High Jetter Posted November 4, 2020 Posted November 4, 2020 I think the Maxi holds up very well against the Maestro - I prefer the lines of it. (Plus it looks a bit shinier too!) Mrs6C and lesapandre 2
richardmorris Posted November 4, 2020 Posted November 4, 2020 3 minutes ago, High Jetter said: I think the Maxi holds up very well against the Maestro - I prefer the lines of it. (Plus it looks a bit shiner too!) You can see the heritage. Mrs6C, egg and lesapandre 3
Tadhg Tiogar Posted November 5, 2020 Posted November 5, 2020 6 hours ago, High Jetter said: I think the Maxi holds up very well against the Maestro - I prefer the lines of it. (Plus it looks a bit shinier too!) I can sort of see where the Gilbern Invader got its face from... lesapandre 1
Six-cylinder Posted November 5, 2020 Author Posted November 5, 2020 lesapandre wrote in What did you drive thread........ I though so...I will have to pull mine out and see what I can do...toasty heater and ok on the move because the ram effect works it ok. Just cold starts are a prob. @lesapandre C15 heater fans are not difficult to change, the problem is finding a replacement known to be in good condition. We have had cold start problems 3 separate times in the six years we have owned it, glow plugs, glow plug relay and contaminated fuel. We did the fan, glow plugs and glow plug relay ourselves, but the contaminated fuel was a ride of shame. Mrs6C and lesapandre 2
lesapandre Posted November 5, 2020 Posted November 5, 2020 I'll pull the fan out.. see what I can find. Its not too bad without....
hairnet Posted November 5, 2020 Posted November 5, 2020 yo BL fondler when is the vvc going in it :D did ya big shed get fixed yet did ya make offer on the maxi - ( @Slowsilver might not let you :P ) Mrs6C 1
Asimo Posted November 5, 2020 Posted November 5, 2020 On 01/11/2020 at 11:41, Six-cylinder said: That's a fail then! The only time ianbmw had available today to get the new HT leads, dist cap and rotor arm on the Trevi was 9am this morning in the rain. I took his offer up as I want to get the car running again and we found the rotor arm I bought was similar but on identical and would not fit. We fitted the HT leads and cap, but we still have a fat spark from the coil and no spark from the spark plug leads. When those Bosch rotor arms fail, and they often do, the resistance material between the centre contact and the wiping contact can be bypassed by soldering a thin piece of copper wire between the two bits of brass. Mrs6C 1
Tadhg Tiogar Posted November 5, 2020 Posted November 5, 2020 2 hours ago, Six-cylinder said: ... @lesapandre C15 heater fans are not difficult to change, the problem is finding a replacement known to be in good condition..... Is it not possible to replace just the motor with a near equivalent? Or, in other words, are there motors in other heater fans that would be a direct fit? This is something I've been thinking about ever since the one in the CX expired in a thick cloud of acrid smoke outside Kings Langley last year....
Six-cylinder Posted November 5, 2020 Author Posted November 5, 2020 9 minutes ago, Tadhg Tiogar said: Is it not possible to replace just the motor with a near equivalent? Or, in other words, are there motors in other heater fans that would be a direct fit? This is something I've been thinking about ever since the one in the CX expired in a thick cloud of acrid smoke outside Kings Langley last year.... Trouble is the motor sits in a moulded plastic case and if it is not exact or firmly mounted the fan will rub the casing. All things are possible but it will require skill, ingenuity, money and patience to achieve.
Mrs6C Posted November 5, 2020 Posted November 5, 2020 8 hours ago, lesapandre said: I'll pull the fan out.. see what I can find. Its not too bad without.... It's not difficult to pull out the fan unit, but you have to remove the whole parcel shelf on the RHS first, to get at the fan. You may need to unscrew the footwell 'A' post plastic trim and carpet trim first, to give enough room to slide the parcel shelf free. The fan casing hangs on 2 or 3 (according to year, I think) threaded studs that descend from the inside of the bulkhead. Once the nuts holding the fan casing to these are undone, the fan casing needs wiggling around to split its air trumpet from the rest of the ventilation ducting and to to withdraw it downwards into the RHS footwell. Its wiring is on a plug that should become visible if you follow the wires back from the fan unit. Just unclip that plug and out it comes. While new fans units don't appear to be available in the UK now, s/h units can be found on eBay, especially in France, Spain, Portugal etc. for around 45 Euros. Sometimes the wiring takes a bit of a beating where it bends up and down to go into the motor. If the fan FTP is due to a broken wire here, it may be possible to fix it with a bit of replacement wire spliced in. With time and patience, the unit could probably be taken apart and a different motor of suitable dimensions be substituted, but we haven't tried that route yet. Also, the fan is two-speed. You may find that you can persuade it to run on one speed even if the other doesn't work. LightBulbFun and lesapandre 1 1
lesapandre Posted November 5, 2020 Posted November 5, 2020 Wow thanks that is so helpful. I will tackle that next week when I get time. I'll try the simple things first like the switch then get it out and check the wires and go from there. If it is u/s I will order something up from France. Mrs6C 1
Mrs6C Posted November 5, 2020 Posted November 5, 2020 1 hour ago, lesapandre said: Wow thanks that is so helpful. I will tackle that next week when I get time. I'll try the simple things first like the switch then get it out and check the wires and go from there. If it is u/s I will order something up from France. Have a squint up under the dashboard on the RHS with a torch and you will see how it all hangs together up there. You just need to undo things in the right sequence to get the fan unit out, then refitting is the reverse as the HBOL would say. The slightly awkward bit for refitting is to get the air trumpet socketed back into the ventilation pipe (IIRC there is a rubber seal around the end of the ventilation pipe, into which the open end of the air trumpet is inserted) but it will go with some more wiggling around of the unit, once back in roughly the right place. Once the air trumpet is in place, line up the fan unit's fixing lugs with the studs, push the unit up to slide the lugs up onto these and refit the nuts. Go carefully with tightening the nuts! Finger tight and a nip up turn with a small socket will be fine. Stripping the stud threads would not be a good thing. lesapandre 1
Six-cylinder Posted November 6, 2020 Author Posted November 6, 2020 I had to go out on an approved lockdown trip today, so what to drive! I decided on the car that I had not driven for the longest that was at home. I had forgotten how lovely it is to drive, being an Elegance it has a comfortable ride and the 3.2 V6 gives it an easy turn of speed. Oh yes the draw back 25/26 mpg, but who cares when you are only doing a tiny mileage. chaseracer, SiC, Cavcraft and 7 others 10
beko1987 Posted November 6, 2020 Posted November 6, 2020 Given the miles I drive atm even I'd be able to afford to put fuel in at 25mpg!
Tadhg Tiogar Posted November 8, 2020 Posted November 8, 2020 On 11/5/2020 at 9:35 PM, Mrs6C said: ....With time and patience, the unit could probably be taken apart and a different motor of suitable dimensions be substituted, .... This has been on my mind half the day. There must be a motor out there that would do the job.
Six-cylinder Posted November 10, 2020 Author Posted November 10, 2020 A long shot, but we need a 9.00 - 16 10 ply tyre. Our JCB has burst a hole in the side wall of a front tyre. New Tyres are hundreds of pounds and all we do is move a around our field and maybe the odd lap by a shiter. It is going to have to be second-hand one. Coprolalia, Mrs6C and beko1987 1 2
beko1987 Posted November 10, 2020 Posted November 10, 2020 74 cans of tyre goo? Got to be a question to ask your local friendly farmer types surely? Or lob the wheel in the boot and pop down kwikfit and film it... Mrs6C, RayMK, DSdriver and 3 others 6
LightBulbFun Posted November 10, 2020 Posted November 10, 2020 12 minutes ago, Six-cylinder said: A long shot, but we need a 9.00 - 16 10 ply tyre. Our JCB has burst a hole in the side wall of a front tyre. New Tyres are hundreds of pounds and all we do is move a around our field and maybe the odd lap by a shiter. It is going to have to be second-hand one. is it too far gone to just stick an inner tube in it? (well Id have thought something like that would have already had an inner tube fitted) Mrs6C 1
Saabnut Posted November 10, 2020 Posted November 10, 2020 Tractor tyres have tubes, 900 x 16 is a fairly common size (or rather was) as FC landrovers were fitted with them, but the 10 ply is more problematic. Take a look at agricultural collective auctions as this will be the best source. Sign up to Bidspotter for notifications of upcoming auctions. LightBulbFun and Mrs6C 2
richardmorris Posted November 10, 2020 Posted November 10, 2020 14 minutes ago, LightBulbFun said: is it too far gone to just stick an inner tube in it? (well Id have thought something like that would have already had an inner tube fitted) https://www.ebay.co.uk/itm/900x16-New-Tyre-Inner-Tube-Good-quality-valve-TR15/182617536222?hash=item2a84da76de:g:ytcAAOSwiLdV99fU Mrs6C and LightBulbFun 2
Dick Cheeseburger Posted November 10, 2020 Posted November 10, 2020 Pair of new tyres here. Too fruity on price I assume? https://www.ebay.co.uk/itm/154097232004 Mrs6C and richardmorris 2
Six-cylinder Posted November 10, 2020 Author Posted November 10, 2020 3 minutes ago, Dick Longbridge said: Pair of new tyres here. Too fruity on price I assume? https://www.ebay.co.uk/itm/154097232004 That does seem a good price but I would still would rather go second-hand and cheap.
dozeydustman Posted November 10, 2020 Posted November 10, 2020 35 minutes ago, Dick Longbridge said: Pair of new tyres here. Too fruity on price I assume? https://www.ebay.co.uk/itm/154097232004 Same chap is selling singles at £60 https://www.ebay.co.uk/itm/BKT-TF-9090-6-00-16-3-Rib-Tyre-New/154097256972?hash=item23e0e98a0c:g:vvAAAOSwmoxfaMsg You'd still need £20 for a tube though. Whacking another tube in might give you a bit of respite but no guarantee any frayed plies are not going to damage it Doing some googlage u-pull-it have a tractors section https://www.u-pull-it.co.uk/agricultural-commercial also http://www.tractorbreakers.com/content/large-selection-wheels-and-tyres Might be worth contacting one of those see how much to have a tyre delivered. Six-cylinder 1
richardmorris Posted November 10, 2020 Posted November 10, 2020 1 hour ago, Six-cylinder said: That does seem a good price but I would still would rather go second-hand and cheap. They will last another forty years though! LightBulbFun 1
hairnet Posted November 10, 2020 Posted November 10, 2020 https://www.ebay.co.uk/itm/6-00-9-600x9-DELI-10-Ply-TRAILER-CARAVAN-STATIC-MOBILE-HOME-TYRES-TUBES/324102549547?hash=item4b7604702b:g:22AAAOSwcIxea9oD no second hand ones.........but this is the cheapest if you dont need ribbed (fnarr)
richardmorris Posted November 10, 2020 Posted November 10, 2020 20 minutes ago, hairnet said: https://www.ebay.co.uk/itm/6-00-9-600x9-DELI-10-Ply-TRAILER-CARAVAN-STATIC-MOBILE-HOME-TYRES-TUBES/324102549547?hash=item4b7604702b:g:22AAAOSwcIxea9oD no second hand ones.........but this is the cheapest if you dont need ribbed (fnarr) It won’t match the other one though! beko1987 1
camryv6 Posted November 10, 2020 Posted November 10, 2020 2 hours ago, Dick Longbridge said: Pair of new tyres here. Too fruity on price I assume? https://www.ebay.co.uk/itm/154097232004 If you read the advert it is for a single tyre, yet the photo shows two, be careful if you go for this one @Six-cylinder richardmorris and LightBulbFun 2
wuvvum Posted November 10, 2020 Posted November 10, 2020 28 minutes ago, richardmorris said: It won’t match the other one though! It's also for a 9" wheel rather than 16", so no use at all really... richardmorris 1
camryv6 Posted November 10, 2020 Posted November 10, 2020 5 minutes ago, wuvvum said: It's also for a 9" wheel rather than 16", so no use at all really... @Six-cylinderDon't trust anyone on here to find you a tyre 🤣 Cavcraft, LightBulbFun and richardmorris 1 2
