2 hours ago, hairnet said:
@wuvvum - wuv i nearly thought this was yours
Wrong model, wrong colour, I'm not on Facebook and mine is sold, but otherwise it's spot on.  ;)
https://www.autoscout24.com/offers/opel-kadett-1-2s-gasoline-blue-856264ad-a54a-d468-e053-0100007f6897?cldtidx=8&cldtsrc=listPage
hmmmm
2 hours ago, Fumbler said:
EDIT: Seems the image has squashed itself when the post was made. Images on the ad itself are of the correct aspect ratio.
Did you buy your computer from @Cavcraft?
7 hours ago, egg said:
Bit of a barg that really, 2.0 Zetec could net you most of it back but that would be a huge shame as these are fantastic cars.
I shouldn't be surprised when I heard that Ford got almost to the launch stage of the sierra replacement, decided it was wank and produced the Mondeo instead, a lesson they learnt from the awful mk5 escort.
These are truly fantastic cars, a huge step up in quality at the time. I can remember the line that made the brake discs for these having to auto gauge (marposs) check every part that came off when otherwise it was left to human intervention, the tolerances were way beyond anything I'd ever witnessed before for a brake disc. A new engine line factory extension was built to house the Zetec and again the focus on quality of parts increased hugely.
Nice rolling project
Description
I am selling a VOLGA GAZ 24 1979, on the move, everything paid for.
The car is a project I don't have time for, the bike is in excellent condition. A
list of what I have available as spare parts for the car bought over the years as I was looking to buy only USSR parts and 95% are such
I've done a lot of things in the car. Starting by replacing the cabin with a newer one from the same modification even the same color car, repairs to the cabin. New muffler and front pipe, replacement of the power steering with a new USSR, replacement of the petrol pump, new cables, spark plugs, replacement of the head gasket, replacement with new brake cylinders, new two cylinders of the clutch, replacement of the rubber hoses on the cooling system, carburetor replacement. Full servicing of the starter, new delko, changed level gauge for gasoline, replaced front and rear shock absorbers with new ones. head valves. Repaired dynamo and replacement with a new relay. Repaired water tank for windshield,
The following parts must go with it:
rear axle old
front axle old
rear cover used
front grille
4 doors used
3 doors new on primer
seat set
Gearbox new
front fenders new on primer
front internal fenders new on primer
rear fenders new on primer
rear mask new primed
rear new apron under bumper
rear bumper used
new water pump
towbar used
Steering wheel used
grille above the wipers with wiper arms and 3 electric motors
New sector box with steering rod
new rear lights
new turn signals
New set of crankshaft bearings
new steering knuckles
new pads suspension
carburetor used
6 pistons new
8 brake pads new
battery cover new
device clutch upper new
distributor cap new
set valves
fiber water pump
spring bolt with pad
shank in bearing /
axial bearing of the shank
gear wheel reverse speed parasitic
ratchet crankshaft
pad spring and some bushing, I guess for the piston bolt
engine brackets
relay headlights
door trim kit as new
alternator relay
parking brake cable new
new mirrors left right
rubber elements on the body and suspension
new left and right gog for front bumper
ferodo for pads 12 bg
new brake hoses
new chrome rings for headlights
new lighting fixture for number
New distributor for brake system
new turn signals
ceiling interior
Signboards two Volga
6 pieces new rubber mudflaps
new door locks with keys
new gklyuchalka hood
book gas 24
two rear reflector mask
Armrest for front seats
set seats
Brand new antenna working
skirts external and internal
NEW fog lamps chrome
two lights for rear side pillars
turn signal lever new
Automatic front seat belts used
Leather cover for front grille used
new two brake drums
new Hebel
new two steering tips
Anyone interested in this hydrolastic suspension pump? (Sorry if in wrong section, rushing to go to work but hope this goes to a good home)
www.ebay.co.uk/itm/264846633942
12 hours ago, Wack said:
Bugger wrong thread ?
Also not a Combine....
