16 hours ago, egg said:
https://www.facebook.com/marketplace/item/755103402948035/
I keep hoping someone here will buy one of these miseries.
392787058_10232837428699245_501336031260
Dawlish - by Sean O'Betjeman
Bird-watching drivers along the old sea wall,
Down here at Dawlish where the slow Citroens crawl:
Low tide lifting, on a shingle shore,
Long-sunk islands from the sea once more:
Red cliffs rising where the wet sands run,
Gulls reflecting in the sharp spring sun;
Pink-washed plaster by the garage door,
Ilex shadows upon the folding roof:
What interiors those names suggest!
Except you can't get in because the doors are ****ed.
12 hours ago, scooobydont said:
Wonder what is up with this? It's had a few bob spent on it
https://www.ebay.co.uk/itm/126340999207
"Currently a non runner. Recently it failed to start. We could hear clicking from the lower crankcase. The crank is turning. It will need to be transported as is not drivable.
Housed at CP Garage Services – Alfa specialist in Dundee."
Sounds a bit ominous ...
  • Confused 1
  • Sad 1
19 minutes ago, Stinkwheel said:
New shells available? If new then not a case for ring ring surely?
No you're right, not really like an old Mini is it!
Depends how honest the rebuilder/restorer/bodger is i suppose.
I was always told if it was a new item of original design with paperwork to prove it then it could keep its identity (as long as axle, engine etc were also used to keep enough DVLA points)
Having said that, its all seemingly a minefield anyway, depending on who you speak to at the DVLA
6 minutes ago, egg said:
Who needs Viagra? Absolutely beautiful.
Passed my driving test in one of those. Damn im old
11 minutes ago, wuvvum said:
If my experience is representative, it'll struggle to do 30mpg, and then it'll shit its DPF and head gasket. Every month or two it'll need a replacement brake caliper when one randomly sticks on. EGR valve will need cleaning out roughly every 6 weeks but at least it's a very, very easy job.
Absolute pile of shit
1 hour ago, grogee said:
That's a good price, I wonder how rusty it is? Either it's had welding or it's been taken to a 'sympathetic' tester.
I mean the seller reckons it passed with "no advisories" so who knows the truth
