All I see is excuses!
Pretty much. I shall not hide the fact that I'd rather use a car with an overdrive gear! I don't really mind driving it long distances but it's too low geared to be economical or sound happy on motorways where even lorries will outpace you!
How much of that is only true because of its utterly horlixed engine though?
60mph on the motorway is still 3,800rpm in top even with a healthy engine, the car is more suited to twisty B roads and darting about town. Besides, driving it for over an hour or two gives me a sore back. :P
My old 1850HL would've been a far better choice for the trip if it were still on the go, 60mph is still 3,300rpm in top but I used to get 38-40mpg on long runs as it had the torque to make holding a constant speed effortless. The driver's seat was also much less collapsed...
Flying would be far easier, faster and cheaper but ultimately I reckon I'd feel like a bit of a ponce for not driving there in something at least 30 years old...
Now I feel bad for thrapping Reliants up and down the motorway at 65-70,which I think was around 4800rpm...
The long haul in the Dolly would be heroic - going for it in the Acclaim - insane and optimistic - flying down and rolling up in Sic's BGT - helpful, courteous and giving the hard working chod a rest.....
Obviously MPG can be vastly improved by doing a fair chunk of the journey on the back of the old big yellow bus :-D
Replacement seat diaphragms are pretty cheap.
I seem to remember Dave Numbers using tie-down-straps as a makeshift repair on a seat base to replace broken webbing. Maybe he used cheapie ratchet-type straps.
Amazon do these pull-through-&-lock type, £2.10p for the pair.
Pirelli seat webbing was the other widely used material. Still available.
The last time the Doloshite's engine touched 4,000rpm it dismantled itself in protest. A decent engine may change my opinions in fairness...
With regards the seat, the base isn't all that bad aside from being a bit flatter than it probably should be. The issue is the back rest, there is a steel bar which runs up to support the headrest which digs into my back, presumably the padding has disintegrated over time. Probably a simple enough fix I've just never been arsed as I very rarely drive the car for more than an hour or two at a time...
I seem to have agreed to collect a Triumph Herald 1200cc OHV engine, sight unseen, advertised on Gumtree last night.
The good news is that it's free and only a few miles away. The bad is that I have no idea if a 1200 Herald engine will actually mate up to the Doloshite's gearbox, but it was free. So fuck it.
Memory foam from an old mattress and a coal sack over the seat back. Luxurious poverty!
Dolomite 1300
This unit provides power and torque figures of 58 bhp (59 PS/43 kW) at 5500 rpm and 92 Nm (68 lbft/9.4 kgm) at 3300 rpm respectively.
Herald 1200
Claimed maximum power of the Herald 1200 was 39 bhp (29 kW), as against the 34.5 bhp (25.7 kW) claimed for the 948 cc model.
But then free and I guess the dollys original engine could have been putting that out around that at the end of its life.
According to the seller it's a high compression engine, presumably from a 12/50, so it should be more around the 50bhp figure.
That could, of course, be bullshit. But yeah, I doubt the old motor was generating anything near 58bhp by the time I owned it...
...60mph on the motorway is still 3,800rpm in top....
:shock:  - that is a lot of revs to be buzzing in your eardrums. I thought the CX was a bit high at 2700rpm (60mph), but 3800 is a lot  :shock:  :shock:  .
Out of interest, what is the final drive ratio on the Doloshite - is there no taller final drive available?
You could fit a diff from a 1500/1850 to improve rpm at motorway speeds but you can't really afford to loose the acceleration... O/D Spitfire gearbox would be nice but they command decent money as Spitfire owners all want one.
Even the Acclaim with it's 5th gear is doing 3,000rpm at 60mph, exactly the same as my '05 Civic!
This free engine can only go well. If it fits in the dolly, tremendous, a working engine is better than a dead one. If it doesn’t fit, no problem, sell it on and top up the piggy bank.
That’s a win-win in my books.
All I can think of in a constructive manner is that you are in a similar situation as dollywobbler with the Fox. Same engine, different car, so there may be differences between the engines but you have the original to swap parts over so it all comes together nicely.
Crack on I say!
Hopefully the knackered engine will yield parts to make it fit. Iirc someone on here offered ramp or storage space for you to do it? Might be worth taking it up as if it's not a straight swap, it could be a couple of days job.
I can't remember if the Herald/Dolomite gearboxes are a straight swap but the engine backplates are easy enough to swap over. The front plate will probably need swapping too as that has the engine mounts on. That's a bit more hassle as it sits between the block and timing chain cover but still pretty simple.
If it won't fit you could run it 'on the bench' to assess its condition, if it sounds good with no smoke clean it up, paint it and flog it on for a tidy sum. All within your capability.
If you do this ^^, make sure you have the camera filming so we can all see your grumpy neighbors reaction to an engine being run out on the street with no silencer!
This is my thinking. The thing is 6 miles away so I can't really lose*.
I do like the concept of firing up an engine on the pavement outside my flat...
Several local Shitters offered help with transport and the esteemed Mr 320Touring will be aiding my engine collecshiun by way of veg powered Germanic steel. (Shame it's nae the Oxford tho).
  • Like 8
Don't poke the rust.
OH FUCKING SHIT STICKS. I WENT AND POKED THE RUST.
Suspicions of Bodge It and Scarper Ltd quality repairs confirmed. Waste of a decent repair panel, that.
The original arch hidden underneath still had giffer touch-ups in the wrong shade of green. Was probably half decent prior to the "repair"... TDC do panels to cover the area affected so it's aaaaall good*
Wow that arch looks totally fucking fucked m8.
You need to get this car fixed asap. If you don't, the lack of driving it will mean more poking of it. More poking of it means more incidents like that.
I had a similar experience this afternoon with my Triumph.
Wished I'd just left it well alone.
I fucked it off and will sleep on it before I look at it again tomorrow.
  • Like 7
That's some 24ct bodgery there.
The other side is the same deal but looks less shit and is already partially repaired so I'll pretend it doesn't exist for now. The current range of TDC panels cover this area:
Which is pretty much what I need. The yellow panel is £60 and I only need the leading edge so I may try and fabricate something to fit instead... Will likely also need some extra metal for the area above the arch lip which the red panel will cover but it's a simple enough shape. The inner seems comparatively decent. I'd say the end result of peeling that repair panel off is actually slightly better than I thought it'd be in that there is actually still some metal there!
Oh no.
You poked the rust.
It's all YOUR fault.
(Ahh well, it had to be done. At least it's not a major repair).
