https://www.ebay.co.uk/itm/austin-1300-classic-ratrod-special/183087869470?hash=item2aa0e32e1e:g:z1MAAOSwkrFajZDB
Deep breath.......
HERE WE HAVE A VERY SOLID 4 DOOR AUSTIN 1300 GOT FOR MY DAD HE HAS A NEW VW NOW SO THIS IS NOT NEEDED  ITS A CAR  WITH A TWIST IT HAS A TRANSIT TIPPER PUMP IN THE BOOT TO ALLOW THE CAR TO BE LOWERED OR HIGHERED USING  THE CARS HYDROLASTIC SYSTEM .YEP ITS TRUE .THERE ARE TWO SWITCHES IN THE CAR .FOR THIS PURPOSE . THE CAR HAS BEEN BLOWN OVER IN SATIN BLACK BUT BEEN DONE WELL ALL THE CHROME IS IN QUITE GOOD CONDITION THE TYRES ARE ALL GOOD THE INSIDE OF THE CAR IS AS IT LEFT THE FACTORY AND VERY PRESENTABLE THERE ARE NO CARPETS IN THE CAR AS WATER IS FINDING ITS WAY IN AND DIDNT WANT THE CARPETS  TO HOLD WATER EVERY THING WORKS AS IT SHOULD AND IT IS MOTED TILL SEPTEMBER .THE GUY I BOUGHT THIS OFF WAS A CLEVER MAN THERE ARE LOADS OF BILLS AND ALMOST EVERY MOT HUNDREDS SPENT LOOK HOW CLEAN THE ENGINE BAY IS ITS  GOOD ENTRY LEVEL CLASSIC OR RAT ROD NEEDS TO BE SEEN GOOD DRIVER AND FREE TAX AND WILL BE MOT EXEMPT IN MAY GOOD RUNNER AND DRIVER WOULD TAKE A CHEAP MINI OR VESPA OR  LAMBRETTA IN PART EX GOT ANOTHER PROJECT SO THIS HAS TO GO ANY QUESTIONS THRU EBAY  OR YOU COULD USE THE ENGINE IN YOUR MINI AND SELL THE SHELL
Aaaaand...breathe.
https://www.ebay.co.uk/itm/Ferrari-250-gto-Datsun-240z-matching-numbers-and-original-right-hand-drive/332582827044?hash=item4d6f7b3424:g:hmUAAOSwXJFapUqW
Ferrari 250 gto
Major projects RARE ferrari 250 gto or RARE Datsun 240z original right hand drive with matching numbers.
I have a full size ferrari body and instructions to build it, this is at a separate cost  my tel 07970246331
So what would I be buying? I am genuinely confuzzled whats for sale here. Is it the 240 without the body or is there another body or are you charging more for the instructions?
Thought this looked alright.
Advisory notice item(s)
  • Rear Brakes imbalanced requirements only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.5b)
  • rear parking (secondary) brake imbalance requirements only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.6b)
  • Steering system has slight free play detected at steering wheel (2.2.A.1b)
  • Nearside Front Sub-frame corroded but not seriously weakened (2.4.G.1)
  • exhaust system deteriorating
  • Nearside Non obligatory mirror damaged slightly lose ()
  • Nearside Rear fog lamp has a product on the light source but not adversely affecting light output (1.3.2d)
  • Oil leak ()
  • Brake pipe slightly corroded front to rear in engine bay (3.6.B.2c)
  • Rear Brake pipe slightly corroded both (3.6.B.2c)
  • Rear Shock absorber has a light misting of oil both (2.7.3)
  • Front Inner brake disc worn, pitted or scored, but not seriously weakened faces (3.5.1i)
  • Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
  • Nearside Front Lower Suspension arm rubber bush deteriorated but not resulting in excessive movement rear (2.4.G.2)
  • Offside Front Lower Suspension arm rubber bush deteriorated but not resulting in excessive movement rear (2.4.G.2)
  • Inner sill's & rear chassis corroded
Never mind.
This is the only picture but much cheapness, albeit very non-AS pricewise.
The vendor is using a jpeg to get round ebay's rules about listings, the salient points are;
*not completely fucked
*£4,900
On the granny...
am not 100% about selling this
https://www.ebay.co.uk/itm/trike/222888793955?hash=item33e5351763:g:i6QAAOSw6Mxarqd5
These trike 'builders' never cease to amaze me. is there some sort of 'dark internet' guide to knocking these things up from bits of shit out of a 1970's office that was firebombed?
