I used to drive a fleet of those Ivecos.  AFAICS there's no noticeable Ford input, but they're not a bad old tool if the price is right.  My big complaint was the dogleg first (and generally low gearing) and the radio placement: approximately at your left ankle.  Brilliant* ergonomics there!  Oh and the sliding side-loaders had a habit of falling off, but on a horsebox that shouldn't be an issue.
Ford and Iveco are (or certainly were, I lose track) the same company. Ford commercial division was sold to Iveco
I once bought a SWB 35-8 off a bloke in Watford.  He'd owned it for four years, and he genuinely thought it was a four-speed 'box - he was completely unaware of the existence of the dogleg first.  To be fair it had such a low-ratio axle that second was about the same as first on a modern van, and comfortable cruising speed was about 55 - I did wind it up to 70 once but it sounded like it was about to put a rod through the block so I didn't try it again.
I don't mind them to drive though - they ride decently enough for something built on a truck chassis, and they cling on fairly well in corners.  The later 2.8 turbos go pretty well too.  They rot, but no worse than a Transit, and being a proper separate chassis you can get away with a lot that you wouldn't in a monocoque van.
Numberplate obfuscation awards:
https://m.ebay.co.uk/itm/Smart-Roadster/132486114222?hash=item1ed8c9abae:g:3twAAOSwZrhabkgm
Do you think I should ask about the colour change?
"LX54YRL
SMART ROADSTER COUPE 80 AUTO(RHD)
Check another vehicle
Colour
Silver
Fuel type
Petrol
Date registered
29 September 2004
MOT valid until
26 January 2019
Get an MOT reminderwhen the vehicle's MOT is near its time for renewal. (Opens in a new Window) by email or text.
If you think the MOT expiry date or any of the vehicle details are wrong, contact DVSA.
Open All
MOT History
Mileage recorded at test, parts failed or had minor problems
Date tested
20 January 2018
PASS
Mileage
65,287 miles
MOT test number
6105 2005 4067
Test location
unavailable until further notice
Expiry date
26 January 2019
Date tested
27 January 2017
PASS
Mileage
55,378 miles
MOT test number
2693 7072 0549
Test location
Expiry date
26 January 2018
Advisory notice item(s)
Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
What are advisories?
Date tested
4 September 2015
PASS
Mileage
54,365 miles
MOT test number
9593 2340 7718
Test location
Expiry date
3 September 2016
Date tested
17 February 2014
PASS
Mileage
48,525 miles
MOT test number
5968 8834 4087
Test location
Expiry date
16 February 2015
Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
Nearside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Nearside Front Track rod end ball joint dust cover damaged, but preventing the ingress of dirt (2.2.C.1c)
etc. etc.."
Its had no colour change, its still silver!!
Explanation:
Upto around 2007, car colours by the DVLA was defined by the colour of the chassis. The Smart Roadster has a chassis with body panels attached, so you don't see most of the chassis. However the bit is visible is the c-pillar section and windscreen surround. There were two options, standard was black, cost-option was silver.
I believe Lotus Elises have the same thing on their colours.
Explanation:
So why weren't all Citroen DS listed as black?
No idea! Maybe because none of the chassis is readily visible from the outside? Or rules were slightly different back then?
Take back what I said a couple of pages ago about Autoshite bingo full house, here's the real winner
Renault: CHECK
Espace: CHECK
3.0: CHECK
Diesel: CHECK
Automatic: CHECK
Injector fault: CHECK
http://www.ebay.co.uk/itm/2008-RENAULT-GRAND-ESPACE-3-0-DCi-INITIALE-AUTO-6-SEATER-MPV-MET-BLACK-BEIGELTHR/202214557703?hash=item2f14ed4807:g:iFIAAOSwvD5Z~39l
'From the very moment you walk up to this car you know that it is unlike all other people carriers you have ever driven'
'I've not had it checked out so I don't know exactly what the problem could be'
WINNAR
