phil_lihp Posted August 26, 2014 Posted August 26, 2014 Can you not just bridge the clock's power cables to test that theory?
philibusmo Posted August 26, 2014 Posted August 26, 2014 Can you not just bridge the clock's power cables to test that theory?That's what I'll do, I ran ot of time and daylight and the dash is fiddly enough to remove in the daylight, let alone at night. Although I did find out last night that I am now so practiced at changing the alternator, I can do it when it is so dark that I can hardly see it. Bo11, you can pay your quid by cheque, postal order or by Access Card.
philibusmo Posted August 26, 2014 Posted August 26, 2014 Despite it still being somewhat deficient in electricity, it is still of for an MOT in about 30 minutes time. I've boshed a fully charged battery on it and it has just stopped raining so hopefully it will manage a whole test without running out of electricity and then have enough to get it home this evening. Wish us luck! phil_lihp, cms206 and Craig the Princess 3
red5 Posted August 26, 2014 Posted August 26, 2014 If it doesn't pass I'm going to take it back to where I found it. KruJoe, Pillock, vulgalour and 2 others 5
michael1703 Posted August 26, 2014 Posted August 26, 2014 What carb does it have fitted? If its a HIF it has a flat bottom Take the dash pot off with its 3 screws and pull the piston out. See what the jet height is by eye because twiddling the screw doesn't always work on the HIFs (I work on them daily) The mixture screw has an 'o' ring which furrs up and sticks, the jet is sprung with a bimetallic spring which will let you richen it but won't always go the other way. Looking down from above, turn the screw anti clockwise and the jet should raise up through the jet holder, get the jet and jet holder flush and then turn the mixture screw two turns clockwise as a base setting, then put the piston and dash pot back on and fine tune using the piston lifting pin on the side eddyramrod and vulgalour 2
philibusmo Posted August 26, 2014 Posted August 26, 2014 It made it to the MOT station, so that's a good start. KruJoe, greengartside, skattrd and 7 others 10
phil_lihp Posted August 26, 2014 Posted August 26, 2014 That's practically a pass in itself. Angrydicky, michael1703 and cms206 3
skattrd Posted August 26, 2014 Posted August 26, 2014 Phil, are we going to get the news shortly or have you left the car to be collected after work?
Danblez Posted August 26, 2014 Posted August 26, 2014 It made it to the MOT station, so that's a good start.Let's not underestimate the importance of this in the MOT passing procedure!
vulgalour Posted August 26, 2014 Author Posted August 26, 2014 Leaving is just as important too, at her last MoT my Princess stalled on completing a fail and then didn't want to restart. I had to push the car out of the testing bay.
Noel Tidybeard Posted August 26, 2014 Posted August 26, 2014 this thread is a little too quiet for comfort
Dick Cheeseburger Posted August 26, 2014 Posted August 26, 2014 I rarely post here, but even I have to comment on this one. C'mon, pass, you bugger! KruJoe 1
eddyramrod Posted August 26, 2014 Posted August 26, 2014 Nails are being bitten up here. My dentist, who I'm seeing in less than an hour, will not be pleased scooping out the debris. C'mon fellas (and Louise) chant: pass pass pass pass pass...
Dick Cheeseburger Posted August 26, 2014 Posted August 26, 2014 C'mon fellas (and Louise) chant: pass pass pass pass pass... Is this me? If so, I'm a hairy chested chap complete with all man parts. I chose my avatar yonks ago as I liked the look of the lass with the Vespa Who is/was she, then? Here she is/was: Annnyway, time to change it I think Has the Princess passed yet? AndyW201 1
Mr_Bo11ox Posted August 26, 2014 Posted August 26, 2014 I’ve just been into William Hills, they reckon its evens on a pass/fail so I put £20 on, I think whatever happens I get £20 back (not too knowledgeable about betting ) cms206 1
philibusmo Posted August 26, 2014 Posted August 26, 2014 I've just heard from the garage. The failure sheet runs onto three pages. That hasn't gone as well as I might have hoped. cms206 1
Wilko220 Posted August 26, 2014 Posted August 26, 2014 Oh. Anything that particularly stands out as a surprise?
vulgalour Posted August 26, 2014 Author Posted August 26, 2014 Yeah but you know how quickly items stack up on those fail sheets. They can take an entire page just to tell you that you've got shit brakes. Angrydicky and Wilko220 2
Dick Cheeseburger Posted August 26, 2014 Posted August 26, 2014 Darn. trigger, cms206, michael1703 and 3 others 6
Mr_Bo11ox Posted August 26, 2014 Posted August 26, 2014 Yes!!! That’s £20 in my hand (I think) cms206 1
mat_the_cat Posted August 26, 2014 Posted August 26, 2014 /\ £19 don't you mean? It's a bugger about the MOT Phil, but hope it's fairly minor stuff. On the bright side at least it hasn't failed on everything, which is usually of some consolation to me.
Parky Posted August 26, 2014 Posted August 26, 2014 Hopefully it's thicko stuff like non functioning ABS, no catalytic converter, and coil springs missing...... Good luck Phil, let us know the damage so we can tell you how easy it is to fix it..... michael1703 and cms206 2
