Horrible things these, but possibly cheap enough to make it viable for some badge-blinded VAG snob
VW Golf mk3 gti 2.0 16v - Picture 1 of 24
VW Golf mk3 gti 2.0 16v | eBay
2003 MG TF 1.8 Blue 72000 miles - Picture 1 of 1
2003 MG TF 1.8 Blue 72000 miles | eBay
Just in case anyone else accidentally* Googles the reg number, that's a topless Tracy Shaw driving.
Cheap* Bentley 8 in St Albans
That taxi is amazing, plus the chances of getting boarded by Customs on the Manchester Bolton & Bury canal with all that weed in the engine bay must be incredibly slim.
7 hours ago, Cavcraft said:
Sprite Major RL Touring Caravan. New Tyres.  - Picture 6 of 9
Sprite Major RL Touring Caravan. New Tyres. | eBay
Back in the day, every other caravan seemed to be one of these, usually being towed by an Austin/Morris 1800/2200.
My parents had a Sprite of similar vintage. Upon trying to move it , it folded flat with the wooden frame completely rotted at each corner. We dismantled it into a skip.  The chassis was fairly solid and needed an angle grinder to cut it up.
Vanstation have been magnet fishing again
1981 Mercedes 2.5L MWB Panel Van Low Miles 56k Long MOT Starts Drives Perfect - Picture 4 of 22
1981 Mercedes 2.5L MWB Panel Van Low Miles 56k Long MOT Starts Drives Perfect | eBay
'It Has Never Failed An Mot'
Date tested
22 June 2010
FAIL
Mileage
50,998 miles
Test location
View test location
MOT test number
9121 9367 0192
Reason(s) for failure
  • Nearside Front Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
  • Offside Front Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
  • Nearside Rear Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
But Besides That Apart From It GIF - But Besides That Apart From It Except  - Discover & Share GIFs
Date tested
21 June 2011
FAIL
Mileage
53,073 miles
Test location
View test location
MOT test number
2966 8247 1403
  • Service brake: efficiency below requirements (3.7.B.7)
  • Offside rear brake recording little or no effort (3.7.B.5a)
  • What Else Is Going On Tell Me GIF - What Else Is Going On Tell Me Whats Up  - Discover & Share GIFs
'It has never failed an MOT'
Date tested
19 June 2013
FAIL
Mileage
53,540 miles
Test location
View test location
MOT test number
3994 1017 3106
  • Rear Exhaust system not adequately supported (7.1.1)
  • Front Exhaust system not adequately supported (7.1.1)
  • Hazard warning lamps inoperative (1.4.B.1b)
Advisory notice item(s)
I Would Love To Know Tell Me More GIF - I Would Love To Know Tell Me More  Curious - Discover & Share GIFs
Date tested
9 June 2017
FAIL
Mileage
54,123 miles
Test location
View test location
MOT test number
2674 6328 7942
  • Nearside front brake binding (3.7.B.1)
  • Offside front brake binding (3.7.B.1)
  • Nearside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
  • Offside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
  • Nearside Front Brake hose has slight corrosion to ferrules (3.6.B.4e)
  • Offside Front Brake hose has slight corrosion to ferrules (3.6.B.4e)
  • Central Rear Brake hose has slight corrosion to ferrules (3.6.B.4e)
  • Nearside Rear Body has slight corrosion inner sill (6.1.B.2)
  • Offfside Front Body has slight corrosion step (6.1.B.2)
  • Do The Work Work It GIF - Do The Work Work It Do It - Discover & Share GIFs
Date tested
19 June 2020
FAIL
Mileage
55,512 miles
Test location
View test location
MOT test number
1316 9728 6137
  • Rear fog lamp missing (4.5.1 (a) (ii))
  • Slight bodywork corrosion
  • Front Prop shaft bearing has slight play Slight play in front UJ (6.1.7 (b) (i))
  • Brake hose has slight corrosion to ferrule (1.1.12 (f) (i))
  • Front Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
Get It Of Your Life Put It Aside GIF - Get It Of Your Life Put It Aside Put  Away - Discover & Share GIFs
