https://www.ebay.co.uk/itm/1986-Toyota-Camry-2-0-TURBO-DIESEL-saloon-very-rare-hard-to-find/163066034059
Diesel!
Refusal Notices
  • Rear parking (secondary) brakes imbalanced 37% (3.7.b.6b)
  • Nearside rear rear position lamp(s) adversely affected by the operation of another lamp efected by stop lamp (1.1.a.3f)
  • Front windscreen wiper does not clear the windscreen effectively both (8.2.2)
  • Battery insecure (1.9.1)
  • Nearside rear vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings inner & outer sill area (6.1.b.2)
  • Offside rear vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings inner & outer sill area (6.1.b.2)
  • Nearside rear vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings iner flich area (6.1.b.2)
  • Offside rear vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings inner flich area (6.1.b.2)
  • Offside rear vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings above rear silencer marked with yellow chack (6.1.b.2)
  • Nearside rear vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings inner flich area around shocker (6.1.b.2)
  • Offside rear vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings flich area around shocker (6.1.b.2)
  • Nearside rear vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings inner flich behind mud flap (6.1.b.2)
  • Nearside rear seat belt anchorage prescribed area is excessively corroded inner flich (5.2.6)
  • Offside rear seat belt anchorage prescribed area is excessively corroded inner flich (5.2.6)
  • Nearside rear brake pipe excessively corroded (3.6.b.2c)
  • Offside rear brake pipe excessively corroded (3.6.b.2c)
  • Front brake disc in such a condition that it is seriously weakened both sides (3.5.1i)
  • Nearside rear outer anti-roll bar has excessive play in a pin/bush (2.4.g.2)
  • Offside rear outer anti-roll bar has excessive play in a pin/bush (2.4.g.2)
  • Front brakes imbalanced across an axle 47% (3.7.b.5b)
  • Nearside rear vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings tow bar moit area (6.1.b.2)
  • Trailer electrical socket (13 pin) not operating the trailer lamps as intended no lamp working on the socket (1.9.4)
Advisory Notices
  • Rear brakes imbalanced requirements only just met. it would appear that the braking system requires adjustment or repair. 24% service brake (3.7.b.5b)
  • Nearside front side light lens damaged
  • Nearside rear vehicle structure has slight corrosion wheel arch (6.1.b.2)
  • Nearside front brake hose slightly deteriorated (3.6.b.4d)
  • Offside front brake hose slightly deteriorated (3.6.b.4d)
  • Offside rear brake hose slightly deteriorated both (3.6.b.4d)
  • Nearside rear brake hose slightly deteriorated both (3.6.b.4d)
  • Rear anti-roll bar rubber bush deteriorated but not resulting in excessive movement (2.4.g.2)
  • Rear anti-roll bar corroded but not seriously weakened (2.4.g.1)
  • Front shock absorber has slight corrosion to the casing both (2.7.2a)
  • Rear shock absorber has slight corrosion to the casing both (2.7.2a)
  • Fuel pipe/s corroded filler neck & others ()
  • All four tyre detireorated (perished)
  • Front coil spring corroded both (2.4.c.1b)
  • Rear coil spring corroded both (2.4.c.1b)
  • Rear crossmember and suspention arms
IT'S FUCKED
Wouldn't be surprised if the moss gathered as it was being driven along
https://www.ebay.co.uk/itm/mercedes-307d-flatbed-spares-or-repairs/153041054525?hash=item23a1f52b3d:g:LOgAAOSwvjBbDSkp
...in that thing. I'd rather fight Mike Tyson and twenty five crocodiles than drive that that distance.
  • Like 6
Just kick it straight..
A Jaguar XJC should never have ended up like this.  Sad really.
Fancy appearing a little bit different when trundling to work in the morning?
Land rover series 2a
not one for the purists out there so no stupid messages
it was put on a range Rover classic chassis cut down to 88 inch
200tdi engine and box in from a discover 1 about 5 year ago
Go and fuck something much more unpleasant than a duck. It is not remotely a Land Rover Series IIa.
https://www.ebay.co.uk/itm/Land-rover-series-2a/113005165127
I remember seeing this about in Alton a lot a few years back.
Don't quite understand sellers logic though. No bids last time round, so list again from same start price?
Yeah, quite unusual. Usually they get listed with a higher start price.
Terrible coloured PV544
The seats too?
And the dash? How dreary. Needs bumpers and repainted into an actual colour. s-l1600.jpg
You mean like this that my mate used to own- :-D
What a deluded twat, he makes a big point about it being mot and tax exempt then mentions that it just happens to be a '39 body chucked on a '94 mazda truck chassis. If he is lucky it might keep the Mazda ID but it should be on a Q plate and no longer tax or test exempt. Some idiot will pay 16k for it and lose the lot when the DVLA find out.
