egg Posted July 23, 2019 Posted July 23, 2019 7 minutes ago, Bfg said: . a couple of inner tubes shouldn't cost much. I'd guess that size is still used on small trailers . When I got inner tubes for mine, I think they were oversized for the 12 inch wheels, but they were sourced for me, so can't quite remember...
LightBulbFun Posted July 23, 2019 Posted July 23, 2019 https://www.vintagetyres.com/shop/swift-inner-tube-500-520-10-also-145-10-and-165-70-10 vintage tyre list this inner tube as being compatible with the BN313 Tyres that TPA have (and i imagine are of the same size as whats currently on REV and OPH although always worth double checking, assuming you can even read the markings through the cracking LOL) although worth mentioning the cracking/bulging on one of REVs tyres, would that still be an issue with tubes? as a side note its funny how this has sort of gone full circle for me, as when I was young I used to enjoy buying Inner Tubes from the local tyre fitters place I still want a big fuck off Lorry/tractor inner tube one of these days LOL! mind anyone complaining about the bulging on REV, I have seen worse on a Model 70! BlankFrank, Six-cylinder and Mrs6C 3
Mrs6C Posted July 23, 2019 Posted July 23, 2019 ^^^ I don't think I would want to be using that set-up as an inspection ramp... LightBulbFun and AnthonyG 2
Six-cylinder Posted July 23, 2019 Author Posted July 23, 2019 I think spending out on inner tubes would be a waste and we would be better just buying new tyres. LightBulbFun 1
Zelandeth Posted July 23, 2019 Posted July 23, 2019 I've got two wheels, currently not holding air, though one may if I could get the bead seated. Wheels are in pretty good shape as I recall. I've no use for them so you're welcome to them. Not sure if I'll have the opportunity to drop them over this week, but you're welcome to them. Given the heat this week it's not likely to happen, but if I can I'll see if I can get any air into them. Might be time for the old lighter fuel trick...see if I can burn my eyebrows off again... LightBulbFun and Six-cylinder 2
LightBulbFun Posted July 23, 2019 Posted July 23, 2019 4 minutes ago, Zelandeth said: Might be time for the old lighter fuel trick...see if I can burn my eyebrows off again... IIRC @Andyrew manage to get one of OPHs tyres seated on the bead via the ratchet strap method well at least to hold air long enough so we could tow her forward a bit so maybe that might be worth a shot before sacrificing your eyebrows to the tyre gods?
Andyrew Posted July 23, 2019 Posted July 23, 2019 Whilst it did hold air there must be a slow leak as it wasn't enough to be heard but the tyre did go down after about 5 or more hours. If it's just leaking on the bead some tyre bead glue/seal should do it. LightBulbFun 1
BorniteIdentity Posted July 24, 2019 Posted July 24, 2019 7 hours ago, LightBulbFun said: @BorniteIdentity you dont happen to still have the pair that got ruined by bad tracking? or have they been worn so badly that they are not safe for field use? They might still be at the garage in their disposal area. They were proper smooth on the edges but if they are still there I know the owner will have no problem with me having them back. I should be passing there in the next day or so - happy to ask. I’m afraid I can’t help with any wheels - but if someone has a set around Cambridge I’d be only to happy to scoop them up and bring them over at some time. I will report back! somewhatfoolish and LightBulbFun 2
BorniteIdentity Posted July 24, 2019 Posted July 24, 2019 Hang on. What size do you need? My Mini is the last of the MKIV’s so runs 10’’ wheels. I’ve never paid much attention but I reckon you’re after 12’’ ?
Six-cylinder Posted July 24, 2019 Author Posted July 24, 2019 3 hours ago, BorniteIdentity said: Hang on. What size do you need? My Mini is the last of the MKIV’s so runs 10’’ wheels. I’ve never paid much attention but I reckon you’re after 12’’ ? Both of these Invacars are on 10 inch wheels, I am told.
BorniteIdentity Posted July 24, 2019 Posted July 24, 2019 5 minutes ago, Six-cylinder said: Both of these Invacars are on 10 inch wheels, I am told. Excellent. I will get up there today and see if I can salvage anything!! LightBulbFun 1
Six-cylinder Posted July 24, 2019 Author Posted July 24, 2019 8 minutes ago, BorniteIdentity said: Excellent. I will get up there today and see if I can salvage anything!! I have reread your post and now I understand there are no rims? I am trying to avoid paying to have old tyres moved or inner tubes fitted and was really looking for wheels/tyres that can be put on or I will just have new tyres fitted to Mrs6C's one. LightBulbFun may think differently for his. LightBulbFun 1
purplebargeken Posted July 24, 2019 Posted July 24, 2019 Bugger, I have two Mini wheels/tyres in the garage that I was going to put on a trailer but they are the bigger size. Damn.
plasticvandan Posted July 24, 2019 Posted July 24, 2019 Reliant spares in Worcestershire will have several hundred wheels and tyres,give them a call. LightBulbFun, somewhatfoolish and The Moog 3
LightBulbFun Posted July 24, 2019 Posted July 24, 2019 4 hours ago, BorniteIdentity said: Hang on. What size do you need? My Mini is the last of the MKIV’s so runs 10’’ wheels. I’ve never paid much attention but I reckon you’re after 12’’ ? The Model 70 Mark A from June 1971 to June 1974 indeed ran on 12 inch wheels but from July 1974 with the introduction of the Model 70 Mark B they switched to 10 inch Mini wheels among other changes (while as TPA demonstrates you can stick 10 inch wheels on a Mark A, I have been told if you stick 12 inch wheels onto a Mark B they will rub in the wheel arches) Both REV451R and OPH868R are from November 1976 so are Model 70 Mark B's 1 hour ago, Six-cylinder said: LightBulbFun may think differently for his. no no what you say sounds entirely reasonable (and when it is time to get new tyres I think the plan is to see if we can get a bulk discount on 6 or something like that)
Six-cylinder Posted July 24, 2019 Author Posted July 24, 2019 For Mrs6C's I will continue to search for at least one used wheel/tyre that holds air as every time we go to it having a flat tyre is a pain. LightBulbFun 1
LightBulbFun Posted July 24, 2019 Posted July 24, 2019 3 minutes ago, Six-cylinder said: For Mrs6C's I will continue to search for at least one used wheel/tyre that holds air as every time we go to it having a flat tyre is a pain. yeah by new tyres I meant new tyres for on road use when we finally get there I fully understand why you want to get some tyres that just hold air for field use/working on the vehicle hopefully between the wheels from Zel and tyres from BorniteIdentity something can be put together that holds air and is good enough for field use/testing
Zelandeth Posted July 24, 2019 Posted July 24, 2019 Got two wheels here, one of which is holding air. One probably will if I can get the tyre to seat I reckon. Given how hectic things are here just now not sure when I'll next be over that way, but if I am I'll drop them off. If you're around MK drop me a line and we can arrange pickup. There are a bunch of 12" ones too, not sure if I have a full set of three that are serviceable though. Six-cylinder, Mrs6C and LightBulbFun 3
Six-cylinder Posted July 24, 2019 Author Posted July 24, 2019 7 hours ago, Zelandeth said: Got two wheels here, one of which is holding air. One probably will if I can get the tyre to seat I reckon. Given how hectic things are here just now not sure when I'll next be over that way, but if I am I'll drop them off. If you're around MK drop me a line and we can arrange pickup. One 10 inch that holds air would advance us. Mrs6C's ZX is in Newport Pagnell having a cambelt service and a couple of jobs so when I get the call to collect it I will see if you are about. LightBulbFun 1
Zelandeth Posted July 24, 2019 Posted July 24, 2019 Excellent. I'll drop you a PM with my contact details just in case you don't have them. I'll leave the wheels by the garage door so you can grab them even if I'm not about. LightBulbFun 1
quicksilver Posted July 25, 2019 Posted July 25, 2019 Looks like it was a good decision to take the Gamma to FOTU. For all the suggestions here that it was too exceptional, the majority of coverage seems to have singled it out for comment and photos. LightBulbFun, catsinthewelder, beko1987 and 1 other 4
Six-cylinder Posted July 28, 2019 Author Posted July 28, 2019 I have been talking to the farmer who is having our hay and he is going to try and cut and bail it this coming week. THAT MEANS - we have 10 acres to play in! I am thinking of a tinkering day focusing on getting the big toys out, digger, dumpers, tractor and horticulture truck. The only weekend I have free in August is 10 and/or 11th. Is anybody free to help me? ---------------------------- While I have said focus on big toys the usual range of activities are also available including. Tea drinks Bring you family for a picnic Bring you dog for a day out Fix your own car Camp Mow grass with ride on mower Fix Honda moped Fix cylinder mower Fix Triumph Spitfire 6 Polish Alfa Giulietta Anything legal and not too dangerous Mrs6C, catsinthewelder, LightBulbFun and 2 others 5
LightBulbFun Posted July 28, 2019 Posted July 28, 2019 Oooh! ill tentatively put my name down, as if nothing else having a much bigger area to run around the invacar sounds like fun! but I also would like to get some actual work done on REV, im thinking of replacing the fuel hoses (as there all quite badly pershied) and this sounds like a good opertunity to do so , I just have to check a few things before I can confirm anything but yeah I will try and see if I can make it
Andyrew Posted July 28, 2019 Posted July 28, 2019 Should be good for the 11th. I'm working on the 10th unfortunately.
hairnet Posted July 28, 2019 Posted July 28, 2019 1 hour ago, Six-cylinder said: I have been talking to the farmer who is having our hay and he is going to try and cut and bail it this coming week. THAT MEANS - we have 10 acres to play in! I am thinking of a tinkering day focusing on getting the big toys out, digger, dumpers, tractor and horticulture truck. The only weekend I have free in August is 10 and/or 11th. Is anybody free to help me? ---------------------------- While I have said focus on big toys the usual range of activities are also available including. Camp how dare you - more like FF tries to wrestle trac'r 3 falls or 1 submission Mrs6C and stonedagain 2
Mrs6C Posted July 28, 2019 Posted July 28, 2019 An OOF? Why do French chefs make omelettes with only one egg? Because one egg is un œuf... egg and dozeydustman 1 1
hairnet Posted July 28, 2019 Posted July 28, 2019 AND YOU THINK IM A LOONY we failed at calvados last week this week i could real guinness real mcewans export squair sassage or tunnocks logs if you like - might be going to fod in aug maybe
Tadhg Tiogar Posted July 28, 2019 Posted July 28, 2019 2 hours ago, Six-cylinder said: I have been talking to the farmer who is having our hay and he is going to try and cut and bail it this coming week. THAT MEANS - we have 10 acres to play in! I am thinking of a tinkering day focusing on getting the big toys out, digger, dumpers, tractor and horticulture truck. The only weekend I have free in August is 10 and/or 11th. Is anybody free to help me?.... Sundays are horse days, so provisionally only Saturday, assuming I'm not away having the exhaust patched up in advance of the MoT..... Six-cylinder 1
beko1987 Posted July 29, 2019 Posted July 29, 2019 I have the kids that weekend, so I'm a deffo for at least one day, maybe both but we'll see how we go! The kids will want a ride in the tractor though I'm afraid... LightBulbFun 1
