richardmorris Posted October 24, 2024 Posted October 24, 2024 20 hours ago, ianbmw said: I thought you sold the 156 Wishful thinking. It’s next on your fix list ( bottom of page three).
ianbmw Posted October 24, 2024 Posted October 24, 2024 16 minutes ago, richardmorris said: Wishful thinking. It’s next on your fix list ( bottom of page three). Don’t tell him and he won’t see on here…..but it’s GL, Royale then I’m tempted to see just how broken the van is! I like the Mk4 cans and they are good old things. im not rushing to fix the CF, that will only be done if a fuel pump appears, I’m not looking for one! richardmorris and Wibble 2
Six-cylinder Posted October 24, 2024 Author Posted October 24, 2024 Today @Slowsilver and his friend Thomas came over to help me put the Mercedes E320 Coupe into storage. This involved reorganising the storage as we had just been dumping cars in there so now we had to squeeze them up to make some room. We then returned to fixing the Mini. This week new fuse box fitted, Hazard flasher unit fitted and working. Onto headlights and we found the inside of the main switch corroded along with connections to the o-s seal beam unit plug. There is smoke inside the o-s sealed beam unit so I don’t think it is long for this world. Shame as it is original with the cars number plate etched into the glass. We then started the hunt for non working instrument bulbs but ran out of time. I have 5 types of capless bulb holders but none fit the Mini. I managed to pump some oil out of the Carlton GL 1.8 Saloon engine as it was over full and smoking. @Mrs6Ccame home with an oil sucker pump from Lidl a while ago and this was its first use. It works but is slow is the verdict. I ran out of time so test running the engine with the oil on max instead of well above it has to wait. LightBulbFun, brownnova, Shite Ron and 5 others 8
Six-cylinder Posted October 25, 2024 Author Posted October 25, 2024 No pictures from the first car task of today that @Slowsilver helped me with. We collected the Rolls Royce from the Auto Sparks in Aylesbury and got it into storage minutes before it rained. It now seems to show it is charging on the ammeter. Car job two with Geoff who did the Mini Mayfair welding was he removed the heater so he could take it home to replace the heater matrix that is leaking. Car three was @ianbmw quest to get the Carlton saloon back on the road. It did not go well as it still smokes very badly. Also a metal power steering pump pipe is leaking badly. On the positive side Ian repaired and reassembled the driver's door handle so that now works and he even put the interior door panel back on. Bonus was to find a Philips radio/cass of a suitable appearance in the car. The wiring has been hacked about to fit a more modern unit at some point in time. 83C, richardmorris, Wibble and 9 others 12
richardmorris Posted October 25, 2024 Posted October 25, 2024 Looks like you elected a new Pope too! timolloyd, adw1977, wuvvum and 8 others 11
somewhatfoolish Posted October 25, 2024 Posted October 25, 2024 On 23/10/2024 at 13:20, Six-cylinder said: I wish it was mine! Have a new one. LightBulbFun, Six-cylinder and Vantman 3
24vdiamond Posted October 25, 2024 Posted October 25, 2024 2 hours ago, Six-cylinder said: No pictures from the first car task of today that @Slowsilver helped me with. We collected the Rolls Royce from the Auto Sparks in Aylesbury and got it into storage minutes before it rained. It now seems to show it is charging on the ammeter. Car job two with Geoff who did the Mini Mayfair welding was he removed the heater so he could take it home to replace the heater matrix that is leaking. Car three was @ianbmw quest to get the Carlton saloon back on the road. It did not go well as it still smokes very badly. Also a metal power steering pump is leaking badly. On the positive side Ian repaired and reassembled the driver's door handle so that now works and he even put the interior door panel back on. Bonus was to find a Philips radio/cass of a suitable appearance in the car. The wiring has been hacked about to fit a more modern unit at some point in time. Is that oil smoke looks a bit light? Looks like it could be brake fluid? Six-cylinder 1
Six-cylinder Posted October 25, 2024 Author Posted October 25, 2024 13 minutes ago, 24vdiamond said: Is that oil smoke looks a bit light? Looks like it could be brake fluid? That makes sense.
MorrisItalSLX Posted October 26, 2024 Posted October 26, 2024 8 hours ago, Six-cylinder said: Very similar to the original radio fitted to my 1990 Toyota Corolla. grogee, tooSavvy, Six-cylinder and 1 other 4
Coprolalia Posted October 26, 2024 Posted October 26, 2024 9 hours ago, Six-cylinder said: That makes sense. Stuck rings too?
ianbmw Posted October 26, 2024 Posted October 26, 2024 It’s an interesting one, now we’ve run it, I want to do a compression test cold and hot and see what we have. it will also be interesting to see if the oil level has risen. The Brake servo holds pressure and there has been no obvious drop in levels. Regardless it will get fixed, just to annoy @Six-cylinder. However if an engine strip down is on the cards, the Royale is going to jump the queue as that really needs the Carb putting back on and some lines made up. anyone mentions the CF, you will be met with a nightmares of Trabant driving route 66. Six-cylinder, LightBulbFun and Shite Ron 3
LightBulbFun Posted October 26, 2024 Posted October 26, 2024 1 hour ago, ianbmw said: anyone mentions the CF, you will be met with a nightmares of Trabant driving route 66. Mrs6C, richardmorris, IronStar and 4 others 7
ianbmw Posted October 26, 2024 Posted October 26, 2024 It’s all go this morning in preparation for returning the Carlton either today or tomorrow. The advisory of an iffy fuel hose has been done. the Carlton is now getting a bath so @Six-cylinder is „“ happy with what we have done to his car“ Six-cylinder, richardmorris, Wibble and 13 others 16
Six-cylinder Posted October 26, 2024 Author Posted October 26, 2024 Today did not work out as planned. Plan “A” was to finish getting the Sigma back together and running after the head gasket change with a local mobile Mechanic Phil. I asked Phil to come to the house first and check the fuel pump on the Citroen DS as it has been broken and sitting in a public layby near our house for the last 3 weeks. The car was on its belly up against a hedge and Phil concluded he could not work on the car where it was parked. A plastic bottle with petrol and gravity feed pipe was held by Phil while I reversed the car home! With the aid of two 3 ton jacks Phil climbed underneath and found the pump. He checked the pump was getting power and concluded the fuel pump was dead. A new pump has been ordered and the car is safely on the drive. Poor old Sigma is going to have to wait a bit longer. worldofceri, Shite Ron, Snake Charmer and 3 others 6
Six-cylinder Posted October 26, 2024 Author Posted October 26, 2024 5 hours ago, ianbmw said: In spite of my doubts about the garage who had failed the Carlton I think they may have had a point with these pipes!
ianbmw Posted October 26, 2024 Posted October 26, 2024 13 minutes ago, Six-cylinder said: In spite of my doubts about the garage who had failed the Carlton I think they may have had a point with these pipes! But those weren’t the pipes they failed! beko1987, Six-cylinder and Mrs6C 2 1
ianbmw Posted October 26, 2024 Posted October 26, 2024 Needed dinner, with an unenthusiastic child who didn’t want to walk……best take the Carlton. In theory, assume it doesn’t fail me, it’s going to Malvern and back tomorrow, which will breach the 500 miles since MOT mark……I will then deem it „“fixed“ and give it back to @Six-cylinder…….where it will no doubt fail the day he turns the key. worldofceri, Floatylight, LightBulbFun and 11 others 14
grogee Posted October 27, 2024 Posted October 27, 2024 16 hours ago, Six-cylinder said: Today did not work out as planned. Plan “A” was to finish getting the Sigma back together and running after the head gasket change with a local mobile Mechanic Phil. I asked Phil to come to the house first and check the fuel pump on the Citroen DS as it has been broken and sitting in a public layby near our house for the last 3 weeks. The car was on its belly up against a hedge and Phil concluded he could not work on the car where it was parked. A plastic bottle with petrol and gravity feed pipe was held by Phil while I reversed the car home! With the aid of two 3 ton jacks Phil climbed underneath and found the pump. He checked the pump was getting power and concluded the fuel pump was dead. A new pump has been ordered and the car is safely on the drive. Poor old Sigma is going to have to wait a bit longer. How did you tackle the unobtanium inlet manifold gasket for the Sigma? tooSavvy 1
ianbmw Posted October 27, 2024 Posted October 27, 2024 Got up early, added fuel Had an uneventful drive to Malvern…. Assuming it gets me home, it’s going to be returned to @Six-cylinder Six-cylinder, grogee, Floatylight and 4 others 7
Six-cylinder Posted October 27, 2024 Author Posted October 27, 2024 2 hours ago, ianbmw said: Got up early, added fuel Had an uneventful drive to Malvern…. Assuming it gets me home, it’s going to be returned to @Six-cylinder Only if you want too. Wibble, grogee and Mrs6C 3
ianbmw Posted October 27, 2024 Posted October 27, 2024 The issue is, it’s now done over 400 miles and whilst not perfect, it’s totally usable. I also really need to get mums Disco done :(. Please sir, can I give you a fully operational vehicle back ? 83C, Dick Cheeseburger, Floatylight and 6 others 5 1 3
hairnet Posted October 27, 2024 Posted October 27, 2024 50 minutes ago, ianbmw said: foot or sandwich @Six-cylinder
Six-cylinder Posted October 27, 2024 Author Posted October 27, 2024 2 hours ago, ianbmw said: The issue is, it’s now done over 400 miles and whilst not perfect, it’s totally usable. I also really need to get mums Disco done :(. Please sir, can I give you a fully operational vehicle back ? Wow a lovely photo of the Carlton Estate. Thank you for all the hard work and doing the shakedown miles and getting it ready for road use. It came to the FoD non running on a trailer and now was driven to the house after 400 + miles. dome, richardmorris, IronStar and 9 others 12
Mrs6C Posted October 27, 2024 Posted October 27, 2024 A huge shout-out and thanks to @Andyrew and @Talbot as well as @ianbmw for all their contributions to getting this fixed (twice!) and looking so good. There are probably a few more on here who have helped it along also, so thanks to you all - you know who you are! 🙂 IronStar, Floatylight, Stinkwheel and 5 others 7 1
ianbmw Posted October 27, 2024 Posted October 27, 2024 It’s very rare things don’t fit on the trailer, but i openly admit that one barely fitted. richardmorris and Stinkwheel 1 1
Six-cylinder Posted October 31, 2024 Author Posted October 31, 2024 This afternoon was a car afternoon with @Slowsilver. We started by putting the Morris 1300 into storage for the winter, boo you might say but I feel the need to protect it from salt. It has been the big success of this year and I have been using as my go to car. We spent some time reloading the vermin boxes to try and protect the cars from being nibbled. The mistake we made was not doing it a while ago when the cars were more spaced apart as Slowsilver had quite a job getting to some of the boxes because the cars are so squashed up now. It was a bright dry afternoon so we then went to the Mini Mayfair. We had had a problem with dash lights not working which is corrosion of the warning lights/dash lighting bulb holder. I bought 3 good used bulb holders and Slowsilver’s friend Thomas donated 2 more and Slowsilver cleaned everything and got them all working. We also put in a new headlight switch as I felt the old one could not be trusted because of corrosion. The Bonus was Thomas had donated a driver’s door mirror which we fitted. Once again thanks to Slowsilver for his time and effort. Anybody who did not join us this afternoon missed out on Jammie Dodgers! Winter is coming and as the sun set the temperature dropped notably with the mist coming of the FoD. tooSavvy, Dyslexic Viking, Vantman and 7 others 10
richardmorris Posted October 31, 2024 Posted October 31, 2024 Plenty of us would drive hours for a jammy dodger. I’m free tomorrow! Six-cylinder and Stinkwheel 2
ianbmw Posted October 31, 2024 Posted October 31, 2024 I only got chocolate fingers! What do I have to do to be upgraded to the jammy dodger club? Six-cylinder and richardmorris 2
Mrs6C Posted October 31, 2024 Posted October 31, 2024 20 minutes ago, ianbmw said: I only got chocolate fingers! What do I have to do to be upgraded to the jammy dodger club? Fix my CF... Dyslexic Viking, LightBulbFun, High Jetter and 3 others 2 4
richardmorris Posted October 31, 2024 Posted October 31, 2024 21 minutes ago, ianbmw said: I only got chocolate fingers! What do I have to do to be upgraded to the jammy dodger club? Work harder
