Shortly after this meeting I went to reverse into a parking space outside my flat and the bloody thing stalled and refused to restart. I didn't want to crank it over masses as the starter is outrageously loud and it was midnight so I pushed it into it's space. My back hurts now.
For the lazy and those weak of limb; stick it in gear and crank the starter, if the road's reasonably flat it doesn't put much strain on the starter over and above that of spinning the engine, just don't do it for more than 10 seconds at a time with a minute or 2 between for cooling down. This has got me out of a few places where pushing wasn't an option and ZOMGdeathtraffik! was an issue.
Tried to get the Civic roadworthy today.
Wrangled a mate in to help bleed the brakes, got them working although I suspect the O/S/R disc might be warped.
Went to reattach the handbrake cables to find they were seized, lovely. Gave up on them.
Then tried to jump start it with the Acclaim.
No luck at all, starter churns for half a revolution and then the electrics die. If the Acclaim is disconnected the Civic's central locking won't even work. I assume the battery is deader than a dead thing on international dead day.
Thank fuck I have some actual working cars...
Parents and girlfriend are of the opinion I should just scrap it but I really need to make something from it's sale. Problem being the MOT is up at the end of next month and the insurance needs renewing on Sept 12th, more shit that I can't actually afford.
Sensible head. I'd say bin the Honda. Make sure it's definitely the the battery, see what it needs for the mot and either sell on with a year's ticket or go the spears & reapers route. If the Dolo and Acclaim are proving to be reasonably reliable transport then put the money into them for improvements*
Silly head. I'd say bin the Honda. Make sure it's definitely the the battery, see what it needs for the mot and either sell on with a year's ticket or go the spears & reapers route. Then enter many roffles.
Stupid unreliable Honda.  What you need is MORE TRIUMPHS.
Take the Honda to the bridge Captn and move on. You've never liked it.
It's now a fund-eating distraction, esp if you're on a seriously limited budget.
If the Civic has timing belt history then it's probably worth investing in. High spec models of this age with belt history and long ticket seem to get offered for about a grand. If it doesn't then it's going to be a more difficult decision whether just to cut your losses and run. Battery, cables and test are going to be at least £150 plus whatever the test throws up.
I'd be tempted to try and find a scrapyard battery for £notmuch and then see if you can get it driving to assess what else it needs. Discs, tyres, exhaust could easily turn it into bridge fodder.
I had the timing belt done at around 70k IIRC, exhaust is a stainless one fitted a couple of years back. This was the MOT from 6,000 miles ago:
The original plan was to wing it up at £800ish to offset the Acclaim purchase. Now the fucker has been sitting for an age and has fuck all MOT left I'd be happy to get anything over scrap/WeBuyAnyCar money, but I need to actually get the thing driving.
My plan is indeed to find a scrapyard battery for £notmuch to achieve just that. My issue is limited time and money means that cars sit for ages until I fix them, never terribly good for their reliability...
Ze Civic, it lives!
I'd love to say I now have three working cars, but the mighty Doloshite had to donate it's battery to the cause...
Once the Civic had actual electricity it fired up on the first turn of the key. As expected of a Honda Civic.
The rear brakes are back to working again although they are still constantly grinding. A run around the block shows the pads are making very uneven contact on the discs so I assume the discs are just gouged/warped to fuck. The O/S makes a rhythmic "woosh" sound which suggests to me it's warped. The calipers wound back easily (unlike the originals) so I assume they are fine.
Normally I wouldn't advocate such things but what about second hand rear discs? They really don't do a lot on the Civic anyway. Usually go really crusty before they have worn out.
perfect car to stick in a local auction? no comeback,quick moneys
I'm not the type to do it or condone it either - but as it moves.... and it's a Civic.... it'll wang through the auctions nae bother I'd have thought. Not sure on what they go through for though as it's stupid money over here. Tis only a battery - second hand one to get it 'over the line' and you're off to the races motor factors.......
Good luck
The brakes might clean up with use, dry driving round a bit with handbrake on say 1 or 2 clicks for a few 100yds and see if the noises start to go. Also have you got a battery charger you could borrow
Spent yonks t'other day hunting for my battery charger but it is seriously lost. I may have left it at my mate's place in Aberdeenshire....
I hope to pick up a battery from a breakers tomorrow.
If anybody wants to relieve me of this fine automobile before the 12th of Sept (when the insurance is due) £500 would secure it and I'll fit new rear discs for the lucky buyer!
Some small updates:
Civic - Ordered new brake discs. 100% sure O/S/R is warped
Doloshite - Still refusing to start/stalling out. Found the ignition timing is drifting again. I broke down at a junction yesterday and a woman in a BINI Cooper S behind me went mental, basting the horn and gesticulating wildly before powering around me at 6000rpm. I was only stopped for 10 seconds...
Acclaim - Still fairly alright. Found out that if I beep the horn the radio turns off. Not even going to question it...
Misc - Ordered a timing light, so I can sort the Doloshite slightly more accurately than by ear and check the Acclaim.
Acclaim I bet that's a shared power feed  & the horn uses too much leccy to keep the radio running.
I've always set points equipped cars with a test lamp, it's not as accurate so I'm told but always came out spot on & I found it much less of a faff.
Most likely the case.
I've decided to not bother reinsuring the Civic as it just isn't worth the cost/hassle and I'm too busy sorting better* cars.
I am now open to derisory offers before I shove it on eBay as spears and repares.
It runs and drives, just over 100k on the clock. Engine and gearbox are gr8 m8, timing belt done at 70kish. O/S/R brake disc is warped (new ones can be supplied) and it needs front pads but the car stops fine. Handbrake cables are disconnected at the callipers.
One rear tyre is a bit cracked/perished for some reason.
It passed its last MOT at the strict garage which condemned the Acclaim so it can't be that fucked but I'm way too brassic to afford the insurance AND couple of hundred quid it might need.
Good plan just sticking to the better cars. Trying to keep three legal with no storage is a bit daft.
I've seen a couple of the later Civics up on ramps. By fuck they rust underneath horribly don't they? Not so much the body, but everything else. My favourite garage hates Hondas. Every rusty bolt snaps off as do caliper bleed nipples and seized calipers are a favourite.
That is my experience. Bodywork and structure is good, bolt heads etc just turn to dust.
I'm amazed how nice my second hand calipers are compared to the ones I took off. Must have been off a cared for low mileage motor...
Went to breakers.
Found battery to fit Civic, check with metre. 12.4v
Bloke says if I'm not in any massive rush he can stick it on the charger for a bit.
I piss off for half an hour to get lunch.
Come back, hand over £20 and fuck off with my battery.
Attach battery to Civic. Half a turn of the starter and it dies.
Nae power.
Try jumping from the Acclaim, nae luck
Fuck me, £20 and 3 hours of my life and I still have a dead Civic.
The bloke from next door came home as I was packing up the jump leads. Apparently he just sold his old man's identical '05 Civic as it was costing a fortune in repairs, guy paid £600 and drove it away to strip for parts....
I don't bother with scrapyard batteries when you can pick new ones up cheap and same day.
Buy that, replace one in your acclaim with it and that in the Civic?
Or if you know someone with a Costco membership get them to get you one. Most looked to be in the £35-45 mark aside from the stupid ones for cars with stop/start systems.
Civic has a backwards battery. As does the Dolomite, but that also has a brand new battery.
Given it'll cost £400 to insure the Civic + whatever it'll cost to MOT and good ones sell for £600-700 it I'm sticking it on eBay tonight as spares and repairs. There is no point in bothering with it any more at this point, it's pouring money into something with no hope of any return. By the end of next month it'll probably be a Zanussi regardless of how many batteries I buy it.
Yeah totally understand that. Just thinking if it runs and can be shown running then you're likely to get a bit more for it.
I think Lion batteries are Yuasa, so whatever the Acclaim has will be better.
Yes/no. Tape the eurocarparts receipt to the battery and if it does crap out in less than 3 years, get it swapped at the nearest ECP branch. I've had quite a few Lion batteries, never had a dud yet. Pretty much as shit as everything else nowadays.
I wonder if the Civic used to be a P6?  Would explain why it's so CURSED.
Oh aye, I can show it running with the Doloshite's battery. They just 'aint keeping it, if somebody wants to drive it away they'll have to bring one. :P If the Acclaim and Civic had swap-able batteries I'd have bought a new one, sadly it aint' the way of things.
The current battery seems to have marginally more life in it than the old one. I'll buy a battery charger (need one anyway) and shove it on for 6 hours and see if I can get any life out of it.
Needless to say, if any of you suckers fine gentlemen wants the thing for £200 please get in touch.
Captain Slow was selling a Rover 2000 for £700 recently, needed WELDING and BRAKE WORK. It'd STILL probably less of a ballache than the bloody Honda.
