https://www.desperateseller.co.uk/cars-for-sale/advert/53954624/101085/0
We have recently reduced our asking price from £400 to £300. This car has been HPi history checked. We are based in Edinburgh
Impressive,
Even more impressive MoT history, well it's last one....
Reason(s) for failure
  • Parking brake lever has no reserve travel (3.1.6b)
  • Brake pedal creeps down when held under pressure (3.3.B.1a)
  • Rear brake disc in such a condition that it is seriously weakened (3.5.1i)
  • Offside rear brake binding (3.7.B.1)
  • Windscreen wiper does not clear the windscreen effectively both (8.2.2)
  • Headlamp aim beam image obviously incorrect both (1.8.A.1b)
  • Exhaust emits an excessive level of metered smoke (7.4.B.3a)
  • Rear Exhaust has a major leak of exhaust gases (7.1.2)
  • Macpherson strut insecure mounting bolt broken (2.4.G.1)
  • Nearside Front Suspension arm has excessive play in a ball joint (2.4.G.2)
  • Nearside Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
  • Nearside Suspension component mounting prescribed area is excessively corroded outer sill (2.4.A.3)
  • Offside Suspension component mounting prescribed area is excessively corroded outer sill (2.4.A.3)
  • Brake pipe inadequately clipped both front to rear (3.6.B.1)
  • Rear Lower engine mounting deteriorated resulting in excessive movement (6.1.D.1a)
Advisory notice item(s)
  • Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
  • Offside Front Brake pipe slightly corroded (3.6.B.2c)
  • Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
  • Nearside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement rear bush incorrectly fitted (2.4.G.2)
 I'd  love to splosh with Juliette Binoche
Image result for juliette binoche
But I'd rather give this a Stu_CDX  wash
https://www.ebay.co.uk/itm/vauxhall-astra-mk1-1-2l/183975458129?hash=item2ad5cab551:g:TGEAAOSwBb1ddrBJ
 I'd love to spend hours servicing Stephanie Powers
Image result for stephanie powers
But I'd rather enter the inside of this Mayflower's
https://www.ebay.co.uk/itm/Triumph-Mayflower-TT15427-DL/233354880032?hash=item365508e420:g:STwAAOSwBzpdkLzi
And I'd like to make Meryl Streep's 'radiator' weep
Image result for Meryl Streep film star
But I'd sooner pull the Wranglers off this Jeep
Wrangler-jeep-tj-5-7-V8-chevy-4x4-manual
https://www.ebay.co.uk/itm/Wrangler-jeep-tj-5-7-V8-chevy-4x4-manual/303297823708?hash=item469df583dc:g:PcAAAOSwtl5dAAPx
Sing Katie Melua a sonnet as she opens her Beetle bonnet
Image result for katie melua
But I'd rather get this bike and ride on it
https://www.ebay.co.uk/itm/Suzuki-GT380-A/323924706143?hash=item4b6b6ac35f:g:dHsAAOSw7ntdgjlW
and I'd love to show Meg my big middle leg
Image result for meg ryan
But I'd rather lick this Rover's pos/neg
https://www.ebay.co.uk/itm/Rover-sd1-v8-3500-auto-efi-moonraker-blue-long-mot-see-listing/383162711607?hash=item593646fe37:g:9GwAAOSwJpxdg9wt
But as much as I'd hate to drain Susan Boyle's sump
Image result for susan boyle
I'd rather do that than drive this steaming lump
https://www.ebay.co.uk/itm/Iveco-Daily-XLWB-Camper/163880258716?hash=item2628064c9c:g:SooAAOSwwO9digTg
Tell me about your mother....
4 hours ago, strangeangel said:
I actually quite like that, apart from that front nearside door. What the hell is going on there? Even more mysterious is that the ad makes absolutely zero mention of it either.
10 minutes ago, Brodders said:
Soft focus being used in an attempt to add sex appeal to a diesel Passat estate.
https://www.ebay.co.uk/itm/VW-Passat-Estate-Z1-1-9-TDI/123921748366?hash=item1cda4fd18e:g:8KcAAOSw7fBdj38~
"mine for 9 years, never let me down"
Well maybe apart from the 3 months it took him/her to get it mot'd after getting this failure sheet
  • Nearside Front Suspension component mounting prescribed area excessively corroded significantly reducing structural strength inner sill to floor (5.3.6 (a) (i))
  • Offside Front Suspension component mounting prescribed area excessively corroded significantly reducing structural strength inner sill to floor (5.3.6 (a) (i))
  • Offside Front Sub-frame corroded and seriously weakened (5.3.3 (b) (i))
  • Nearside Front Sub-frame corroded and seriously weakened (5.3.3 (b) (i))
  • Spare tyre defective ()
  • Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive jack mount (5.3.6 (a) (i))
  • Offside Rear Suspension component mounting prescribed area is corroded but not considered excessive jack mount (5.3.6 (a) (i))
  • Exhaust has a minor leak of exhaust gases (6.1.2 (a))
  • Front Registration plate deteriorated but not likely to be misread (0.1 (b))
  • Rear Registration plate deteriorated but not likely to be misread (0.1 (b))      I'M OOT
Black cabs used to all be like that, the nearside front was an open luggage rack; it was only the FX4 that started the fad for having a new-fangled door instead.
