1 hour ago, HMC said:
But for less than 10% of the price ive got it now running on 8. Its so silky smooth now its unbelievable the difference. i can only imagine its was a combination of messed up order and knackered components.
Top shiting. Did you establish whether the order was correct before ripping out the old crap?
I was quoted over £30 years ago for a dizzy cap for my SD1. So comparatively speaking the rolls price was not that bad.
Beware though - a lot of ignition components are utter horseshit made in China - even in a brand name box - some of the rotor arms last about as long as six creme eggs in our house.
Riding high on all 8 cylinders was great, but was swiftly followed by the starter jamming whilst backed on single  yellows right outside a pub, on a hill….
Try as i might i couldnt un jam the starter from the flywheel. I spent while lying in the gutter hitting the starter with a hammer, with water running up my sleeves.  Result? I ended up very wet, but the starter wouldn’t budge. I had a crack at moving the crank but its quite hidden. I was going to take the plugs out to help, but basically i needed to just get it shifted as i started to attract the attention of the parking bods. I even wrote a little sign (in vain)
Why all the fuss trying to start it? Well, in rolls wisdom the brakes are powered by an engine driven pump, theres no traditional master cylinder, there would be no brakes, and the handbrake is shit. And its on a hill. And its pointing downhill. A recipie for demolishing shops right there.  It felt a bit like being one of those engineers who were trying to figure out how to raise the Mary Rose without trashing it more.  it is quite boat-like when it works.
Anyway i parked a car behind it and tethered a tow rope to it, buttock clenchingly i slipped it into neutral, using the other cars brakes and the slack taken up by reversing the other car up the hill. Then we eased around a blind corner, Shad first and onto the flat at 6am this morning.
There we switched the cars so the powered car went first and at walking pace we rolled into a suitable unrestricted parking slot
Phew!
  • HMC changed the title to HMC- Shad Shed - salvage operation
There is a back up braking system in the event that the engine stops. Underneath the car directly under where the drivers seat is, there is a standard master cylinder same one as an early Land rover. I think it just goes to the front wheels but it's enough to stop the car.
I know this because I was the lucky* person who got to steer a shadow whilst being towed by another car last year. The FTP was caused by a faulty coil ballast.
That good to know, cheers. Would have made it less scary for me!
A recipe for demolishing shops right there
Well yes but one of them is an off-licence, isn't it? Two birds, one stone and all that.
Bravo lateral thinking...
You might want to check that emergency foot brake sometime under 'controlled' conditions - ie in a big car park with a gentle tow or push - these are super-heavyweight cars... and worth checking carefully the thing is actually working.
Getting the handbrake in tip-top condition wd help if you can.
I've had a Shad' and the XJ6 which are both virtually unbrakeable with engine stopped IMHO.
Starter motor is going to be some standard item. Not the battery with not enough go?
The backup master cylinder had been replaced on ours a few years earlier which is maybe why it worked reasonably well. Definitely worth testing it.
On 11/02/2024 at 15:37, LightBulbFun said:
the number plate stuff is awesome, exactly the sort of shite I live for :) looks so much better on period plates!
I would leave the white splotches alone, I know certainly REV's period and original front number plate is also fairly splotchy like that, so it does not look out of place in my eyes at least (I would post a picture but someone would shout at me cuz Invacar LOL)
and I dont think the plod would mind also, it still clearly says the correct registration mark :)
I fucking love that shot, especially the whole incongruity of it, especially with the slot mags and caked in grime, it looks quite mean if anything :)
Rolls-Royces were alway everyday cars, just for rich people, instead of the fashion accessory they've become.
  • Agree 1
If it's of any interest to anyone, we once saw a dark coloured Shadow &  caravan combination on a site in the New Forest. The van was nothing exotic, just a relatively elderly single axle caravan. Thinking about it now, I'd imagine that it was practically effortless to tow behind such a large engined car.
We all know they used to like raiding the parts bin, but someone has gone one step further with the driver’s footwell mat…
From an Acclaim
19 minutes ago, HMC said:
Ive recently adopted this orphan…
After a colourful life including three engines, and at least 1 new gearbox, its spent the last few years dragging its older relatives about for spares and restorations. (photos by St Austell Bay classics)
Anyway, its been replaced by a discovery 3- and there was a possibility the next step would be for it to be sold off in parts through their e bay account.
I was interested in it was it was in an unusual colour for a p38, and its a very low spec one.
No extra wood, more basic heating system, no sunroof, no leather etc
Its also has had the rear seats removed and the load bay extended. easy enough to reverse.
So its the poverty model of the least appealing range rover. But its had everything its needed mechanically as its been in front line use.
It wafts along nicely on air, whilst not particulary quick (its the 2.5 bmw 6 diesel) and although the interior needs a clear and a few (cheap) replacement bits, it still feels special to drive.
I think it looks quite funky in white.
I've been looking for one like that for years. Having had every generation of Range Rover (other than the latest), the P38 is the best by far.
The build quality is genuinely astounding on them.
That looks great and being a base model is more 'Landrovery' - less to go wrong too. A real survivor. Bravo!
Looks real old money - just needs Hunter wellies, a ripped waxed jacked, flat cap and profuse nasal hair to complete the look.
  • HMC changed the title to HMC- Another automotive orphan- contains METROCAB
Ive got the nasal hair
I see the thread title expecting to see see hot Metrocab action and I get a P38 Land Rover? its cruel getting a mans hopes up like that! :mrgreen:
is this the Autoshite version for when an item in your shopping delivery gets substituted?  :)
"we are all out of shonky Metrocabs, some bloke called @wuvvum bought them all last time, have a shonky range rover instead"
Give it approximately 12.3 days and this one will be up for sale, it is HMC.
45 minutes ago, riek said:
Give it approximately 12.3 minutes and this one will be broken down, it is a Range Rover.
EFA.
I did wonder if that was ex-rozza being povvo spec and white but then I saw that it was an auto diesel so slower than a wet weekend in Cruden Bay.
  • Haha 3
  • HMC changed the title to HMC- NEW Orphanned P38 Range Rover
223k not out. Although the mechanicals are a bit of a trigger’s broom. Looking at the history one replacement engine was itself changed after about 15k
Lovely, a brown corduroy interior could almost sway me into owning one. Was it a police one?
Those tyres are worth the sale price alone. I hope it's a full set of Vigourouses, not just a hotch-potch of mismatched lesser tyres.
@LightBulbFun a JLR colleague told me a story about the P38 development, apparently someone mentioned its resemblance to a Metrocab during its development and the designer wasn't best pleased with the comparison. Once seen, never unseen.
Hah :) I almost wonder if there was some  subconscious intentionality with that?
as a fair number of the preposed replacements for the FX4 where Range Rover based :)
https://www.aronline.co.uk/concepts-and-prototypes/austin-fx4fl2-proposed-replacements/
That massively gives me the horn. We're moving soon and it would make an excellent moving van.
After a colourful life including three engines, and at least 1 new gearbox, its spent the last few years dragging its older, more glamourous relatives about for spares and restorations. (photos by St Austell Bay classics)
I was interested in it as its an unusual colour for a p38 and its a very low spec one.
Did it use to have blue lights on the roof ?
I wondered, but the first keepers seem to have been farmers in hampshire, looking at the service book.
Farmers .... I'm surprised it's still got a service book ....I'm a farmer's son
