9 minutes ago, sdkrc said:
Does anyone need an upside down Corsa here? If so, you're in luck
Cheaper option is to buy one that's the right way up and just tilt your head a bit
https://www.ebay.co.uk/itm/NOT-BARN-FIND-UPSIDE-DOWN-CAR-AUTOMOBILIA-/255392964261
So basically an Oz one, wouldn't that make it a Holden Barina? Haha.
10 hours ago, Dyslexic Viking said:
You shit on a newspaper and throw it out the window.
You have some weird personal habits! 😁
36 minutes ago, AnnoyingPentium said:
That one's been on the bay for a while now. BDs are brilliant cars and massively underrated in general. However, the fella's deluded if he thinks he'll get anywhere near 2.3k for that particular example.
10 hours ago, goosey said:
Perkins 4236 conversion?
it may have been re-bodied at some point in its life but retained the original chassis
That may be true, but if it has had a different body, a different interior and a different engine fitted, if memory serves it no longer has enough points on the DVLA score system to keep its original identity.
Also a 4.236 makes about 75 bhp and is flat out at about 3,000 rpm so that is going to be slow AF.  Although it'd probably drive up a vertical cliff in low range.
Ad states its a 300tdi which further suggests they've just stuck the three door's ID on a 90s five door.
May have been rebodied years ago before the rules were tightened up, Back in the 90s my dad built a “coiler” which was a cut down Range Rover chassis and running gear but with a heavily modified a series 1 body but it was retained the series 1 ID
Even with those power figures ( which for the time were pretty reasonable) A 4236 was a popular conversion back in the day and quite sort after, I even remember people converting Range Rovers to the Perkins 4203 which my dad had fitted in his series 2a and is the only vehicle I have ever snapped a half shaft in and yes that was slow and you needed arms like Popeye to turn the steering wheel
My bad, it was mentioned earlier that it was registered as a 3.8 diesel which threw me a off
14 hours ago, alcyonecorporation said:
The things wrong:
1. OSF does not exist
2. Headlamp resembles B&W chicken breast in fog
3. Suspension depressed
4. Space saver on NSR (new buyer can spend longer being shit)
5. Yes
Saw something similar on YouTube. They paid £900 for an S class that turned out needing £9000 of repairs.
  • Haha 3
1 hour ago, grogee said:
That needs to go in the Tasteless Giffer Mods thread.
Excellent work, have the rest of the day off.
Also, WTF is that on the roof???
There also appears to be chequer plate on the top of the engine!
