HMC Comings (sherpa) and goings (morris)
22 minutes ago, timolloyd said:
Loving the Shadow. Always makes me think of Charlie Hungerford.
Charlie Hungerford had a Cloud - it was wedding white though.
To be honest you could probably improve the value just by respraying the black tidemarks under the bumpers white. Even if you use Smoothrite or something it will look instantly look better for a 6 footer view or in photos.
If it’s got a little bit of cream in the white, I can recommend Fiat ‘Bossa Nova’ white, it’s 97% white but ‘not quite’ in the words of 1980s Dulux ads. Easily available in Halfords as it’s a standard 500 colour.
If it’s full on WHITE AND NO MESSING than whatever 80’s Fords were painted in will do the job. I remember ‘Diamond White’ on my Mk4 Cortina but it had probably been renamed for the mid80s heyday of the XR3 & XR4x4.
Because I am a bit of a hoarder, I have a Ford brochure stash to hand.
Diamond White is the shade named in both a 1979 ‘Cars’ catalogue and the Mondeo launch brochure so there are probably thousands of gallons of the stuff still about on factor’s shelves.. It is a proper old school cop car/bathroom porcelain white.
4 hours ago, HMC said:
Could  be my imagination but this is getting better with use, the brake pedal feels more positive and its starting instantly. The handbrake has stopped working but the mechanism is free and in good order, but the forward cable to the pull has snapped- so an easy fix.
Useful to work out what it's got in the fluid reservoir.
These require specific brake and suspension fluid which is now out of production in it's original form but has been remanufactured.
It's explained here:
https://www.flyingspares.com/news/homepage-featured/rr363-brake-fluid.html
The bugbear with these early RR systems is the RR363, as with all DOT3 & DOT4 fluids, is hygroscopic, which means that the fluid will absorb and chemically combine with water from the atmosphere.
Which is part of the reason the systems fail due to water/corrosion. Which is why these cars thrive with use to keep everything moving otherwise they do seize up. They require regular flushing.
Workshop manual pdf is here:
https://rrtechnical.info/sy/tsd2476/8.pdf
In 1980 Rolls-Royce took a step forward when they changed from brake fluid to LHM mineral oil - to power the braking and suspension systems - which is not hydroscopic - but is not for these early cars.
Worth having a look and having the right stuff in stock.
If the system fails - they do lose their brakes pretty quickly (check the twin warning lights are actually working on start up) and if these come on  - on the move stop immediately...
I'd also get the handbrake working...
My friend Toby has one of these - he lost his brakes...but was ok.
The Spirit of Ecstasy needs to be GOLD. 😂
Aye that's a good reminder actually, remember that these are like hydraulic Citroens in that there is no brake servo etc...you are simply switching on a hydraulic circuit to power the brakes - no system pressure = no brakes whatsoever, no matter how hard you stand on the pedal.
I've made the mistake of rolling Craig's one out of the garage before the pressure had come up one day and very nearly went through the fence.  He thought it was hilarious mind you...thank god the steering is so light that I was able to spin it round fast enough to get round the corner.
I didn't know the earlier cars didn't use LHM, every day's a school day.
  • Agree 2
I do think that tide of underseal needs raising somewhat and some really rough filler repairs with fish eyes grinning through the Poundland Diamond white paint.
Ford Diamond white predates Mondeos! Mk 2 Escort, maybe even earlier than that.
9 minutes ago, lesapandre said:
Low coolant of engine temp warning light?
Coolant light, but coolant level ok. One of a number of electical gremlins 😂
On 11/01/2024 at 18:39, Zelandeth said:
If it weren't for being vastly over committed here already I'd probably be getting an itchy finger asking to add myself to the queue as a Roller has always been on my list - albeit a slightly later one (I've spent many happy miles wafting around in a friend's mid 80s Silver Spirit) than this, but I'd definitely not turn it down because of details like that!
I know of a relatively cheap late 80s one that needs some love if you're keen!
On 13/01/2024 at 17:22, HMC said:
I take it that is ms_HMC at the wheel
The photos made me wonder what the equivalent-era Soviet drive shot could have been.  OK agreed, 'prestige' cars didn't really exist, but just for the sake of it, had a look
ZIL 117 ?  The SWB one.  With bonnet ornament.
GAZ-14 ?   Needs a bonnet ornament.
76765513_2811539202245639_3304087442818072576_n.jpg.19802af992bdaead9b251babe7547510.jpg
TATRA 613 ?  This lady looks like she wants to scream the yaichki out of the V8
Even in export-spec, GAZ-24 still stuck with 4 cylinder engine, so probably not
Извините, мне просто было интересно.
I wonder if there are any ZiLs in the UK. Always found them fascinating.
I thought these also had a conventional master cylinder backup or was that only the Silver Spirit?
I am loving this RR. So many of the cars on this place are hovering between scrapman and salvation but few are this glamorous.
  • Agree 1
Same. I wonder if the Russian embassy here ever imported and used them.
Meanwhile on the ropey ‘shad front, we all know its received a generic, demeaning and tacky; but at the same time quite glamorous and accessible wedding white blow over…… but in what?
As a comparison of factory whites in the works car park….
My money is on the old ford diamond white (bottom of pic) and the mini looks a bit too cream?
Or what about white van man white? after all, when it started getting the bride to the church on time, it became a trades vehicle as well…
  • HMC changed the title to HMC- Silver ‘Shad BLOW OVER what with?
On Soviet luxury barges, some of these GAZ ZIM bellow were sold in Norway, some went as taxis while some were used by our authorities.
This was the Soviet Embassy car JLM 555 photographed 1956.   It is a ZiS 110, a reverse engineered copy of the 1942 Packard Super Eight.  ZiS became ZiL in 1956, so it is by lineage, a London Embassy ZiL
Thought to be this one, raced Firecracker 2001.
314409362_480656897377034_2610643948148659434_n.jpg.9c14da62788f093aa01b94aa2d1861f4.jpg
This (no later than 1960) GAZ 12 ZiM was raced 1992 and said at the time to be an ex-Diplomat car.  Well ok, they all were 'Diplomat' cars, but how and why did it arrive in UK otherwise.  Possible film set maybe, who knows
I appear to have invaded the thread sorry.
  • Sad 2
On 13/01/2024 at 17:26, lesapandre said:
Low coolant or engine temp warning light?
Guess the warning light bingo. Varying degrees of expensive fun*.
My Dad has owned his T-Type for 35 years. He long thought that white wasn't actually a factory colour (and I see from your posting that yours has had a colour change from original), but according to this:
Most frequently sold colours -rrsilvershadow.com
you could have your Shadow/T-Type painted white from the kick off. Could it be that your car was painted an 'official' Rolls-Royce white?
It's really nice to see Shadows in use. I've had two (well T-Types, but I'm splitting hairs.) An absolutely superb '68 (now in Holland and sadly now not so nice) and a complete shed of a '71 which I took to pieces. For the latter, despite it being totally irredeemable, I still feel dirty that I parted it out (to use an Americanism.) Here it is before I'd sold bits:
They are magic in a way that is hard to describe. Yes, the steering is vague, parts prices that will wipe out your monthly salary in an instant and fuel economy only matched by a tank, but just the waft factor alone makes up for it. Anyway, nicely bought and I'm following this thread with great interest.
You couldn't really buy most of them if you were a normal Soviet citizen so it's kind of moot and you certainly didn't have a driveway.
The GAZ was really the top car you could get as a normal person and in cost:salary ratio would've been (I suspect) more expensive to a Soviet citizen than the Rolls-Royce was to a UK citizen and with a longer waiting list. So that's probably the closest comparison.
My bet would be enamel tractor paint. Cheap, hard wearing and easy to paint.
It's really nice to see Shadows in use. I've had two (well T-Types, but I'm splitting hairs.) An absolutely superb '67 (now in Holland and sadly now not so nice) and a complete shed of a '71 which I took to pieces. For the latter, despite it being totally irredeemable, I still feel dirty that I parted it out (to use an Americanism.) Here it is before I'd sold bits:
They are magic in a way that is hard to describe. Yes, the steering is vague, parts prices that will wipe out your monthly salary in an instance and fuel economy only matched by a tank, but just the waft factor alone makes up for it. Anyway, nicely bought and I'm following this thread with great interest.
Great back story- so you grew up around them?
Ive tapped up the RREC and asked for the records they have, so im looking forward to finding out more (soon hopefully!)
I suppose yes. Dad bought his T-Type when I was 15-years-old. He'd always fancied one and it was owned by the MD of the company he worked at. From memory it was £7K which is £18.5K in today's money. The icing on the cake was a number plate he'd accidentally ended up with when buying a Riley as a student in the 1960s. The Riley (RMF) was advertised at £20 plus £20 for the number (it's a three letter combination followed by a one). Anyway, during the test drive, the owner managed to put the Riley through a hedge making a mess of the wing in the process. Supposedly the owner got out and said to my Dad that he could have the car and the plate for £20. Anyway, the plate has been on the Bentley for most of the 35 years.
Various things have been done over the years including the obvious stuff with suspension, brakes, repairs to the rear bumper corners, some bodywork. It's got 134K on it and generally very tidy if not immaculate. He's not particularly precious about it as this photo illustrates (we were rebuilding my Land Rover's engine):
You mentioned the RREC. Yes, the records are definitely worth getting (if not a little pricey.) Dad's came with some interesting 'extras'. Firstly it has a roof rack with a matching green cover! There are screw fittings mounted to the roof. It also has opening quarter lights both front and back plus 'cotton reel' rear head rests and an unusual indent in the rear parcel shelf (presumably for a hat.) I think the paint is possibly a bespoke choice - known as Smoke Green Valspar (I could be wrong on this one.)
My '68 was an absolute gem and highly original. I bought it from Baron's auction in the mid-2000s when I had my phase of buying classics with my house deposit money. To add to the fun I always drove my new purchase back home. I think this one decide to throw one of its brake warning lights halfway round the (London) South Circular. You can see it here (UK photos were actually mine):
Bentley T1 #4179 - www.rrsilvershadow.com/
I actually managed to make a slight profit on it which must be some kind of feat. Lol. It is a rather rare colour - sage - which was a Silver Cloud colour originally and didn't last that long into Shadow production. It's one of the very few cars I miss. To my mind the early cars really are spot on, in particular the interior with its 'Chippendale' dash.
Good luck with your one. No matter how short an ownership I really think it's worth everyone having one if you're into luxo-barges. Nothing quite compares, although an early Spirit or square headlight Turbo R certainly tickles.
As an aside, hasn't there been a bit of a bust up at the RREC?
