purplebargeken Posted May 9 Author Share Posted May 9 Can ignore the EML now but can’t ignore the transfer of oil from the engine to the front of the car, including the hot manifold. Will try the fuel cap again tomorrow. bunglebus 1 Link to comment Share on other sites More sharing options...
purplebargeken Posted May 9 Author Share Posted May 9 Rest of it is faffing about stuff but have lost patience and enthusiasm for it totally. Link to comment Share on other sites More sharing options...
Sigmund Fraud Posted May 9 Share Posted May 9 A service is always worthwhile, I presume yours has a coil pack rather than a coil and distributor ? Make sure you use the correct PAS fluid, those should use green CHF. Oil leaks from the top are usually the rocker cover gasket. Liberal application of Reizosil with a new gasket, and replacing the stupid rocker cover bolts should fix it. @bunglebus is correct about the fuel cap. If it spins it's locked, and they can be temperamental. I'd normally replace them with a non-locking version. bunglebus 1 Link to comment Share on other sites More sharing options...
purplebargeken Posted May 9 Author Share Posted May 9 I imagine it is a coil pack one. Aye, same as my T4, I have a bottle of it here. Cheers re rocker cover tips 😊 Will look at it again tomorrow but the non-locking option appeals hugely. Link to comment Share on other sites More sharing options...
purplebargeken Posted May 10 Author Share Posted May 10 Yep, rocker cover fucked, looks like it’s been a tad bodged previously and likely just unfortunate timing. Febi temp sensor arrived and fitted in a matter of seconds, no more dribble, phew. Sony Xplode Radio and CD player fitted. Loopoo dislike reduced by 12.7 percent. chodweaver, bunglebus, Keymaster and 2 others 5 Link to comment Share on other sites More sharing options...
purplebargeken Posted May 12 Author Share Posted May 12 Non-locking fuel cap has landed, can not be arsed with faffing around with a temperamental locking fuel cap. Found 4 or 5 spare dodo hex sound deadening mat. Will fling this at the underside of the bonnet as it’s just metal. Why not, it was just lying around. Keymaster 1 Link to comment Share on other sites More sharing options...
purplebargeken Posted May 14 Author Share Posted May 14 Sound deadening mat applied. Can’t tell you if it makes it any quieter as oil pisses out of it when running. Getting that sorted on Friday afternoon along with the recurring EML light. bunglebus 1 Link to comment Share on other sites More sharing options...
Sigmund Fraud Posted Tuesday at 21:29 Share Posted Tuesday at 21:29 Some Lupos came with underbonnet sound insulation as standard. I had retrofitted it to Mrs F's car, but it was still deafening at 70 due to the gear ratios of the 1-litre box. I chose the rather more involved option of installing the 1.4-litre box to quieten my own Lupo down. It worked brilliantly. bunglebus and EyesWeldedShut 1 1 Link to comment Share on other sites More sharing options...
purplebargeken Posted Wednesday at 06:23 Author Share Posted Wednesday at 06:23 Hopefully it will take the edge off it, anything motorway will be the T4 or the Jag lol. Link to comment Share on other sites More sharing options...
bunglebus Posted Wednesday at 06:53 Share Posted Wednesday at 06:53 Fair play to you trying to make it 100% right. Seems a lot of Lupos have the EML on, I need to fit a lambda spacer to ours to try and stop it coming on regularly Link to comment Share on other sites More sharing options...
purplebargeken Posted Wednesday at 06:57 Author Share Posted Wednesday at 06:57 Well I have it now and have sunk money into it, so may as well plod on. It will be fine once sorted but has cost me a fair few quid. There were probably better cars out there for the money, such is the AS way tho. Link to comment Share on other sites More sharing options...
fatharris Posted Wednesday at 06:57 Share Posted Wednesday at 06:57 Cripes, you've not been having much luck with it - hopefully the new rocker cover will signal the end of your woes. Link to comment Share on other sites More sharing options...
bunglebus Posted Wednesday at 07:03 Share Posted Wednesday at 07:03 They are good cars but probably just suffering from the attitude of cheap car so don't bother maintaining it unless it won't move/fails MoT purplebargeken and Sigmund Fraud 1 1 Link to comment Share on other sites More sharing options...
purplebargeken Posted Wednesday at 10:38 Author Share Posted Wednesday at 10:38 Yeah, am hopeful as it is pretty much pissing out, being somewhat overfilled didn’t help. Will have an oil and filter change when the gasket is sorted. Have Pela pumped some oil out to a normal level too. Link to comment Share on other sites More sharing options...
purplebargeken Posted Wednesday at 10:40 Author Share Posted Wednesday at 10:40 Yeah, agreed. At least the body is solid. Poor maintenance and a minging interior. Would have enjoyed the challenge a few years ago, much less now tbh. Link to comment Share on other sites More sharing options...
purplebargeken Posted 19 hours ago Author Share Posted 19 hours ago Ffs, booked a mobile mechanic to come and do the rocker cover gasket and check the EML light, twice he couldn’t be arsed turning up. Well fuck you. Will do the gasket myself but there is a bewildering choice on eBay and the fb Lupo group can’t be arsed responding to my posts. Which fecking gasket do I go for and what do I replace the shit VW rocker cover bolts with?? Link to comment Share on other sites More sharing options...
Sigmund Fraud Posted 17 hours ago Share Posted 17 hours ago For the gasket, I think all UK-spec 1-litre models use the same one. Don't take my word for it, though ; search the Reinz online catalogue with your engine code. As mentioned earlier, ignore what the VW workshop manual says and put a thin smear of sealant everywhere. Stupid bolts are dealership-only, and £OUCH. I wouldn't substitute them with high-tensile bolts, as they won't clamp the rocker cover correctly, and you'll inevitably torque them up too much and bugger the threads (which go into the camshaft bearing caps - i.e. not something you want to be replacing). bunglebus and purplebargeken 2 Link to comment Share on other sites More sharing options...
Forty45 Posted 10 hours ago Share Posted 10 hours ago Ours decided to put the EML on after an oil change for some reason. It then went off but would return on random occasions. Could be a connection got knocked when changing the oil filter? Changing the fuel filter was worthwhile while for "performance". It's not that difficult to do - disable the fuel pump, jack up rear of car, remove filter near rear wheel, replace. purplebargeken 1 Link to comment Share on other sites More sharing options...
