg Posted September 9, 2019 Posted September 9, 2019 I think my Fiat Uno had that set up, definitely one car I've owned.
Timewaster Posted September 9, 2019 Posted September 9, 2019 1 hour ago, dollywobbler said: Oh wow. Have just learned that there is no separate rear washer. Apparently you hold the fronts on until the rear joins in. That's deliciously half-arsed! What? Is it actually built like that or is it knackered? I'm thinking some sort of valve that gets overwhelmed and allows water to escape from the other outlet? I remember Rover making a big deal out of the fact that 800 hatchback rear wiper operated if you engage reverse with the front wipers on. Wow! What added value and prestige that £2.99 relay ads to the car. Microwave and Bamboocarman 2
Microwave Posted September 9, 2019 Posted September 9, 2019 2 minutes ago, Timewaster said: I remember Rover making a big deal out of the fact that 800 hatchback rear wiper operated if you engage reverse with the front wipers on. Wow! What added value and prestige that £2.99 relay ads to the car. Until someone told me it was meant to do that, I thought my 800 was just exhibiting the usual electrical issues. beko1987, davehedgehog31, somewhatfoolish and 3 others 3 3
dollywobbler Posted September 9, 2019 Author Posted September 9, 2019 15 minutes ago, Timewaster said: What? Is it actually built like that or is it knackered? How it is. I think it's meant to operate both together, but takes longer to reach the rear. Timewaster 1
Austin-Rover Posted September 9, 2019 Posted September 9, 2019 5 hours ago, dollywobbler said: Â Fog lamp is more mysterious. Pressing the button does nothing... Press and hold in until the little marker light on the switch comes on.
dollywobbler Posted September 9, 2019 Author Posted September 9, 2019 MIND BLOWN. TripleRich, Retr0naut, Shep Shepherd and 19 others 17 5
MorrisItalSLX Posted September 10, 2019 Posted September 10, 2019 My Corolla operates the rear wash in the same fashion, except Toyota also added a wash position in the rear wiper switch, meaning that both front and rear wash buttons do exactly the same thing. Plus you get through about half a litre of screen wash on the front before the rear kicks in as the line drains out afterwards.
dozeydustman Posted September 11, 2019 Posted September 11, 2019 On 9/9/2019 at 4:38 PM, ETCHY said: That's mental, has any other car ever done it that way ? My Samba and Horizon both did that. egg 1
dollywobbler Posted September 13, 2019 Author Posted September 13, 2019 Genuine wheel trims! Sadly, the check engine light is still on (battery disconnected hence bonnet open) so I'm going to have to find someone with a code reader. Or just ignore it. It runs fine... Shep Shepherd, LightBulbFun, Alusilber and 9 others 12
Zelandeth Posted September 13, 2019 Posted September 13, 2019 Worth doing a bit of reading (or wait a bit) I've seen some cars where the check engine light would clear if the car successfully went through a certain number of full start, run, stop cycles without the fault recurring...not saying that's the case here, but it's not impossible.
Noel Tidybeard Posted September 14, 2019 Posted September 14, 2019 On 8/30/2019 at 3:22 PM, EssDeeWon said: I forgot these existed until earlier this year when I passed one on the M25, inside lane doing 40 tops and in light met green. Interested to hear / see more on this beast.  That Picasso would have potentially made some interesting hubnut viewing though. Definitely picked the right car though. If this doesn't end up with Doctor Pandemonium one day then this place isn't what it used to be. no, no, no, we simply MUST NOT let Dr Roverkiller near this little chap ? EssDeeWon 1
garethj Posted September 14, 2019 Posted September 14, 2019 For the rear washers, can you fit a non-return valve in the rear pipe?
dollywobbler Posted September 18, 2019 Author Posted September 18, 2019 By heck it's nice around here. Things I like The styling, especially the arse. The torque. The low waistline - you can actually see out of it! Â Things I dislike The ride - too firm. Stiffened by Rover. The steering - too quick. Quickened by Rover... The terrible wiper design and shambolic column stalks. Â davehedgehog31, RayMK, LightBulbFun and 5 others 8
Lacquer Peel Posted September 18, 2019 Posted September 18, 2019 It might be worth changing the gearbox oil.I am enjoying your enthusiasm for this car, totally unloved even on here. I like it. Next time you go to the continent find a Tata Indica to compare the two. LightBulbFun 1
Zelandeth Posted September 18, 2019 Posted September 18, 2019 Could you swap the springs and dampers from the original car onto it to soften the ride up? Wheels and tyres too potentially? LightBulbFun 1
dozeydustman Posted September 18, 2019 Posted September 18, 2019 As a potential solution to eradicate or at least minimise the triangle of doom, could the wiper arms be rotated a spline or maybe 2 on their spindles? The passenger one will eat into the triangle and the driver's one clear more of the area near the A-pillar. Or even add an inch or 2 to the driver's side blade?
dollywobbler Posted September 19, 2019 Author Posted September 19, 2019 Driver's wiper would go clear off the screen. I reckon you'd need to move the passenger arm at least 30 degrees to make much difference to the doom. I do have a brand new arm, which did leave me wondering whether I should try and reshape the one on the car, but I think it'd just look shit.
chaseracer Posted September 19, 2019 Posted September 19, 2019 12 hours ago, dollywobbler said: ...but I think it'd just look shit. It's a CityRover, Ian... ? timolloyd, adw1977, Mrcento and 4 others 1 6
Andyrew Posted September 20, 2019 Posted September 20, 2019 If you want annoying wipers try a disco 2. I've put disco 2 wipers on my 300tdi and when you clear the screen when the wiper returns the air blowing against the arm causes a little sprinkle of water to go back on the screen right in your line of vision.  Â
dollywobbler Posted September 29, 2019 Author Posted September 29, 2019 After being scared by weather reports, I took the CityRover on the 50-mile Mach Run today. Apparently, you're meant to show your engines off. Mine doesn't have any turbos though. It wasn't a classic car run, just a car run, so absolutely anything was welcome. Mk3 Transit Executive RS! Espero! (19,000 miles from new, was also at the Retro Rides Gathering) Weather did thankfully improve, and it was a nice run out, though the CityRover's tiny fuel tank is annoying. The fuel light comes on after 200 miles, so it's had two fills within a week. As has the 2CV... I reckon I must be getting on for 1000 miles in the CityRover. It's a bonny little thing really. Only had some mild aquaplaning at times today - fresh tyres to be fitted next year if I'm keeping it. LightBulbFun, egg and paulplom 3
Noel Tidybeard Posted September 29, 2019 Posted September 29, 2019 could this be the elusive bumper trim? https://www.ebay.co.uk/itm/GENUINE-MG-ROVER-R-H-BUMPER-INFILL-TRIM-PART-NO-284488506306-FITS-CITY-ROVER/272806176878?hash=item3f8483e86e:g:OMcAAOxyemBR7ldB
dollywobbler Posted September 29, 2019 Author Posted September 29, 2019 Hard to tell in that pathetic excuse for a photo. FFS! No. Rimmer Bros shows that as part of the arch liner.
clayts450 Posted September 29, 2019 Posted September 29, 2019 Stumbled across this on my home server, Ian, dunno if any use ? Offishul workshop manual https://1drv.ms/b/s!AlJQ9M8KH6CWgdYf972Er09ncqWzBw?e=1jWfT8 LightBulbFun, adw1977 and egg 3
dollywobbler Posted September 29, 2019 Author Posted September 29, 2019 Oooh! Thank you. LightBulbFun 1
dollywobbler Posted October 6, 2019 Author Posted October 6, 2019 Did about 300 miles in this today. Conclusions: 45mpg isn't bad, but 200 miles to the fuel light coming on is. I also keep forgetting that the fuel flap release spring is broken, so I have to wedge the lever up. The ride is bloody terrible. Would be very interested to try a Tata Indica without the Rover mods. Over concrete sections, it does not stop bouncing. Awful. The seats, which feel like they should be uncomfortable, somehow are not. Motorways are great. It's pretty peaceful bar some road roar, and you don't have to change gear. Bonus! The gearchange still sounds horrendous. The indicator stalk makes a 2CV one feel as robust as that in a W123. It's pathetically shit. The wipers are out in the breeze, so wash the windscreen at speed and they dribble screenwash over the screen for the next five miles. Operate the washers at slower speeds and the triangle of doom effect takes over. The huge windows and mirrors mean visibility is excellent. LightBulbFun, paulplom, BL Bloke and 3 others 6
Fumbler Posted October 6, 2019 Posted October 6, 2019 How complicated would it be to undo the Rover suspension stuff? Was wondering if they decided to stiffen the shocks or springs and if it would be possible to replace them. LightBulbFun 1
