AlsoMike Posted December 30, 2018 Posted December 30, 2018 Thinking of selling my 205, its a bit of project but they are only going up in value so this could be a great INVESMUNT OPPERTUNNITY for someone. I am based in Lincolnshire though so there is an element of danger involved if viewing/collecting. Its a 1990 XE model, which is just about as base model as they get. Originally a 1.0, but I've swapped in a 1.4 engine (regular TU3) and 5-speed box. No XUD content here chaps. MoT'd til June and taxed to get you home. Its pretty tidy, a few small dings and scratches here and there but polishes up ok. Interior is slightly mis-match as the previous owner had put GTi bits in, but I've replaced the seats with some decent GL seats which are mega comfy. Rust-wise it has a small hole in the N/S/F inner wing which may affect the next Mot depending on how picky your Mot guy is, and a rust patch under the rear seat. I've replaced pretty much everything on this car over the last 5 years, engine/gearbox/exhaust/front suspension/rear brakes & lines. The front suspension is Monroe GTi shocks with -40mm springs and the rear has been lowered 40mm. I did this 3 years ago and there doesnt look to be any camber on the rear beam. It starts easily with a bit of choke and drives and stops ok. I serviced it about 500 miles ago and fitted a cambelt and clutch when I swapped the engine in 3 years ago. Unfortunately the engine has a vibration/rumble at certain revs. I'm not sure what this is, i think this may be wear in the bottom end, hopefully its something less serious but dont bank on it. The car is located in Lincoln and I'm after around £400. Apologies for the 'just washed' ebay style pics. BeEP, Alan_Green, Maurice Marina and 15 others 18
aldo135 Posted December 30, 2018 Posted December 30, 2018 PM sent... Don't suppose you want a Xantia delivered do you?!!!
Marm Toastsmith Posted December 30, 2018 Posted December 30, 2018 Nice. 1.4 205s are where it's at. Tempting but I think one is enough for me. What are those wheels off of?
cobblers Posted December 30, 2018 Posted December 30, 2018 FFS it's my birthday, that cars got my initials in the number plate and I've got an engine for it in my nan's shed. But nowhere to park or work on it so I'm going to have to stay out. If someone does want a Saxo VTR engine for nowt to drop in this, let me know! yes oui si, Carlosfandango and bangernomics 3
SRi05 Posted December 30, 2018 Posted December 30, 2018 This looks like an absolute bargain, it's lovely
Cavcraft Posted December 30, 2018 Posted December 30, 2018 Blood hell, that's lovely. Also predict these will become the 'new' Mk2 Escort and the 3 door, non-sunroof shells are going to be worth pure DOLLAR v.soon. skattrd and cobblers 2
Peter C Posted December 30, 2018 Posted December 30, 2018 I've got an engine for it in my nan's shed. That’s just 100% Autoshite. dome, loserone, Ohdearme and 5 others 8
Fabergé Greggs Posted December 30, 2018 Posted December 30, 2018 Flipping lovely. Tell me about a VTR engine in these then.. I take it the manifold layout, gearbox and driveshafts fit but you just have to make the ECU work?
cobblers Posted December 30, 2018 Posted December 30, 2018 VTS engine is the one to go for if you can choose (125bhp, 1.6 16v)VTR is basically the same as what's in, but bigger. 90BHP. Physically it all bolts in with some grinding to the drivers side engine mount to clear the cambelt cover on the 16vNot sure what you'd do about an exhaust, I presume you'd just have to adapt from the VTS downpipe to the rest of the systemWiring is easy enough, I used to make looms for people to order back in the day but it's only about 5 wires to make it work, another 10 to make the gauges work properly. You'd need to get the ECU unlocked, but nowadays it's no hardship. I'm told the C2 1.6 16v engines are better (but fit the same) however I've been out of the game since before they were affordable.125bhp in this would be a right little flyer, I had the same engine in a 106 Rallye which is probably slightly heavier and it really was great fun. Fabergé Greggs 1
Fabergé Greggs Posted December 30, 2018 Posted December 30, 2018 VTS engine is the one to go for if you can choose (125bhp, 1.6 16v)VTR is basically the same as what's in, but bigger. 90BHP. Physically it all bolts in with some grinding to the drivers side engine mount to clear the cambelt cover on the 16vNot sure what you'd do about an exhaust, I presume you'd just have to adapt from the VTS downpipe to the rest of the systemWiring is easy enough, I used to make looms for people to order back in the day but it's only about 5 wires to make it work, another 10 to make the gauges work properly. You'd need to get the ECU unlocked, but nowadays it's no hardship. I'm told the C2 1.6 16v engines are better (but fit the same) however I've been out of the game since before they were affordable.125bhp in this would be a right little flyer, I had the same engine in a 106 Rallye which is probably slightly heavier and it really was great fun.Sounds loads of fun. For some reason I thought the 16v engines were significantly different..
clayts450 Posted December 30, 2018 Posted December 30, 2018 That looks gorgeous - I need to get my arse plonked down behind the wheel in one of these before they all vanish. I feel you on the vibration - going through the same with old Rover. Pain in the arse, almost literally. Steal for someone this - hope it becomes a forum bike soon.
bramz7 Posted December 30, 2018 Posted December 30, 2018 I had a 1.4 205 for a short while and it was really pokey. Just didn't gel with the hard clutch or seats though....
Partridge Posted December 30, 2018 Posted December 30, 2018 I had a 1.4 205 for a short while and it was really pokey. Just didn't gel with the hard clutch or seats though....When I was learning to drive, I crashed one into my Gran's hedge because I wasn't used to the clutch.
Marm Toastsmith Posted December 30, 2018 Posted December 30, 2018 I had a 1.4 205 for a short while and it was really pokey. Just didn't gel with the hard clutch or seats though.... Mine has soft clutch and seats. AlsoMike 1
2MB Posted December 30, 2018 Posted December 30, 2018 My old red 205 1.4 (gt) had just about the most instant power at its disposal of any car I’ve ever driven, literally a flex of the right foot would pull you right up a hill in a way that nothing has been able to match.I really want this
Marm Toastsmith Posted December 30, 2018 Posted December 30, 2018 What are those wheels off of?anyone?
cobblers Posted December 30, 2018 Posted December 30, 2018 Berlingo I reckon? Marm Toastsmith and chaseracer 2
dome Posted December 30, 2018 Posted December 30, 2018 That is a little honey. I had an xs back in the day, great fun!
richbraith Posted December 31, 2018 Posted December 31, 2018 I had a 1.4 205 for a short while and it was really pokey. Just didn't gel with the hard clutch or seats though....The one I'm currently driving has some of the most comfortable seats I've ever sat in. AlsoMike 1
AlsoMike Posted December 31, 2018 Author Posted December 31, 2018 anyone? I think they are just standard 13x5 peugeot steels - 2 are off a 205 I broke for spares a while ago and 2 are off my old 306. They have the black centre caps from the original 4.5 inch steel wheels fitted.
djoptix Posted December 31, 2018 Posted December 31, 2018 I like this a lot. If it's still around once I've dismantled the second MGF and put all the nice bits on the first MGF and sold the engine from the second one and scrapped the rest and fixed the windscreen chip on the first MGF and got it through its MOT and sold it, I will buy it. I mean, it won't be, but you know. PS disappointed at the lack of "still 1.0 on logbook m8" cliche. aldo135 and AlsoMike 2
GeordieInExile Posted December 31, 2018 Posted December 31, 2018 Base spec means less stuff, which means lightness. With the 1.4 this must go like stink.
JJ0063 Posted December 31, 2018 Posted December 31, 2018 God, that's beautiful and you're not even that far from me. I've got plenty of room too. Just no money spare.. hmm.. Why did I just spend £75 on a dashcam and £45 on jeans again?
AlsoMike Posted December 31, 2018 Author Posted December 31, 2018 Base spec means less stuff, which means lightness. With the 1.4 this must go like stink. Its deffo nippy.
djoptix Posted December 31, 2018 Posted December 31, 2018 I have an Mi16 that would go in this... davehedgehog31, Scruffy Bodger, BorniteIdentity and 1 other 4
Picketlinefeelingfine Posted December 31, 2018 Posted December 31, 2018 Always wanted to try one of these 205s because I only ever hear folks race about them.amazing that they're still this cheap. I'm sure Partridge will ask you to scrap it though, even though it's a Peugeot
Partridge Posted December 31, 2018 Posted December 31, 2018 Always wanted to try one of these 205s because I only ever hear folks race about them.amazing that they're still this cheap. I'm sure Partridge will ask you to scrap it though, even though it's a PeugeotChrist man, what's your beef with me? Did I cut you up or something or steal your lunch money? EDIT: OP, I'm aware this is in no way helping you sell the car, but at least you've had a free bump. Carlosfandango and BorniteIdentity 2
Dayno Posted December 31, 2018 Posted December 31, 2018 I like this a lot. When did the engine start making the rumbling sound and has it been getting any worse at all?
AlsoMike Posted December 31, 2018 Author Posted December 31, 2018 Rumble has been there since i swapped the engine, i thought it was exhaust hitting something to start with, it was an unknown quantity off ebay tho. Its never got too much worse tbh, always appeared over the same rev range. I keep the revs down and drive around it.
