46 minutes ago, Shite Ron said:
4 and 5 speed slushboxes are modern. Real cars have 3 speed slushboxes. I generally prefer a manual but have a few automatics, they are generally much cheaper to buy and give a different but not unpleasant driving experience when you are used to them. Also automatics are usually much cheaper to buy secondhand.
Try an old Vauxhall Powerglide, just two forward gears.
I think the early Suzuki Alto only had a two speed box!
11 hours ago, New POD said:
What's not to like ? It's a manual.   Real luxury does not involve using ones hands and feet to change gear.
Absolutely.
9 hours ago, jamiechod said:
id rather make my own gear choices than some archaic 90s tech slush box to eventually select a cog and charge me extra in fuel for doing so ;)
Calling the 90s archaic is making me feel old. My 90s stuff is the height of modernity to me.
That's more like it. My idea of modern is having a Borg Warner 65 instead of a 35.
1 hour ago, New POD said:
Are the 8 speed autos done with 8 different gears or is it a CVT with programmed steps (like the 54 plate 6 speed A200 turbo I test drove with CVT last year * fecking ace car but gearboxes are chocolate so didn't buy)
The ZF 8 speed are separate gears and a proper slush box. Ford and GM have teamed up to make a slush 10spd auto. Used on Mustang, F150 and others.  Most manufacturers have given up on CVT as it seems hard to make them long term reliable.
These modern slush gearboxes can select any ratio and not need to shift them in order.
Computer controlled 5 speed boxes are tolerable. Newer it is, the more advanced and way superior driving experience they give. Even shitter as they age though when they go wrong and no one ever maintains a auto gearbox over here properly.
I've not been in or driven a mechanical auto gearbox that has been good. Either they sliiiip into gear for smoothness or they bang in to gear for speed. As there is no computer orchestrating proceedings, they almost always can't change between their behaviours.
As I say, I have an auto myself, I prefer one with 8 cogs rather than 4 or 5? I've given the reason why, reaction times are, in my opinion, abysmal. The e46 tiptromic I had recently it felt like an age before it kicked down and could overtake safely. My car you can literally tap the throttle and its offf, and it's only a 2.0 diesel.
3 hours ago, New POD said:
You should try a mk2 cavalier 3 speed auto.  Preferably with a smaller engine.
I had a 1.8 Cdi Auto given to me free in 2004 and the gap between 2nd and top was so large it was full of illegal migrants attempting a crossing in stolen fishing boats.
Wish I'd kept* that car.
It's an 8 speed slush box effectively so 8 seperate cogs.
I think the only other auto I have had an affinity with is the dsg Vag unit but as you put, they are chocolate so would be frightened to death of owning one.
2 hours ago, Yoss said:
Absolutely.
I was 8 when the auto box in an S type was released so I've seen them come on quite a bit in a short time 😅
The ZF 8 speed is the most amazing thing, I’ve only driven 2 cars fitted with it , both have over 600 bhp , but the way it will kick down 4 gears and launch past dawdlers, is instantaneous and doesn’t feel like something mechanical happened , just one minute you’re doing 50 then a few seconds later , double that , without feeling a single change. The rev counter  would probably give it away, but to be honest I’m usually too busy to look down!
When I get back behind the wheel of one of my archaic Merc 7 speeders it feels like a BW35 ( low on fluid) . It should last forever in a 420d .
To show my age I remember 2 speed Powerglides too, my Dad had a Viscount when I was 10, and I had a 67 Impala that I ever even noticed was only 2 speed, it was when I sold it the new owner mentioned it.
The first 5 speed auto I drove , I managed to drive 100 miles on the day it was delivered new with top locked out, it was a W124 300e 24 and I’d knocked the lever to the left. I read the manual that night.
When I first got the ex-Bramz Buick Park Avenue, it was stuck in third so was effectively a single-speed auto.  I drove it 100 miles like that and it was perfectly adequate, although pulling out onto busy roundabouts required careful timing.
55 minutes ago, sdkrc said:
This is groundbreakingly shit in all the right ways
bid up to £430, that's quite surprising!
My Saab 900 is a 3 speed BW35 and I’ve done many miles in that. It’s a bit revvy on the motorways and not the most economical because of the lack of lockup, but around town the way it slurs along is utterly delightful.
That Mondeo looks like it's been prepped for the oval, which is the best things for them.
Ps: @wuvvum I was winning the listing for that taxi but bottled out of a bigger offer when I got outbid. I think it finished at about £190.
9 hours ago, Asimo said:
cramped, gloomy, sweaty, whiff of coolant / fags / air freshener
Have you been to my house?
3 minutes ago, bogeyhead said:
Passengers please enter by the red door.
a FWD mondeo with a mismatched passenger door, no wheel trims, no interior pics or a RWD jaaaaaaaaaaaaag with a manual box and full cow, (nothing in description RE coolant leaks/fag smells  so bizzare comments) for £25 extra,
#autoshite
8 minutes ago, TheDoctor said:
https://m.facebook.com/groups/196144481494131?view=permalink&id=349535439488367
I don't need another old red Rover with lacquer peel.
Screenshot_20201027_203206_com.android.chrome.thumb.jpg.9cb6096ba15f84614b9cccac7c10bef1.jpg
EVERYBODY needs more red Rovers with lacquer peel. Even if you've already got some. #truefacts
