https://www.ebay.co.uk/itm/1998-Renault-Megane-1-6-Scenic-Alize-Ltd-Edn-Auto-76000-Miles-Spares-repair/233148271804?hash=item3648b84cbc:g:-vIAAOSwAvFcdlJA
'failed MOT due to some minor welding'
  • Oil leaking excessively from engine (8.4.1 (a) (i))
  • Nearside Front Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced (6.1.1 © (i))
  • Offside Front Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced (6.1.1 © (i))
  • Nearside Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced center (6.1.1 © (i))
  • Offside Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced center (6.1.1 © (i))
  • Nearside Rear Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced (6.1.1 © (i))
  • Offside Rear Inner Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced wheel arch (6.1.1 © (i))
  • Rear Exhaust system insecure (6.1.2 (a))
I still can't deal with modern cars failing MoTs on serious welding, I thought cars now lasted forever and the electric gubbins was what killed 'em. Looks mega clean on top that, too.
I have known of that ropey Espace for years, it's lived near Barnes for what seems like forever. Someone should buy it and give some of us a break from buying evertyhing
These look quite compact amongst today's traffic. I've been seeing quite a few about recently and pondering the possibility. As you do.
This one is in the south of France. €2900.
Hopefully it has been there a long time so as to avoid our salt.
XJ-S were just made for wafting across Europe........
https://www.leboncoin.fr/voitures/1580044757.htm/
Cavraft, I hold you entirely culpable for the fact that I've just put that on my watch list.  :-D  I do have a real want for this, even if just for a short while.
https://www.ebay.co.uk/itm/Volvo-940-2-3-lpt-SE-5-DOOR-ESTATE-PETROL-MANUAL-P-REG-22-STAMP-SERVICE-HISTORY/254152934054?hash=item3b2cb202a6:g:R7gAAOSwdzBcf7T1
Alright. I'll have it off you when you're finished with it!
