Rocket88 Posted December 14, 2023 Author Posted December 14, 2023 This sounds promising……, after a bit of de-chavving…… chaseracer, HMC, camryv6 and 3 others 6
Rocket88 Posted December 14, 2023 Author Posted December 14, 2023 Anyone fancy a project? Can deliver…. I no longer have the physical capabilities, and probably never had the skill set. Got a reasonable budget for work required
Rocket88 Posted December 14, 2023 Author Posted December 14, 2023 3 hours ago, sasquar said: i like those! theres somethign about the odd shaped, suicide front doors that pleases me. Whats the powerplant plans? Sticking with period, or something a little more modern? From memory, these are still pretty valuable, so you might be better hunting an orignal engine out, but if thats not your flavour, i would probably be tempted by something like a zetec, or more likely a mx5 engine and box (easy enough to find in auto as well!) Bmw engine above, is a great engine, no doubt about it, but a bit ott for something this size i would think. MX5 twin cam and auto box looks favourite sheffcortinacentre 1
bunglebus Posted December 14, 2023 Posted December 14, 2023 1 hour ago, Rocket88 said: This sounds promising……, after a bit of de-chavving…… Just paint the car to match chaseracer and Rocket88 2
shampooefficient Posted December 14, 2023 Posted December 14, 2023 49 minutes ago, Rocket88 said: MX5 twin cam and auto box looks favourite Now trying to think of anything RWD and DSG that isn't a million pounds
Rocket88 Posted December 14, 2023 Author Posted December 14, 2023 The curse of fwd…..😱 sheffcortinacentre 1
Bren Posted December 14, 2023 Posted December 14, 2023 I am not surprised you found the jag underwhelming. Performance wise when you have been used to turbo diesels even a large naturally aspirated V8 can be a bit disappointing - especially at the bottom of the rev range. My BMW did nothing below 3k. Rocket88 1
bezzabsa Posted December 14, 2023 Posted December 14, 2023 another vote for a Jag straight 6.... would suit it and added slush box smoothness too
artdjones Posted December 14, 2023 Posted December 14, 2023 5 hours ago, Rocket88 said: Sounds appropriate…. Could you find out? There might be a difficulty with length. The RME is a 1½ litre, and Riley even found it necessary to lengthen the chassis in front of the A pillar to accommodate the 2½ litre engine in the RMB/F. Also, the XK is very heavy, probably enough to spoil the balance of an RME. The engine/autobox out of a Daimler Conquest might suit. lesapandre and alf892 1 1
tooSavvy Posted December 14, 2023 Posted December 14, 2023 "I'm an engineless Riley, get me out of here!" Public vote?? Mazda ...all day 🚀🤩🛠️
83C Posted December 14, 2023 Posted December 14, 2023 Small and light is the way forward in the RME. MX5 engine and box as suggested, or for slightly more complexity a K-series in 160bhp VVC flavour.
Rocket88 Posted December 14, 2023 Author Posted December 14, 2023 4 minutes ago, 83C said: Small and light is the way forward in the RME. MX5 engine and box as suggested, or for slightly more complexity a K-series in 160bhp VVC flavour. Not that common with an auto box, and apparently the MG auto isn’t great…… Mazda seems to be pretty reliable tooSavvy 1
Mr Pastry Posted December 14, 2023 Posted December 14, 2023 There isn't as much space as you might think. The crossmember linking the torsion bar mountings has to be retained, though perhaps could be modified. Also the width is restricted if you consider where the body sides would be. A BMC B series might be the sensible but boring option -not in the same class as the Riley, but similar size and weight, auto is no problem, and the 1.8 is considerably more powerful. And no, I don't want the job. Rocket88, tooSavvy and garethj 2 1
Rocket88 Posted December 14, 2023 Author Posted December 14, 2023 Mazda lump is actually physically smaller than the Riley engine tooSavvy 1
Supernaut Posted December 14, 2023 Posted December 14, 2023 OM602 (non turbo) running on waste veg oil. Fuel pump wound up for maximum reek. chaseracer, chodweaver, Coprolalia and 2 others 2 3
New POD Posted December 14, 2023 Posted December 14, 2023 10 hours ago, Rocket88 said: I’ve actually got stashed away a Cologne V6 and auto box If it were the cosworth 2.9 24V then maybe, but uf it's a marine spec from a reliant, with 12 bhp don't bother.
Rocket88 Posted December 14, 2023 Author Posted December 14, 2023 Looks like the Mazda lump then….😂😂😂😂 tooSavvy and chaseracer 1 1
warch Posted December 14, 2023 Posted December 14, 2023 I love Cologne V6 it sounds like an aftershave for a certain sort of gentleman (probably the sort of bloke who posts on here tbh). 'What are you wearing?' 'It's Cologne, Cologne V6 for Men'* * Same range as Swarfeg'e hand cream. bunglebus, Sigmund Fraud, chodweaver and 1 other 2 2
wuvvum Posted December 14, 2023 Posted December 14, 2023 3 hours ago, artdjones said: The engine/autobox out of a Daimler Conquest might suit. Not many auto Conquests around though, most of them were pre-select - tracking down an engine / auto 'box combo might be tricky. Sigmund Fraud 1
SiC Posted December 14, 2023 Posted December 14, 2023 3 hours ago, Mr Pastry said: A BMC B series might be the sensible but boring option -not in the same class as the Riley, but similar size and weight, auto is no problem, and the 1.8 is considerably more powerful. There is a B series converted Riley that sold at auction not that long ago. Mr Pastry 1
wuvvum Posted December 14, 2023 Posted December 14, 2023 The Riley One Point Five had a B-series so it's not completely out of keeping with the marque either. eddyramrod 1
sheffcortinacentre Posted December 14, 2023 Posted December 14, 2023 10 hours ago, Stinkwheel said: Im thinking a fairly easily available 2.0 DOHC ford as fitted to sierras and granadas etc with an auto box (was it a c3 fitted to these?) would be a good call - Old enough engine for it to have been done 30 years ago as well 😉 4ald 4speed Stinkwheel 1
Rocket88 Posted December 14, 2023 Author Posted December 14, 2023 59 minutes ago, sheffcortinacentre said: 4ald 4speed If I could find one……
Mr Pastry Posted December 14, 2023 Posted December 14, 2023 The RME axle is going to be the limiting factor. There won't be much choice of alternative ratios, and how much power will it stand? Presumably the 2.5 litre used the same axle and that developed about 100 bhp.
eddyramrod Posted December 14, 2023 Posted December 14, 2023 MX5 does look suitable. I have to admit I was thinking Pinto. Really the only thing that's easy to get and would fit and be period-appropriate is going to be the MGB 1.8. But it appears you've had a Moment Of Revelation, a few posts ago. You have my sympathy. I've been there. it's not nice. I'm still trying to adjust, so good luck.
Rocket88 Posted December 14, 2023 Author Posted December 14, 2023 21 minutes ago, eddyramrod said: MX5 does look suitable. I have to admit I was thinking Pinto. Really the only thing that's easy to get and would fit and be period-appropriate is going to be the MGB 1.8. But it appears you've had a Moment Of Revelation, a few posts ago. You have my sympathy. I've been there. it's not nice. I'm still trying to adjust, so good luck. Trouble with B series is that the auto boxes are pretty awful. I’m not bothered about trying to go fast….. just want something reliable. Riley back axles are pretty strong eddyramrod 1
junkyarddog Posted December 14, 2023 Posted December 14, 2023 54 minutes ago, eddyramrod said: I was thinking Pinto. Yep,2.0 pinto with the 4 speed autobox. eddyramrod 1
sheffcortinacentre Posted December 14, 2023 Posted December 14, 2023 You'll probably pay same for a worn-out 2.0 pinto as you'll pay for a complete MX-5 garethj, tooSavvy, grizz and 3 others 3 3
Sham Posted December 15, 2023 Posted December 15, 2023 If you want reliable, something from and MX-5 or an old rwd Toyota or Datsun is surely the correct choice?
grizz Posted December 15, 2023 Posted December 15, 2023 MX5 complete donor for my Rezin Rockit build was £400.00 delivered and scrap removed. It is really good and when you see how often they are used in multiple ways it makes a load of sense.
