£300 Aerodeck still for sale in Wells, Somerset ...
12341297_10153880069050530_4735737126702
It's been standing for 12 months with no MOT.
If you want details it's on the Aerodeck parts for sale grp ... https://www.facebook...roups/Aerodeck/
These are awesome cars, someone get it bought.
I do like the front end of the SD1, it must have looked even more menacing when they first came out.
I am selling this on behalf of a friend who has moved abroad and has no further use for the car.
The MOT has lapsed - hence the "spares or repair"
I wonder if this has just been sitting on someones drive and only needs an MOT with nothing actually needing to be done to it.
I should have checked the MOT history before saying that!
Parking brake: efficiency below requirements (3.7.B.7)
front registration plate deteriorated (6.3.1d)
nearside front Headlamp not working on dipped beam (1.7.5a)
Parking brake lever has no reserve travel (3.1.6b)
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.3)
Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.D.3)
nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
nearside rear parking brake recording little or no effort (3.7.B.6a)
offside Front position lamp(s) not working (1.1.A.3b)
nearside front Direction indicator not working (1.4.A.2c)
offside front Direction indicator not working (1.4.A.2c)
offside Headlamp aim beam image obviously incorrect (1.8.A.1b)
nearside front Brake pad(s) less than 1.5 mm thick (3.5.1g)
Apart from the usual shit Volvo handbrake issue, the rest doesn't look that bad. Emissions depends on how far out it is - may just need a good drive. Or just a new cat/O2 sensor. Or its fucked.
It's cool because it's a modern volvo but still has tiny little wipers for the lights. None of this pop-up high pressure jet rubbish.
http://www.ebay.co.uk/itm/262349059510
Pogweasel sleeper.
Now for something completely different-super car destroyer!This is one serious sum itch,mother.300+bhp prepared by abbot racing.
Spec-engine 13k race prep,adjustable suspension, L.S.D.intotal £17,000 spent!
Totally!
I've always wanted one of these, or the equivalent Chevy/Pontiac.
"The Cadillac of minivans" as Elmore Leonard wrote in Get Shorty.
That looks ace for the money. Shame it's not MOT'd though.
It's not far from me either...
This looks cheap for one of these.
Check the MOT history of a vehicle
Registration number: B326RLP
Vehicle makePORSCHE Vehicle model928 S Date first used31 December 1985 Fuel typePetrol ColourBlue
MOT history of this vehicle
Test date24 March 2009 Test ResultFail Odometer reading79,706 miles MOT test number1319 5388 9492 Reason(s) for failure
Nearside Front Headlamp aim too low (1.8)
Offside Front Headlamp aim too low (1.8)
Anti-lock braking system warning lamp indicates an ABS fault (3.4.1c)
Nearside Rear Seat belt stitching incomplete (5.2.2b)
Advisory notice item(s)
Front Anti-roll bar rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Fuel pipe/s corroded
Worse than that is the ad- caps lock and punctuation are a stranger to this guy
THIS AUCTION IS FOR A B REG PORSCHE 928S IN DARK METALIC BLUE .I BOUGHT THE CAR OFF A FRIEND WHO HAD  BOUGHT THE CAR OVER 7 YEARS AGO AND APART FROM ASKING ME TO TAKE IT FOR AN M.O.T  ON INITIAL PURCHASE (SEE PICTURES FOR THE FAILURE SHEET) HAD JUST PARKED THE CAR AND LEFT IT.IT TRANSPIRES THAT THE PREVIOUS OWNER  HAD DONE SIMILAR SO ITS COVERED LESS THAN 50 MILES IN 13 YEARS.<div>DUE TO IT BEING STOOD FOR 7 YEARS I REPLACED THE BATTERY,FUEL PUMP,FUEL FILTER AND SPARK PLUGS AND IT FIRED STRAIGHT UP WHICH IS AMAZING CONSIDERING CONSIDERING THE STATE OF THE FUEL (SEE PICTURES FOR A FUEL SAMPLE IN A BOTTLE).THE FUEL TANK WILL DEFINITELY REQUIRE CLEANING OUT DUE DIRT AND RUST IN THE FUEL.THE ENGINE SOUNDS SWEET WITH NO NASTY NOISES.IT DOES SMOKE SLIGHTLY (SEE PICTURES) BUT ITS NOT A BLUE OIL SMOKE AND THE RADIATOR IS DAMAGED SO IT HAS NO COOLANT SO ITS NOT A WATER ISSUE SO IM GUESSING ITS THE FUEL WHICH NOT ONLY LOOKS TERRIBLE BUT SMELLS TERRIBLE ALSO.</div><div>I HAVE DRIVEN THE CAR IN FORWARD AND REVERSE GEARS AND THE TRANSMISSION WAS FINE BUT ONLY FOR A SHORT DISTANCE DUE TO THE DAMAGED RADIATOR/NO COOLANT.</div><div>THE BODYWORK LIKE MOST 928'S IS SUFFERING FROM PAINT BUBBLING AND WILL REQUIRE A FULL RESPRAY TO MAKE PERFECT BUT COULD BE USED AS IS WITH A GOOD POLISH.</div><div>THE INTERIOR WILL NEED A REALLY GOOD CLEAN AT THE LEAST (I WOULD PERSONALLY SPEND A FEW HUNDRED POUNDS ON HAVING IT RE COLOURED)  BUT OVERHALL IT SHOWS VERY LITTLE WEAR FOR A 1985 CAR.THE ARMREST ON THE CENTRE CONSOLE IS MISSING AND UNFORTUNATELY THE RECOVERY DRIVER WHO DELIVERED THE CAR TO ME SPLIT THE STITCHING ON THE STEERING WHEEL WHEN HE LOADED THE CAR NOT RUNNING WITH NO POWER STEERING (EASY CHEAP FIX BUT STILL ANOYING.</div><div>SO TO SUM UP,THE CAR STARTS,DRIVES AND STOPS IN NEED OF RESTORATION.IT COULD BE USED FOR SPARES BUT THAT WOULD BE A SHAME IN MY OPONION.THESE CARS ARE VERY GOOD INVESTMENTS AT THE MOMENT AND ARE SURELY SET TO RISE IN VALUE JUST LOOK AT THE PRICES OTHER OLDER PORSCHE'S,YOU COULD BUY THIS CAR NOW THEN LEAVE IT A FEW YEARS AND STILL MAKE A GOOD PROFIT WITHOUT TOUCHING IT.</div><div>PLEASE COULD THE WINNING BIDDER CONTACT ME IMMEDIATELY AFTER THE AUCTION ENDS.PAYMENT IS REQUIRED WITHIN 3 DAYS,CASH ON COLLECTION.THANK YOU.</div>
Think you might have time to go and look at it for me?  Just in case I suddenly found some cash down the back of the sofa, you know... ;)
That's bugger all failures on that Porka .... 7 years ago.
I'm sure that could be done! No idea how we'd get it up to you though without MOT? Unless you just pre book an MOT and go for it?
I 'might' be able to store it for a little while too, since there's a space on the drive as my Capri is away being rebuilt.
It looks pretty minging inside tbh but other than that appears ok in the pics. It's up to you...
Pogweasel sleeper.
Someone on my course at uni had a tuned 9000. Pulling nearly 400bhp. Absolutely mentally insane. Required a massive steering wheel fight when he floored it, to keep it going in a straight line.
It had done 240k when he started fiddling with it. By 255k he lost 3rd. By 258k he lost 2nd. Pretty much on the dot at 260k the gearbox died.
20k miles on a 240k mile gearbox with double the normal hp I would call that a win...
Logistics is something we could look at later.  What concerns me more is, would it be viable for someone with no time/space to take on a project?  A trusted pair of eyes going over it would be very helpful.
As for the interior, I've had worse.  Much worse!
I do like a Cavalier TD, this one needs some repairs for the MOT test.
Oh. :(
That's a Corsa B diesel donor car...
http://www.ebay.co.uk/itm/AUSTIN-PRINCESS-2-2-AUTO-/301907927033?hash=item464b1d5ff9:g:2MkAAOSwZ8ZW8-gg
nice, i'm sure this was big derek's car,
if so, then it is up for sale again, and with another £1000 put on the asking price....
it certainly looks like dereks, and if it is, then i can tell you that it is as immaculate as it looks. in fact it is probably better than it was when new.
http://www.ebay.co.uk/itm/Rover-Stirling-1993-Four-door-saloon-leather-interior-2675cc-petrol-blue-/141935198040?hash=item210bff3f58:g:FS0AAOSwHgVW7sAr
Selling a car 101:
Step one: Employ a glamourous model.
Step two: Come up with a realistic selling figure.
£3,100.00
Step three: Write an informative ad.
Stirling Rover, leather interior. condition as new.
Job Jobbed.
