55 minutes ago, grogee said:
Rear suspension not even mentioned.
Where do I sign?
This should explain it - must be the weight of that engine in the rear that makes it look low:
Car has rear 8 valve engine needs a trailor to take away
Anybody want to save a Mazda Bongo Frendee!
A near neighbour wants to sell their Bongo, I think it will probably end up scrapped but if anybody is interested I can put you in touch.
It has sat for the last 3 years.
MOT history,Check mileage recorded at test, MOT expiry date, and test outcome,Hidethis section
Date tested
28 June 2018
PASS
Mileage
180,608 miles
Test location View test location
MOT test number
6797 0166 4534
Expiry date
27 June 2019
  • Nearside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c))
  • Offside Front tyre perrished
  • both headlamps weathered
  • oil leak front axle
  • Rear Coil spring corroded both (5.3.1 (b) (i))
  • Front Tyre worn close to legal limit/worn on edge both (5.2.3 (e))
  • Offside Rear Tyre worn close to legal limit/worn on edge (5.2.3 (e))
  • Offside Rear chassis corroded
  • underbody corroded
  • Offside Outer sill corroded and holed
  • Nearside Outer sill corroded and holed
6 hours ago, MorrisItalSLX said:
FTFY
I'm just imagining how hot this colour would have looked on an XR2, as it would have made a good contrast with all the black spoilers and arch covers.
Date tested
28 June 2018
PASS
Mileage
180,608 miles
MOT test number
6797 0166 4534
Expiry date
27 June 2019
It's fucked.
Just now, richardmorris said:
Fantastically awful. What is it?
https://en.wikipedia.org/wiki/Paramount_Cars
Quote
 It was originally intended to have Alvis engine and suspension but to reduce cost the production versions used Ford 10 components including the 1172 cc side valve engines, but fitted with twin SU carburettors, which resulted in poor performance.
It probably is quite awful indeed...
Date tested
28 June 2018
PASS
Mileage
180,608 miles
MOT test number
6797 0166 4534
Expiry date
27 June 2019
how would they feel about me living in it
Might put buyers off, just saying.
i'll have you know i'm an incredible catch, got my own place and everything
