Bus Shite
Felly Magic
8 minutes ago, Joey spud said:
Anyone know what this ugly duckling is ?
Which do you mean, the Metrobus or the Wright (yes, the lot from Northern Ireland ) bodied Bedford of Maidstone Corporation or Boroline as they regarded themselves...
Yeah the yellow "prison bus" the MCW was my local bus to get home.
Would the Bedford have been as grim to operate as it look ? Bedford or Leyland powered ?
They were Bedford engined, Allison auto boxes. Maidstone seemed to get on well with mediumweight chassis, they operated a few Wadham Stringer Vanguard Bedfords too IIRC.
Looks like CKM142Y, Bedford YMT, so has their own engine. Actually very much liked by small operators as they were a pretty reliable bus / coach, if somewhat "wank" to drive and underpowered. We (the National Bus Company) had some with both Duple Dominant and Willowbrook 'Spacecar' bodies and despite our best efforts they survived quite well, if you ignore having to ask the passengers to get off and walk up the hill because the bastards wouldn't get up fully laden.
Culture shocks abound... what do you mean I have to give change and issue tickets? Where is the second door?!
I NEED TO EXIT THE CAB TO DEPLOY THE WHEELCHAIR RAMP?!?!?!
The yoouffee of today, don't know they were born..
"When I was a lad....".
fill in your favourite Monty Python sketch..
The very first job I did after passing my test was in a Leyland Leopard seven years older than I am... then I graduated onto a manual Tiger 245.
I had a harder start than most my age 😂
Luxury!!!!
That must be the earliest thing I've seen with a Wright badge. They must have been quite a minor player back then?
Bluestar have a tap on tap off system. Nothing unusual there you say. And for many years they have run dual doors at least on the double deck fleet. But some buses have the tap out machine by the rear door as you would expect and some of the second hand ones have it by the front door which makes no sense at all. So those of you with physical tickets get off by the rear doors and those using tap on tap off have to get off at front and battle through the people getting on.
And now the new batch of Enviro 400s are single door anyway. It's very inconsistent. I don't see why we need to tap out when it's a £2 flat fare anyway. I guess it won't be £2 forever but whilst it is it can't be that hard to ignore the tap out bit.
On 12/05/2024 at 20:16, Zelandeth said:
Seven dead apparently.  What the actual hell happened there?  You'd have to think catastrophic brake failure from the looks of it.  Which simply Should Not Happen on a vehicle like this.
I don't know how true it is, but the driver survived. Apparently his previous shift was 20 hours.
Given my - admittedly only on preserved vehicles - experience with Bedfords, it will probably have been slow but pretty much utterly dependable.
Duple Dominant II on a Bedford Y series would still be in my lottery win garage.  STA380R was pretty much solely responsible for my interest in all commercial vehicle type things, so that combo has a very special place in my heart.  Also the first coach I ever drove.
Sadly that wouldn't surprise me.  Something happening to the driver just seems more likely with the way that unfolded.  Most modern vehicles are smart enough to cut power even if the throttle pedal is physically jammed if the brakes are applied.  In the case of such a dual input situation, priority will be given to the brakes and power will be cut.  I guess that wouldn't do anything if something happened to the fuel pump itself...but this is all speculation.
I may have accidentally found the best public transport system I've ever come across, and it's bizarrely in Mallorca.
Get ready for a very underwhelming post as I didn't take many photos!
Here is the very unusual underground bus station in Palma which took me ages to find and was very confused by Google Maps until I realised it literally was underground - as was the small train station (which sadly I didn't have enough time to use).
https://www.tib.org/en/inici is the PTE and its ticketing and route planning system is not only very cheap but is an exemplar digital public transport information system. Lots of kudos there. The busses are all Scania from what I could see and pretty much brand new and looked very nice and colourful. They were all very appropriately optimised for their routes -  mix of low and high floor including a very unusual high floor bendy bus which took me to the airport on my way home.
I was on a cycling holiday and an additional surprise highlight was our lunch stop in Soller where the café we randomly picked had a vintage tram go past every five minutes!
Also saw a HMMVW and a weird Chinese car
  • Like 7
16th December 1978 was a miserable morning and it wasn't going to get better or warmer, as this 1963 ex East Midlands Willowbrook bodied Leopard, fitted with manual transmission, no power steering and those BFO handbrake levers was my enjoyment* for a shift.
On 06/05/2024 at 15:38, SunnySouth said:
Bit of Portsmuthian shite for you all…
Firstly, a batch of the new Wrightbus Kite electrolical thingies, sat in the current Hilsea parking area. I rode one of these the other week, first electric bus I’ve been on. I was pleasantly impressed, I have to say! I’d much rather see these in use than Chinese BYD and Yutong crap.
Hilsea depot has for years parked some of it’s stuff in the yard of the local newspaper across the road, I believe the whole site has now been acquired for a brand spanky new depot and it’s currently mid-demolition, with the buses sort of dumped safely out of harm’s way down the back.  A Streetshite looks on in envy at the sort of decent, bombproof heavyweight vehicles that Wright used to body a few years ago! These Volvos are the current driver trainer fleet down here, seem to be a fair few of them. MX55 plates, not local.
And lastly, an E200 sniffs the air having been serviced in the ‘proper’ former Southdown Hilsea West depot building, before a fittery type individual rags the shit out of it around the block and across the road to the afore mentioned parking area!
If I’d had known you were coming to my work I’d have brought the Rolls in 😆
There has been a fair bit of investment in urban public transport in Spain. By urban I mean non long distance as run my ASLA or Flexbus.
The Lynk & Co car is a Chinese/Volvo brand. I think the only factory is in China.  The company are getting more and more popular. This is the Spanish website for them https://www.lynkco.com/es-es
There does not seem to be many agents for the cars. But buried in that website it says one one the pick up points is Palma
I was in Yorkshire back in the 70's somewhere round Halifax, I think, and I was on a double decker and we came down a hill where, at the bottom, was a cross road with traffic lights and we hit it on the red. Off up the other side and it stopped about half way up and lots of people got off. I'm upstairs and thinking, 'fuck me that's a busy bus stop'. Then the ticket bloke came up and, basically, asked me to join the rest walking up the hill while the bus ground it's way up where we all got back on. Seems that if you get a green at the bottom it can make it if not it's walkies time. Yorkshire eh!
Gateshead and District Atlantean on the left.
Below is an 1950s ad for Reginol engine oil as 2 Norwegian Scania buses passed 400,000km without an engine overhaul or reboring on Reginol oil. Reginol oil was then used motor oil that had gone through a process and was then sold as new oil. According to what I read from several sources, this were terrible stuff, but still 1950s engines lasted to high mileages on this.
A nice hilly route for you and that delightful* conveyance too!
Have to say it’s changed a bit since it was my work! ;) No shagged minibuses dumped in the compound out the back, and no Evening News employees parking their sodding cars in the bus area in the yard!
Old Edinburgh bus now in Australia and has been converted to a motorhome.
Sent from my SM-A145R using Tapatalk
Back to life in the provinces. Busy* shift last night, 1656-0102 on the X25.
On 13/07/2023 at 22:24, mk2_craig said:
Potential bus futureshite.
Mellor Sigma.  I had a sniff around it today, either the industry will love it and they'll shift bucketloads of them, or it'll turn out not to be so well screwed-together with total sales of about 7.
I was wrong, it appears that Mellor have given up after registering only five of these.
From last week's Faversham festival of transport (I didn't go, just seeing some pics), probably travelled on this bus when it was in service.
443719205_834222488740543_74981158900388
