Six Cylinders Motoring Notes
18 hours ago, Six-cylinder said:
no syncro on 1st or 2nd
can you pull off in 3rd?
Not really, 2nd flat or downhill and soon into 3rd. Uphill 1st to walking pace and crash it into 2nd and then it pulls strongly uphill in 3rd and 4th. I am sure I will get better at it with practice.
are you going to fit the SOE or leave it bare?
or possibly get a Rubber Duck type Mack emblem , bit more AS
Please say your buying a special pair of driving gloves and a driving hat now?
Would double de-clutching help?
Quite a spectacle to behold, my Lord having his large knurled nut caressed gently in public.
What's the turning circle like?  Every prewar car I've driven apart from the Renault Novaquatre was shite, and all were a lot smaller than the Rolls.
Shirley the turning circle is 'adequate'?
I don't think a Rolls owner should have to change direction, shirley everyone else should.
I really hope the SOE came with it. I'd love to see it fitted.
Looking down an RR bonnet and having that emblem leading your way down the road really is quite something!
Terrible and you simply cannot turn the steering without the car moving.
No sadly it only came with the plain town cap.
Any SOEs dumped unwanted at your place!
In disguise with a Town Cap. More apt....
19 minutes ago, High Jetter said:
I thought of Sale Or Exchange!
I was on the Churchill theme!
57 minutes ago, Six-cylinder said:
Tonight @ianbmw came over and did part 1 of fitting my reconditioned Carlton head.
Sure I just missed it, but did we ever find out why it failed so spectacularly shortly after the head being refitted before?  Original head gone porous?
Yes, but I was being discreet! :)
A small diameter hose came off when I took it out of storage and left a large puddle on the floor. I had left it idling while I put away another car and closed up. It was no problem to put the hose back on and refill the radiator. I drove about 4 miles and it seemed as if the engine was getting hot so I stopped and opened the bonnet. The temp gauge said normal and the radiator was full and stone cold, but the engine was overheating.
I only came up with two explanations, first was the thermostat was jammed shut and the second that there was an airlock. I favoured the airlock as the culprit as the thermostat had been working fine 2/3 weeks before.
I had the head checked by the engineering shop and they found no problem with it being porous. They found a little distortion and machined it flat. there were also two very slightly bent valves that were replaced, which they believe happened when cranking it with water in the cylinder after the head gasket had failed.
That's sad - I'm sure in the walkaround video I saw of it, it had an SOE fitted.
Best I could do would be to 3D print you one that'd be too small and chrome paint it! 😅
Yesterday I took the 20/25 to a care home in Milton Keynes. It part of a classic car display organised by Milton Keynes Classic Cars Club for the residents.
One lady was taken by a Tiger!
One of the staff was taken out in the noisy Corvette by its enthusiastic owner. On return I said to the girl, did that make your legs go wobbly, no she said my husband has a Porsche!
As this care home is the one that organised Classic cars for the residents I have put my name down for a place!
On 7/28/2023 at 2:29 PM, quicksilver said:
I've got a mental picture of it looking like an Indian train with people crowded on the roof and hanging off the sides, one occasionally falling off and getting left behind.
Sir has indeed purchased himself a most excellent conveyance.
Like Omar sharif and the resistance fighters in the yellow rolls Royce!
On 7/28/2023 at 6:37 PM, timolloyd said:
Is it me or does @Slowsilverlook like Brabinger from To The Manor Born? And in which case does that make @Six-cylinderRichard Devere?
I think @Six-cylinder needs to buy him a chauffeur’s uniform!
On 7/28/2023 at 6:30 PM, Six-cylinder said:
@Slowsilver helped me move the Biturbo to storage this afternoon to make more room for the 20/25. I felt it was only fair to give him first ride in the 20/25.
Armed with a printout on how to cold start your 20/25 I set about getting it started. Having had it on charge since last night the starter flung the engine over with enthusiasm. Trouble was it would only run using the starter carb which you are not suppose to use for more than 30 secs.
Slowsilver noticed the knurled lid of the carburettor piston housing had vibrated lose and unscrewed slightly allowing the vacuum within to be compromised, the piston therefore did not rise and the slow running jet did not operate as intended.
This repair is of course considered to just be the normal duties of a chauffeur! (thank you slowsilver for your diagnosis and repair, you have saved the car from being unusable this weekend)
The plan now is to take slowsilver out for an evening run after rush hour.
Ah, so like mrs fforbes Hamilton, you got a little man from the village round to fox it!
4 hours ago, bezzabsa said:
£1400 you must be joking,  as much as I would like a dress uniform for my car if that is the cost it is no go. I may have bought a Rolls Royce but I am still a shiter at heart. Please can everybody keep an eye out on there local Freecycle site!
what a cracking purchase. Well played sir.
How about
No. Thought probably not.
One of these and a rattle can from poundland?
  • Haha 5
How about
The radiator base cap alone is £240 without the lady so I need to stumble upon a bargain.
