Zelandeth Posted November 3, 2019 Posted November 3, 2019 This jet is tiny. When we're talking poking through it with wire, we're talking a couple of strands from a bit of flex. This was after it had been cooking in the ultrasonic cleaner for half an hour and had already had half a can of aerosol carb cleaner unloaded trying to shift it...so it wouldn't have been that easy to shift with whatever happened to be floating around at the FoD. Main jet is reasonably large, the idle jet is flipping tiny though. 125 Vs 55, though I'm not sure what those numbers actually represent in terms of dimensions...or if they're just a standard used to represent carb jets... LightBulbFun and Mrs6C 2
LightBulbFun Posted November 3, 2019 Posted November 3, 2019 45 minutes ago, Zelandeth said: This jet is tiny. When we're talking poking through it with wire, we're talking a couple of strands from a bit of flex. This was after it had been cooking in the ultrasonic cleaner for half an hour and had already had half a can of aerosol carb cleaner unloaded trying to shift it...so it wouldn't have been that easy to shift with whatever happened to be floating around at the FoD. Main jet is reasonably large, the idle jet is flipping tiny though. 125 Vs 55, though I'm not sure what those numbers actually represent in terms of dimensions...or if they're just a standard used to represent carb jets... aye yeah defo did not have anything that small, I think we used a strand from REVs broken throttle cable (I wasn't the one doing the poking, but I was floating around quite closely, as I find all this sort of stuff very interesting ) its interesting and worth noting that the Model 70 workshop manual, talks about the Weber 32ICS3 carb, where as Dolly's and every other Model 70 I have seen has a webber 32ICS10 (I dont think I have seen a Model 70 with a Solex carb, and its interesting to note that the DHSS spare parts book only has the weber listed) this is the only bit of info I can find on what the ICS10 variant is about exactly https://puch500.eokc.at/forum/viewtopic.php?f=6&t=1151 I am in contact with a guy who knows all things Steyr puch, but the language barrier makes things hard sadly perhaps the guys are haflinger technik knows something? just worth keeping in mind if something does not quite match up between the workshop manual and the IRL carb Mrs6C 1
Six-cylinder Posted November 7, 2019 Author Posted November 7, 2019 The Invacar manifold is back from have its bracket welded back on by @Andyrew, thanks very much. LightBulbFun, Mrs6C and egg 3
Six-cylinder Posted November 7, 2019 Author Posted November 7, 2019 @Andyrew also separated the old broken coil for its bracket for the CX and repainted the air filter assembly. Again thanks very much. Mrs6C, Tadhg Tiogar, egg and 1 other 4
Mrs6C Posted November 7, 2019 Posted November 7, 2019 10 minutes ago, Six-cylinder said: @Andyrew also separated the old broken coil for its bracket for the CX and repainted the air filter assembly. Again thanks very much. Are you channelling your inner Johnny Cash and getting @Andyrew to repair the CX one piece at a time? Tickman, stonedagain, DSdriver and 1 other 1 3
Six-cylinder Posted November 7, 2019 Author Posted November 7, 2019 I turned up at @Andyrew workshop with a rattling exhaust heat shield about to fall off on the black Alfa 156 so this is now in the boot! It is an Alfa so the driver door open button choose that moment to stick in so the door would not close, WD40 failed but 3 in 1 managed to get it working again. I then tried my luck to see if he could stop the drivers knee pad falling down that covers the fuses, no is the answer, but then the combined design and manufacturing skills of Alfa Romeo never managed it either! Mrs6C 1
Six-cylinder Posted November 7, 2019 Author Posted November 7, 2019 I collected Mrs6C's ZX today, it has now got a fresh MOT with just a number plate bulb that needed replacing. beko1987, Scruffy Bodger, LightBulbFun and 13 others 16
beko1987 Posted November 7, 2019 Posted November 7, 2019 32 minutes ago, Six-cylinder said: I collected Mrs6C's ZX today, it has now got a fresh MOT with just a number plate bulb that needed replacing. Hope that gives mine good karma... LightBulbFun, Mrs6C and Six-cylinder 3
Andyrew Posted November 7, 2019 Posted November 7, 2019 Some before and afters. egg, Tadhg Tiogar, LightBulbFun and 4 others 7
Six-cylinder Posted November 8, 2019 Author Posted November 8, 2019 It's Friday, it's shopping, but this week it is 1993 all over again! DSdriver, HillmanImp, Saabnut and 11 others 14
Tadhg Tiogar Posted November 8, 2019 Posted November 8, 2019 16 hours ago, Andyrew said: Some before and afters. That looks like the usual air filter for a CX 2.5litre. Mine's equally corroded, and people keep telling me to replace it with one of those foam cone filters instead
Six-cylinder Posted November 8, 2019 Author Posted November 8, 2019 4 minutes ago, Tadhg Tiogar said: That looks like the usual air filter for a CX 2.5litre. Mine's equally corroded, and people keep telling me to replace it with one of those foam cone filters instead Thanks to Andyrew I am now very happy to keep mine original. (2400i)
Six-cylinder Posted November 8, 2019 Author Posted November 8, 2019 Floaty McFloatface has arrived! Andyrew, eddyramrod, anonymous user and 22 others 23 2
LightBulbFun Posted November 8, 2019 Posted November 8, 2019 haha very cool so what is the story behind this one if there is one or was it just an impulse ebay buy? and is there any specific plan for it or? (ironic thing is I doubt it floats!) BTW side note, taxed for the first time in 15 years! yay! Mrs6C 1
egg Posted November 8, 2019 Posted November 8, 2019 Seeing this arrive @ the FoD is like a new ride at Alton Towers ? BorniteIdentity, The Moog, LightBulbFun and 3 others 4 2
vulgalour Posted November 8, 2019 Posted November 8, 2019 Note to self: return here to quote pictures for December calendar thread. Mrs6C, The Moog, egg and 3 others 6
Six-cylinder Posted November 8, 2019 Author Posted November 8, 2019 14 minutes ago, vulgalour said: Note to self: return here to quote pictures for December calendar thread. chaseracer, Mrs6C, spike60 and 4 others 7
Zelandeth Posted November 8, 2019 Posted November 8, 2019 Was lucky enough to get to see the new arrival this afternoon, and I very much think that it does look to be a huge amount of fun The FoD is getting a name for itself as a home for oddball three wheeler vehicles isn't it... LightBulbFun, egg and Mrs6C 3
Six-cylinder Posted November 8, 2019 Author Posted November 8, 2019 Just now, hairnet said: slam it put a 3 pot ecoboost in it NO, no has any body got a crashed Tesla we can pinch the batteries/motors out of! catsinthewelder, LightBulbFun and hairnet 1 2
hairnet Posted November 8, 2019 Posted November 8, 2019 5 minutes ago, Six-cylinder said: NO, no has any body got a crashed Tesla we can pinch the batteries/motors out of! kill a duracell bunny now
LightBulbFun Posted November 8, 2019 Posted November 8, 2019 12 minutes ago, Zelandeth said: The FoD is getting a name for itself as a home for oddball three wheeler vehicles isn't it... much the dismay of @Six-cylinder probably it will be very interesting see what makes such a relatively old electric vehicle go etc especially on the motor speed control side of things (ie im curious is it a big ass resistor, several speed tappings on the motor itself or some early high power silicon?) side note you didn't happen to get a chance to drop the fuel tank out of REV did you?
Floatylight Posted November 8, 2019 Posted November 8, 2019 Floaty McFloatface has arrived!Hate to ask the obvious... Hpw are you planning to charge it at the FOD?Sent from my Moto G (5) using Tapatalk LightBulbFun 1
Saabnut Posted November 8, 2019 Posted November 8, 2019 1 minute ago, Floatylight said: Hate to ask the obvious... Hpw are you planning to charge it at the FOD? Sent from my Moto G (5) using Tapatalk V8 Petrol generator I hope.... dome, Six-cylinder and LightBulbFun 3
Six-cylinder Posted November 8, 2019 Author Posted November 8, 2019 15 minutes ago, Floatylight said: Hate to ask the obvious... Hpw are you planning to charge it at the FOD? Sent from my Moto G (5) using Tapatalk There is no plan! Impulse buy no forethought, just bid and so we have won it, now what! wuvvum 1
666jjp Posted November 8, 2019 Posted November 8, 2019 awaits pic with invacar on the back? 500tops, chaseracer and LightBulbFun 2 1
Zelandeth Posted November 8, 2019 Posted November 8, 2019 (edited) This sounds like an excellent excuse to get hold of something like a Gardner 6LX engine and a generator suitable to bolt onto it... Edited November 8, 2019 by Zelandeth typo LightBulbFun 1
Mally Posted November 8, 2019 Posted November 8, 2019 30 minutes ago, Six-cylinder said: There is no plan! Impulse buy no forethought, just bid and so we have won it, now what! Just stick it on front of your Xmas cards. Mrs6C 1
wuvvum Posted November 8, 2019 Posted November 8, 2019 Those mirrors though... If memory serves the speed control on these old floats was done by a thing called a thyristor chopper, which switches power to the motor on and off rapidly - more efficient than a BFO resistor, although I would imagine said resistor could also double as a cab heater in the winter. LightBulbFun and Skizzer 2
richardmorris Posted November 8, 2019 Posted November 8, 2019 2 hours ago, Six-cylinder said: Floaty McFloatface has arrived! I despair. anonymous user and Mrs6C 1 1
