BorniteIdentity Posted October 25, 2021 Posted October 25, 2021 I think I’ve found a MK1 Sierra tow bar which I would like to add to a MK1 Sierra. Obviously there is no provision for electrics, so I guess one has to go splicing. Can anyone tell me what I’ll need to make it all work? Perhaps you have experience of adding a tow bar to an old nail? Vehicle electrics are my least favourite, so I may just find an auto electrician to do it on my behalf - but any guidance would be gratefully appreciated.
MikeR Posted October 25, 2021 Posted October 25, 2021 never actually done a tow bar , the one I had on the 240 I used as a parking sensor .. paulplom 1
NorfolkNWeigh Posted October 25, 2021 Posted October 25, 2021 Piece of piss, just scotchlock the wires to the right hand wires running into the tailight, plus one wire across from the left hand indicator. Probably not how you SHOULD do it but I never had one catch fire . eddyramrod 1
sheffcortinacentre Posted October 25, 2021 Posted October 25, 2021 That's what the "professionals" do or at least before a plug was fitted in loom.
Mr Pastry Posted October 25, 2021 Posted October 25, 2021 32 minutes ago, NorfolkNWeigh said: Piece of piss, just scotchlock the wires to the right hand wires running into the tailight, plus one wire across from the left hand indicator. Probably not how you SHOULD do it but I never had one catch fire . You are also supposed to fit a heavy-duty flasher unit which will cope with the extra bulbs on the trailer, these are readily available but you may get away with the standard one. St.Jude 1
Barry Cade Posted October 25, 2021 Posted October 25, 2021 My specialist subject now 😆 Yup, scotchlocks..you can use connectors, or solder, but scotchlocks are fine if used properly and its dry.. Dead easy on an old Sierra. You will need to wire up both tail lights separately,so 2 wires to the other side.. White wire to a good earth.. don't use the tail light earth, find a bolt or stud on the tail panel and clean off the paint.. Sierras were bad enough for disco lights back in the day.. You should fit a tell tale or beeper to let you know the indicators are working.. usually come with the kit. If its a Ghia ( or Cosseh..😄) with the bulb failure warning, you'll need a bypass box. White- good clean earth. Black- left tail light Brown -right tail light Green- right indicator Yellow -left indicator Red- brake lights, either side.. Blue- fog light.. dome, eddyramrod and Royale80 3
wuvvum Posted October 25, 2021 Posted October 25, 2021 24 minutes ago, Barry Cade said: You will need to wire up both tail lights separately,so 2 wires to the other side.. I tend to just bring a wire in from one tail light and then use a short bit of wire to jump across to the other tail light terminal on the plug. (Obvs as a professional I realise you'd never contemplate such a bodge.) Agree though, wiring up a towbar on an old motor is a piece of piss - none of this 7-way bypass relay bollocks you get with moderns. Barry Cade and UltraWomble 2
Barry Cade Posted October 25, 2021 Posted October 25, 2021 3 minutes ago, wuvvum said: I tend to just bring a wire in from one tail light and then use a short bit of wire to jump across to the other tail light terminal on the plug. (Obvs as a professional I realise you'd never contemplate such a bodge.) Agree though, wiring up a towbar on an old motor is a piece of piss - none of this 7-way bypass relay bollocks you get with moderns. If you do that, if 1 fuse goes, you lose both taillights though.. Try a modern 13 pin VAG with no trailer prep. You have to remove the body control module from under the dash,run the wires along the whole car then split the big 60 terminal multiplug, then fit tiny pins into the correct position in the plug (s). Then code in the park sensors, cruise control, abs,etc . It's quite a job!
Angrydicky Posted October 26, 2021 Posted October 26, 2021 They're not the cheapest, but Watling Engineers in St. Albans do supply and fit if you're so inclined. They've got an amazing back catalogue of obsolete towbars and can make one for pretty much any old crock to order. BorniteIdentity, cort1977, Barry Cade and 1 other 3 1
Tommyboy12 Posted October 26, 2021 Posted October 26, 2021 Just to add. If you do have problems with the flasher relay not being man enough the simplest way to sort it is to fit LED indicators to the trailer. I wired up a Mini with a towbar in about 20 minutes without the use of scotchlocks. If you have basic electrical tools like crimps and strippers its pretty easy to do a better than bodge job.
BorniteIdentity Posted October 26, 2021 Author Posted October 26, 2021 25 minutes ago, Tommyboy12 said: Just to add. If you do have problems with the flasher relay not being man enough the simplest way to sort it is to fit LED indicators to the trailer. I wired up a Mini with a towbar in about 20 minutes without the use of scotchlocks. If you have basic electrical tools like crimps and strippers its pretty easy to do a better than bodge job. Cheers man. I've been thinking about getting an LED lightboard for some time now - mainly as the bulbs in my ERDE thing are forever getting wet and blowing and just being shit. A £30 led board could live indoors and be a lot more useful, so if it doesn't work I'll probably go that way. Ta!
sierraman Posted October 26, 2021 Posted October 26, 2021 Above all make sure its bolted to solid metal...
wuvvum Posted October 26, 2021 Posted October 26, 2021 I just fitted cheapo eBay LED bulbs to my existing light board - worked out a lot cheaper than buying a new one. Tommyboy12 and BorniteIdentity 1 1
groovylee Posted October 26, 2021 Posted October 26, 2021 not sure if they still do it, but wilmonds in hitchin used to fit towbars. GT towing in hatfield / welwyn definitely still do. BorniteIdentity 1
BorniteIdentity Posted October 26, 2021 Author Posted October 26, 2021 Right - got a new towbar on eBay for £40 which I'm happy with! Looks from the pictures like I need a separate tow ball as there doesn't seem to be one in the pictures. Does anyone have one lying about? A new one seems a bit daft on this old heap. I will then probably employ an auto electrician to do the wiring so it's done well - rather than my usual tactic of having a go, fucking it up and then going cap in hand to someone who knows what they're doing who can look on smugly!
groovylee Posted October 26, 2021 Posted October 26, 2021 12 minutes ago, BorniteIdentity said: Looks from the pictures like I need a separate tow ball as there doesn't seem to be one in the pictures. Does anyone have one lying about? A new one seems a bit daft on this old heap. i think i have a spare towball, might even have the bolts. i'll have a look at the weekend when i get home, you can pick it up with the oil when we finally end up being in the same place at the same time lol Lee BorniteIdentity 1
BorniteIdentity Posted October 26, 2021 Author Posted October 26, 2021 4 minutes ago, groovylee said: i think i have a spare towball, might even have the bolts. i'll have a look at the weekend when i get home, you can pick it up with the oil when we finally end up being in the same place at the same time lol Lee Thanks man. Be good to trot over for sure. groovylee 1
Jack D Posted October 26, 2021 Posted October 26, 2021 15 hours ago, Angrydicky said: They're not the cheapest, but Watling Engineers in St. Albans do supply and fit if you're so inclined. They've got an amazing back catalogue of obsolete towbars and can make one for pretty much any old crock to order. Watling Engineering seem to have a towbar for anything. I rang them about a year ago after several pints and now I’ve got a towbar for a BMW 840 in the shed. Only one they’ve ever sold apparently. Arrived in about 4 days. How’s that for service! Barry Cade, Angrydicky and BorniteIdentity 3
wuvvum Posted October 26, 2021 Posted October 26, 2021 Now all you need is a BMW 840 to go with it... Barry Cade 1
mat_the_cat Posted October 26, 2021 Posted October 26, 2021 On 10/25/2021 at 11:40 PM, Barry Cade said: Try a modern 13 pin VAG with no trailer prep. You have to remove the body control module from under the dash,run the wires along the whole car then split the big 60 terminal multiplug, then fit tiny pins into the correct position in the plug (s). Then code in the park sensors, cruise control, abs,etc . It's quite a job! Getting ready to string out your new job I see BorniteIdentity 1
Barry Cade Posted October 26, 2021 Posted October 26, 2021 13 minutes ago, mat_the_cat said: Getting ready to string out your new job I see 😆 New job is also my old job.. know what's coming!. mat_the_cat 1
