HMC Comings (sherpa) and goings (morris)
2 minutes ago, Tubbo said:
It’s a real shame to burn all that history!
GDPR innit?
  • Haha 3
  • HMC changed the title to HMC- Rover P4 80
I bidded on that to £1950 but it didn't hit reserve. It was on the P4 drivers guild website at over £5k and I assumed the reserve was a lot higher. Anyway I decided to buy the one I have.
When the auction ended, the chap offered it for my bid price. I was very tempted but I turned him down as I'd rather have the 6cyl, even if scruffier than this 4cyl when given a choice.
Likewise I offered on yours via Facebook, and the vendor was going to get back to me, if it wasn’t collected; which it was. I’ve had a 100 and a 110 and a dead 80 (which I never actually drove) and wanted to try a less nose heavy one for local pottering.
Back home after a bit of a Dartmoor potter about
This has got tonnes of history- it was on the road till about 1968 and then was left untill returning to the road in 1991. All the docs and history suggest it’s done 31k from new. It certainly drives more lightly and crisply than the other ones I’ve had.  The photos are from 1988/89.
I'm surprised it has disc brakes at the front I had thought they had drums.
9 minutes ago, Surface Rust said:
I think the P4 is becoming the Southern AS version of the Ssangyong Rexton.
There must be a collective term for them.
An armada?
A pillage?
A pillage sounds apt!
How do you find the 4 cyl compared to the 6?  I love the sound of the 6 and think I'd miss the torque, but lighter parking also sounds appealing!
and the man answers my question without asking :D
also @Six-cylinder are you scruffier cos youve got more pots :D
An armada?
A pillage?
a flash git (in period)
I did the school run this am in the p4.  I got to it a bit earlier than necessary as I was unsure if the car would turn over and start. It did perfectly.  I have low expectation, at least at first when it’s called upon to be AN CAR rather than an exhibit.
It had rained quite heavily overnight and a the front mats were quite wet, looked like the door seals were to blame.  My eldest (aged 9) was much taken with the radio that needed to be tuned manually. Totally alien to him, and a source of amusement. I did test it out but although it had power, it just made cracking noises. He suggested we look for an antenna (which we found mounted on the roof) and when we extended it the radio worked! Think it was bbc world service that we picked up on LW?
Its just occurred to me that “radio on” is a 1970s British art house film what I’ve got a copy of. The protagonist drives a knackered p4 from London to Bristol. Might watch it again soon.
An armada?
A pillage?
A Trudge
It is peculiar how low the values (outside of The Guild) have remained on even quite nice examples of these.  You can pick up a reasonable P4 for the same sort of money as a Morris Minor which makes you wonder why you'd pick up a Morris Minor.  Suppose you could just have both.
Not seen it. Sounds great.
C&SC reviewed a 60 and reckoned the lighter IOE 4 was a better steer than the 80; both run rings around the 6s.
It is. Bleak, but great.
Awesome soundtrack, for the most part.
CAUTION: does contain Sting.
That looks brilliant. It's how I remember those motors looking in the 1980's when I was a young.
I'd have that over a mint one in a heartbeat - just looks like a daily user not some show queen.
An armada?
A pillage?
a siegfried?
Sir, you misunderstand the premise.
Extra cylinders are not for extra ... "Go", as your vernacular so crudely claims.
Extra cylinders are to balance the engine and provide additional torque. Silence and flexibility are the hallmark of a quality motor car.
Did a quick fleet shot yesterday….
And had a bit more of a look around the p4…
So much envy for this fleet. Winning at life there Mr HMC.
Most likely Radio 4 LW on 198KHz from Droitwich.
Being where you are in a car of such vintage, you ought to get RTE Radio 1 from Ireland on 252 too. Scroll to the right a bit and listen out for the death notices.
Lovely car this. Well done.
Shame the tool tray insert has turned to chewing gum; does anyone remanufacture them?
6 tubs of play-doh, patience, create a resin 'negative'.... Cast a repro >> Mebbies 🤔
Ace trolley, that 👍
