Brown as fuck: 2001 BMW X5 3.0 - Exxon5!
Baker Street achieved - we won’t be needing Sherlock to work out what I’ve bought unless he has a fault code readerattachicon.gif5E1B4341-A6ED-467F-9232-711FB6780E55.jpeg
Winding your way down on Baker Street
Engine lights in your head and dead on your feet
Well, time for another crazy day
Your beemer will drink the fuel away
And forget about everything
This city makes you feel so cold
It's got so many people, but it's got no soul
And it's taken you so long
To find out you were right
When you make time to collect more shite
SAX SOLO
The build sheet is probably under the rear seat squab if you can be bothered looking .
Just found the invoice for £41,345.45
Adjusted for inflation that's the best part of £64000.
For the 40,000 service.
The mahogany leather etc is listed on the invoice :D I’ll scan it at some point
Surprisingly they only took a £1000 deposit for it - I would’ve wanted far more to not be lumbered with that colour choice if I was the dealer!!
Lovely motor, I bet it wafts. I'd feel like a hi-rollin shite playa in that.
But 16 mpg. Six teen m p g !
Sorry but the paint and interior combo is fit.
Found a receipt in the history for “investigate why horn sounds at random intervals” resulting in work to the wiring / clock spring area, couple of years ago.
Have they damaged the wiring for the cruise control switch I wonder.....
"Clock spring"
Fnarr Fnarr
Or wrong clock spring installed that didn't pass through the cruise button wiring?
Is this an auto or manual? If manual, check clutch switch.
Possibly your DS150e will hopefully give live read out of the cruise button states. That'll tell you which buttons are working.
I had an X5 in for paint back in 2009 but the V8 version.
I must say I loved it, I had my ML at the time but this felt like a totally different car, more like a car really, sporty and handled great.
Only issue was MPG, WOW, still the thirstiest car I've driven to date, single figures pretty much everywhere, can't say I wasn't making good progress though.
I like the X5, especially from 2008 on (E53???)Sure it has a chav reputation but who cares? I still think it's less of a liability than a rangey of the same era!!!
Pre 2007 - E53 - the last acceptably good car made by BMW - just a big E39 525ix really.
2007 on E70. The epitome of where it went wrong.
A dodgy person would send it in for the airbag recall, then phone them the next day to complain that the cruise control isn't working...
Any signs of 4x4 tech STOLEN from Land Rover?
What, like a removable rear propshaft for increased mpg?
Any two bucket wronguns got an opinion on how to sort the windscreen out? It was swirl marks all over like it’s been cleaned with a scourer, so does the rear window. Fine during the day but a bit of a pain at night.
My insurance company has a £70 excess on "normal" cars but £140 for my X5 as "it is a big screen".
It does have the light and rain sensor in it and mine is an 8 pin version. The early ones were 4 pin apparently.
It's very hard to polish without leaving new, interesting swirl marks in.... Which you only see at night so you don't realise you made it worse until you're out and about.
Fault code reading session #1
Objective - investigate PDC and cruise control
All of the rear sensors are reporting open circuit so I assume there is a wiring fault. Front sensors work fine.
Cruise control buttons on the wheel work as expected and the light on the instrument cluster works too
There was a “Multifunction steering wheel - interface” code on the engine/standard OBD fault codes though.
Along with “exhaust camshaft sensor - signal” but we won’t talk about that here
For cruise, push I/O button to switch it on. You should see the symbol on the screen.
Press the "+" button to set the speed, and the "+" and "-" to adjust it.
The top button that looks as though it's to set it is actually to reset it if you brake or go above the set speed.
