Shite in Miniature II
2 hours ago, eddyramrod said:
Thank you!  I have the Camaro, but it's much too nice to strip.  I'll have a look among my stock and see if there's anything suitable, because I do have a Vanguards Cresta that definitely is going to become WiFeY.  Solido's tyres are a bit low-profile for my taste but I'm sure there will be a way....
I might have a set of these somewhere .. i cut one up to make a coupe singer vogue.. then again i might have busted them getting them off ..  They'd only be 13" and 4 bolt thoughford-diesta-mki-61-bscc-1980-alan-curnow-corgi-va12502.jpg.19c3d6dfa8e78fe2f83b9b8a36f4d32e.jpg
If you can find them, that would certainly help!  Thank you :)
Had a couple of late deliveries yesterday, firstly this Polistil CX that's only lost 12.7% of its bits
In a small job lot was this Superfast Mustang, one I always find hard to resist even when they've been ridden hard and put away wet
Check out the broken wheels, don't see that often - although I remember it happening to my ERTL General Lee at junior school when I jumped it between two desks
Almost missed this Siva Spyder, unusual for having the chrome loop over the roof rather than black. I've got a better one but they don't show up every day
  • Like 9
I’ve a couple of AMX Javelins that the hub has broke free on, perhaps they were a faulty batch?
9 hours ago, sheffcortinacentre said:
What happened to rest of fiesta?
Well i've found this bit ...so far , still looking for the chassis !
On 17/10/2025 at 22:07, FakeConcern said:
Yesterday I came home to find a gold Norev Renault R16 missing the bonnet from @andrew e on the doormat and today I had a proper look at it.
Here next to my red one I took it apart and you can see the broken lugs that should stop the bonnet falling out
Maybe this shows it better
Here's mine for comparison, I tried quite hard to ply the bonnet out, but gave up as I didn't want to break mine as well
I had already decided to try and make a bonnet in resin which is why I wanted the red one removed to make a mould. I did that with the bonnet attached
Which produced a resin bonnet with several flaws from air pockets
A coat of paint shows it better
It needs some filler and some lumps smoothed off. I may try to cast it again or I may revert to the tried and trusted method of using sheet aluminium
Remember this bonnet-less Norev Renault 16? I thought it might suit the sprawling Norev collection of @FakeConcern ?
Well as you can see it went through his restoration shop and came out the other side like bloody new!!!!! Probably better than new actually!
Compare and contrast 😳 I can't contain just how great this is - the bonnet is phenomenal recreation and the respray is the golden cherry on top 👌
Thank you Peter 😎
I’ve never figured a way to recreate the bent over lugs on matchbox that hold bonnets/bootlids in place.
Me either. Maybe a bit of tube cut lengthways slipped over the hinge, and glued inside the body?
Found another Police !  ... still no wheels though . I have to much shit... i need a clear out . Swap 4  32  w 33L  jeans!
Thank you Peter 😎
I'm really glad you're pleased with it and it was fun doing it.
I like the summer house, by the way!
I thought that 16 was yours.
Lovely job you made of it, and the colour match looks spot on.
  • Agree 1
Thread drift: That beach hut was here when I moved in 2013, previous owner had it installed when they gave up their real one - it's had a couple of coats of Dulux and its frilly round the edges but it just won't die!
It was my daughters hideout turned teacher prep room, but she's bought a house now so it's mine agsin now 😉
Today's diecast deliveries. These premiums were actually a tag along with some other stuff I was after, but no complaints
Thought there was a Redline lurking in there too, but it's a Marx J Car
Check out this Road Champs Testarossa
I don't remember the original having square doors
But it does have 3(!) opening bits
Shonky E30
With the similar Corgi
Taking of which, this M3 casting seems to be much less common than the wide arch version
I like these early Lesney T1 panel vans, the styling reminds me of the early adverts which made them look all swoopy and streamlined
Moving on about 5 decades, a couple of modern ones - saves me releasing mine from the cards
Can our resident Super GT expert see what's different about this BR 15/16?
Mainly I wanted this Astra, as I'd not seen this livery before
That's because it's someone's custom. Gah
Never mind, spotted a couple of Graffic Traffics in a lot, here are the two pics:
Astra looks good, just needs the stickers removing?
Gah again. I did my best but the paint is coming off now
Transit:
Moving on, Dinky copy Superior Sunnyside Rover 3500 survived its jiffy bag journey
Last, and by no means least, this was not exactly cheap - white Corgi Man from U.N.C.L.E. Oldsmobile
I was given a good tip at a recent toy fair about these - the blue ones have a ridge around the bonnet sticker, white ones do not. Makes spotting a fake a bit easier
  • Like 11
Yours has got a higher percentage of parts than mine has  😁
Are these considered rare?
Think I've got a white one.🤔
I'd never seen a white one when the model was current (I'm old enough!) but I first noticed them on the secondhand market probably 30 years ago.  I've definitely got one in stock, and a blue one; another blue one I've restored and I might have another white one somewhere.  Or it might have gone, I don't know.
Good news Eddy , i've at last  found the Fiesta chassis !
Bad news , only 3 wheels LoL .
They're those split things where the  axle riveted end bit is covered with a seperate outer part ..  and i think they were specific to the Vanguards Curnow racing Fiesta , which are a bit pricey ...
If i can find the interior and roll cage too   , the missing wheel part could be with it..
Late collection from the Post Office. These were all from a Vinted seller who listed a load of goodies and accepted a cheeky offer on a bundle
Rarest are these two Hot Wheels Sizzlers
Also very desirable, two original 16 redlines
From this side of the water, a  pair of Lone Stars. I really wish they'd been more successful against the likes of Matchbox, they're just lovely things
58 minutes ago, sierraman said:
BR15/16 I think meant the two colour schemes originally released
Sounds about right - this one stood out to me as it's missing the gold flash that's normally inside the white area
Matchbox Super GT BR 15/16 Monteverdi Hai
The same as the red centre section on the blue version
As best I know they had planned some more including a Miura but the mould had gone. The first ones in 1985 were made in Rochester then not long after the manufacturing was transferred to China, I figure the margin was quite good on them so more models and colours were introduced, I’ve well over a 100 of them which only scratches the surface. Eventually in the early 90’s they became Glo-Racers in neon colours which are quite hard to find. Unused stocks seemed to find their way into various multipacks or Motorcity sets for years afterwards.
I've after wondered if you could get identical Super GTs with both England and China bases,  but I've never found any. It seems the Chinese ones are always different to the original English versions
A few die cast gubbins to discuss this evening, in no particular order. Found another Matchbox Continental in Morrisons so I freed it
QC is not the best, red mark on the roof and nasty paint defects on the bonnet
I'd like to line this up with a stock original Lesney but my lowered custom was easier to get my hands on
Shame the lacquer has crazed on mine
Another Morrisons find was this Integrale that I didn't buy when it originally came out
The reason I was out in the first place was to collect my Christmas present to myself, this Go-Bots Super Couper which was in the junk shop's window display
In the post late last night were a tidier Espana Corgi Chevrolet Van than the current one
And a Dinky Dublo VW van
  • Like 9
More 50p finds.
Someone has poured glitter glue in the Karmann Ghia. The bonnet is missing and I'm guessing some air intake? Cool casting that I have some how missed.
Zylmex Rolls is a nice thing with the spirit of ecstasy still intact!!
20251211_201158small.jpg.7608e7a41852f350b8eb6bb43d20ec8a.jpgimage.jpeg.7641f7aafa2bf8a204a896b4881a16b6.jpeg
