HMC Comings (sherpa) and goings (morris)
On 21/04/2024 at 22:06, HMC said:
I thought this would be Portuguese made ( like the shed of a galaxy currently on the fleet), but the Vin plate suggests Germany (Cologne?) Any recommendations for a Ford vin decoder?
Galaxy’s were made in a new factory (1990s) shared with VW Group. Ford never built cars in Portugal on their own.
Escort news.
Its never run right basically.  I was told it “likes a lot of choke” which basically meant its hard to start, bogs down, isnt happy idling and when it warms up it gets worse.
Turns out after i broke out my strobe light the ignition timing was so far out as to be unbelievable it would run. Anyway whilst messing with that i decided to fit an accuspark electonic ignition into the existing distributor and a new coil. Starts and goes even better now!
40 minutes ago, HMC said:
Escort news.
Electronic ignition is one of those things all old cars benefit from imho these days. I’ve fitted it to both my Capri and the Mercury and it makes a big difference.
Points and condenser was a decent enough solution to the job in the day but it was always an achilles heel on old stuff. Prone to cold and damp, wears and needs resetting and of course nowadays humanity seems to have lost the ability to manufacture decent quality condensers that actually work!
Since fitting mine I’ve done absolutely nothing whatsoever to them. Though I do still keep the old pars in a box in the boot just in case.
Escort’s looking absolutely brilliant btw!
The mk2 Escort imo was one of those cars that really needed decent wheels on it. Get the right wheels & it transformed it. See one on crap wheels & maybe more than many cars it just kills the looks somehow.
Yours looks good.
Yours looks good.
 Cheers!
just collecting an indian in it
My Triumph was on Luminition electronic ignition for about 15 years but did start getting harder to start until one day approaching a major roundabout in Southampton it just died. Fortunately Mrs Yoss was with me so we were able to push it up on to the grass. A quick check said we had no spark.
Now for that entire 15 years I had a spare distributor with points and condenser set up ready to go, wrapped in a carrier bag and stowed under the boot floor along with many other spares (it's surprising how much stuff you can pack in and around the spare wheel). So I quickly fitted that and it fired first time. That was about five years ago and I keep thinking about going back to electronic ignition but have never quite got round to it. So the points and condenser are now at least 20 years old and still going strong. They are probably so old that they were not made in China.
I still think about going back to electronic ignition but other jobs always seem to come along first. There certainly doesn't seem any point replacing the points and condenser I have now because they will be cheap Chineseum.
2 hours ago, HMC said:
Escort news.
The accuspark that was on my beetle when I got it failed and I’ve heard of a few others who had issues with it.
I replaced it with a Pertronix which has been excellent for the last year or so.
I'm still on points and condensor. However even buying Distributor Doctor parts, I've got through a few condensors. I'm very much on the fence about going electronic though as it seems a 50/50 split of opinion in the old car world.
If I were to go for it I'd be going for a full Aldon dizzy I reckon. Bit strong at a couple of hundred but I can always save up 😄
I think tbh, that’s the crux of it! Chinese cheap crap. If they were made to a quality things might be different but unfortunately they’re not.
On the Mercury I had a hell of a job getting it to run or run right on the points. I bought a couple of condenser’s new from different companies. One was dead straight out the box and the other worked ok-ish for a while then that failed. In the end I went through quite a few condenser’s before finding a decent one.
The crap ones were all made in China, India and somewhere else similar. The original one that worked still but was clearly ancient and the wire was all corroded was made in USA and the good new one I got in the end was Mexico. I got fed up in the end so fitted Pertronix electronic and it’s been perfect ever since.
If your old points set up is working fine now then your probably best off leaving it as is. The old working parts will be far better quality than the modern rubbish you get to replace it with. Maybe if it ever does fail then consider electronic ignition then?
The old service interval for changing points & condenser every 6k or 6 months is a great idea… back in the days you could get quality parts! Now however… not so much. If it ain’t broke don’t fix it springs to mind.
Electronic ignition isn’t a 100% solution either though. It’s generally more reliable and easier to maintain but it’s still a bunch of electronic components that can and do sometimes fail. Touch wood I’ve not had that happen yet though.
Why is it that automotive ignition condensers are now so bad, while modern electronic condensers generally have become supremely reliable?
Probably, like most things, they’re built much more to a price than a quality.
Didnt @SiC do some testing with them on his MG thread? I can’t remember what the outcome was though…
The thing is though that the electronic components are not expensive, and are basically exactly the same thing.   Lack of joined-up thinking somewhere.
  • Agree 1
I have a Gammatronix box on the Panda, it keeps the points but removes the condenser and just uses the points as a low current switch so has the benefit of not burning out the points or worrying about shite condensers, and if it fails you just need to plug the condenser back in. They are about £30
True, but if you consider the kit for a Pertronix electronic ignition is roughly £100 - £150ish vehicle depending. Not cheap, but I think it’s one of those times where you get what you pay for.
You could get a much cheaper electronic kit, but if it’s cheap then it’s probably made with cheap components which means it might be more prone to failure?
Then consider a new Chinesium condenser is a couple of quid… they’ll just be the absolute cheapest internals you can find thrown together as quickly as possible and slung out the factory doors by the thousands. They probably know damn well a high percentage of them will not last long or work at all but that’s the cost of consumers demanding the cheapest price.
Personally, I’d gladly pay significantly higher prices for a quality product made in GB or the USA but unfortunately that doesn’t seem an option anymore. And I’d probably be in a minority with that mindset too!😄
  • Agree 2
2 hours ago, Mr Pastry said:
... while modern electronic condensers generally have become supremely reliable?
They really haven't.  As someone who regularly finds himself fixing people's broken bits of electronics, whether it be a £20 kids toy or a £5000 high end TV, unless it's something that has physically been broken the problem will at least 95% of the time be down to failed capacitors.
The ones used on a points ignition system are a pretty specialised type as well as they need to stand up to a very high voltage gradient.  If you've ever been buying high voltage caps (which if you work on valve era tech you will), you'll find that they're annoyingly expensive compared to the more pedestrian ratings.  They're also nowhere near as widely available.
Aside from the pretty hard life they live electrically, the environment is tough given the huge temperature and humidity swings you're going to see in an engine bay.
What you really want for this application is a proper hermetically sealed polypropylene film capacitor.  However what you generally get when buying automotive ones is a really cheaply made wax paper type.  These were never particularly reliable even in their day, being prone to absorbing moisture which causes them to become electrically leaky over time.  However when they were £0.50 and were replaced every year or two as a service part that wasn't the end of the day.  Now being made even MORE cheaply as everything these days is a race to the bottom and/or stored in unknown conditions for how long, it's no wonder they're woeful.
If you don't want to go to the expense or complexity of switching to an electronic system, just fitting a good quality condenser external to the distributor will probably go a long way to making things more reliable.
That's exactly the point.  I don't get why everybody doesn't just do that, and suitable types would have been identified.
I don't actually remember many condenser failures back in the day on the stuff that I serviced, and certainly didn't think of them as being unreliable.   It was mostly Bosch and Marelli rather than Lucas so maybe I was just lucky.
I have Lumenition on the 2CV which gives no trouble and seems to be a good quality product, but it's more because of poor access to the points than anything else.
Galaxy update
Its been brilliant! its got the 2.3 4 cyl petrol unit fitted, which apparently is related to the ford scorpio twin cam and not the zetec. By this facelift it was the entry level engine, and it has the “zetec” trim level, just to confuse matters!
It goes quite well, its pretty torquey and feels quite well suited to the car.
It has an essex registration and a few clues to its past. I was suprised it had most ofnits original paperwork, book pack etc and the number plates and screen sticker suggest it was a ford company vehicle, and then sold through “ford direct” whatever that was.
Anyway, that was a long time ago in this cars 22 year old life…..
But being a bit rough and ready makes it so practical- van, car, skip, dog transport. Its already ruined so its the ultimate usable all rounder.
I had a Transit with that engine - they are indeed an updated version of the older twin cam.  That van went like the clappers but bugger me did it like a drink!
2000s fords Group shot- cheap bangers
1970s ford- not so cheap banger
theme: BANGERS
I have to admit as non-native the Galaxy is more interesting to me than the Escort ha.
9 hours ago, HMC said:
Galaxy update
The supervisors and managers at Ford can lease cars , when they have done a certain mileage  they give them back and lease another, the returned cars were then sold via Dagenham motors as Ford direct. I can't remember if they were only available to Ford employees or to the public but Ford employees definitely could access a list of the stock available at the time
I think the Ford Direct might have also been the name for any Ford approved vehicle but with the Ford motor company plates and Essex reg its almost certainly an ex management lease
Thing I always remember about MK2 escorts is the loud clock tick. I remember being left in the car as a kid as my parents did something ridiculously boring in a garden centre and I preferred to sit in the car and listened to that tick...wondering why it took so long to buy a growbag.
10 minutes ago, egg said:
Thing I always remember about MK2 escorts is the loud clock tick. I remember being left in the car as a kid as my parents did something ridiculously boring in a garden centre and I preferred to sit in the car and listed to that tick...wondering why it took so long to buy a growbag.
Pampas grass and upside down 🍍
10 hours ago, HMC said:
Galaxy update
Zetec trim is strange.. minus tractor powered... does ur rear heater still work?
theme: BANGERS
Love a pair of Bangers 🤡
@egg  @danthecapriman do you know what the original tyre size would be for the dartboard wheels? im tempted to go oem on this as theres a lot of wannabe works escorts and not so many standard cars about.
Soz I don't - @bunglebusmight?
185/70/13T is what I’ve got. From what I could find out that’s the standard size. Although mine are the 5.5’’  dartboard rim. There’s also a 5’’ version.
