Truck Shite
29 minutes ago, Rust Collector said:
'Saurer'
Saurer were a Swiss company who regularly appeared in various editions of 'The Observers Book of Commercial Vehicles' they made allsorts - tippers, dustbin lorries, coaches and military vehicles. All looked very tough and purposeful.
They did have a tie up with the Italian OM company (taken over by FIAT, now IVECO) - the one above looks very OMish.
Saurer originally made textile equipment before branching out into lorries. They are still with us, but back to making textile equipment only - https://saurer.com/en
3 minutes ago, willswitchengage said:
Competition time. What are we looking at here?
Test rig of some sort in a push me/pull you config? Diesel at far end and Hydrogen at the near end?  Don't see any fuel tanks but the right hand end looks like a condenser setup???
Definitely double headed. Some sort of high maneuverability carrier that needs to be so low it can't have a driveshaft up the middle, but isn't expected to work indoors much, or on public roads? Doesn't look especially heavy duty either, nor extensible, which rules out most 'specialised carriers' I can think of. Maybe carries whatever it carries on the roof? That looks fairly robust.
Definitely intrigued though!
Wasn't it for use in the Chunnel? Looks like a mad Renault Master when clothed?
I thought they used trains...
A Sterling truck (defunct US manufacturer) now used by the same learner driver school as the ones previously snapped in this location.
An Aussie fuel truck.
I did see loads of exciting American trucks, including the iconic Peterbilts and Kenworths also loads of Macks (my favourite) but whilst driving, so couldn’t photograph them.
3 hours ago, MJK 24 said:
A day to forget 🤦🏼
Oops! Good attempt tho
With the collapse of the DDR the IFA factories struggled against western products. Robur was one - here's their attempt at modernisation, as well as the plastic grille and fancy seats the main change was replacing the ancient 3 litre petrol engine with a Deutz diesel. This was made in 1991 but didn't save the company as it was still a design from the '60's and the east was being flooded with cheap Transits etc.
  • Like 7
A Berliet Stradair, these look like a Matchbox 'lorry from the future' but are a real thing, built between 1965 and 1970 in alsorts of body types.
Anyone else think that there's a little bit of Stradair in a Sherpa?
Love the “step”, no expense spent. Could have doubled up as a starting handle in an older truck.
Earlier Robur's look like they have a starting handle hole in the grille, which is blanked off in later ones. I can't find any pictures of someone starting one with a handle, but the steps look like they not designed for easy removal.
image.png.bd3b3940756bb11a4b19ef85535f4cc8.pngimage.png.9729d374366d6e5bbd155c74ab206347.png
The DK3 from Ludwigsfelde 1956-58, it has a 652 cc DK2003 diesel engine developing 6 hp, the white handled lever controls the steering.
I believe Sterling was once Ford Trucks, spun out under a new brand name, bought by Daimler then quickly closed down.
Flitwick car show yesterday had a few trucks in attendance, mostly modern ones from local fleets but also these two oldies. The first is obviously a Bedford KM...
Stringer_Trevor_NRD197M_Flitwick_2023-08-20.thumb.jpg.f7f3df27a5732223377bbe0cc51c2893.jpg
But the second I wasn't sure about other than being an AEC
Luckily the owner appeared while I was looking at it so I asked him what it is. It's a wartime AEC 0854 6x6 that he thinks was either a tanker or crane, one of a pair rebuilt after the war by timber merchants B & J Davies with Gardner engines, new cabs and timber crane bodies. Top speed of 28mph and an unladen weight of about 8.5 tons.
@quicksilver, I followed an early/mid 1990s grey ERF tractor unit pulling some sort of bulk liquid trailer, on my way back from the last FoD event . It pulled out of front of me on the Buckingham to Bicester road, about halfway along, it turned across me very sharpish from the large farm which advertises pick your own asparagus frequently.
Initially I was like ‘WTF’ but then it proceeded to travel at least 70mph for most of the rest of the way, I struggled to keep up with it, it only slowed down (to about 60-65) when it caught up a National Express coach about 3 miles out of Bicester, which it proceeded to tailgate all the way to the roundabout by the Heritage place, where it shot off in the direction of Aylesbury.
Lots of diesel smoke puffing out of the stack. It did not appear to brake at any point in the journey, maybe the trailer lights were disconnected. The trailer had no plate so no idea of the actual year.
It seemed illegal on several fronts, and also absolutely perfect if someone ever wanted to remake Duel but this time set it in Buckinghamshire.
I assume it is well-known, or perhaps notorious locally?
There's only one man that could be: the infamous local character Robert Gassor aka Nobby. He loves ERFs, has had that one for years and drives it very enthusiastically. I've seen him many times, along with his uncle who has a slightly newer blue one.
W985 RNE - Robert Gassor
It’s pre 2000 ish so it’ll be speed limiter exempt.
hit the gate doing 98 drive and let those truckers burn 10-4. Toot toot!
And right on cue after I mentioned him, Rob's Uncle Phil turned up this morning.
I've often wondered why older trucks aren't more common, is it a question of them reaching the end of their economic life and being too expensive to contemplate rebuilding or it is more to do with the need for reliability/warranty on something that needs to be utterly reliable? TBH I've heard that some modern trucks can be a bit deficient in the reliability stakes these days, usually down to electronic or sensor issues.
I couldn't help noticing how many old trucks are still running in Australia, and how many engine remanufacturers/rebuilders there are. Same with heavy plant, people prefer to keep rebuilding what they've got rather than buying a replacement digger or whatever every six or seven years. They also prefer fairly old tech designs, although I think emissions rules are much more lenient over there.
Our haulage industry is very 'consumerist' and for the most part, old equipment is bad for image. Add in that the bulk of second hand sales come off the back of the deals manufacturers do with the big corporate fleets, and so smaller fleets will tend to fall into line. It's pretty much only those sorts of owner drivers (or farmers, sole traders etc.,) who use genuinely old equipment; probably because it's bought and paid for, they know what it'll do, and they can probably service it blindfolded!
There's really no reason not to use an ERF like that; even though the company is defunct, the makers of the bits that compose it, aren't. Cummins, ZF, and Rockwell/Cameri parts aren't any harder to get than anything else. It'll plate to 44t and hook onto an ISO equipped trailer, and the 'lack' of BHP isn't that big a handicap when you've got a manual box. So you can't go into London (or any other LEZ)? No bother! Most truckable stuff isn't within LEZ's anyway. And if it's just you driving it, you're not going to rack up the interstellar kilometres that a triple shifted corporate trunker will.
Will probably still do 28mph across a ploughed field towing a portacabin with no wheels. :D
