Cheap Pride. There's a catch though.
Kia pride for spares or repair, failed its MOT on a couple of small patches of welding.
Doesn't sound too bad me old china. Let's check it with Bully...
  • Reason(s) for failure
    Nearside Outer Body or chassis has an unsatisfactory modification, seriously affecting its strength within 30cm of the body mountings sill (6.1.B.2)
    Offside Rear Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings subframe (6.1.B.2)
    Offside Rear Body or chassis is damaged, seriously affecting its strength within 30cm of the body mountings wheel arch (6.1.B.2)
    Offside Rear Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings wheel arch (6.1.B.2)
    Offside Front Inner Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings sill (6.1.B.2)
  • Advisory notice item(s)
    corrosion on under side of vehicle
    oil leak
    suspension bushes deteiorated
    all cv boots perished
    brake pipe slightly corroded
    brake hoses perished and ferrules corroded
Hmmmm I'll give it a miss.
http://www.ebay.co.uk/itm/Kia-pride-spares-or-repair-/263059155775?hash=item3d3f8c2b3f:g:pxsAAOSwPWRZUgd7
bASe spec Metro with the weird metal rear bumper for £100
https://www.gumtree.com/p/rover/rover-metro-1.1-low-mileage-needs-to-go-tomorrow-/1249555695
Yup thats the 1.1C
No rear shelf, no clock, no JESUS handles, no wheel trims (centre caps only), no Central locking, keep fit windows, two speed heater fan, painted metal at the tops of the doors & A pillars, rear bumper that shows the valence rather than hiding it (which shows the number plate recess on the Mk2 "A series" shell pressings), blanking plate in bumper rather than second fog lamp (colour coded though to make it look like a fog) no rear wash wipe ( dealer edition Advantage 1.1C gained Rear WW & clock), no PAS either. Should be carb rather than single point injection.
Xedos 6 no MoT - needs welding £175 Loogabrooga
Bully says:
    Offside Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Nearside Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Nearside Front constant velocity joint gaiter deteriorated to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
    Service brake: efficiency below requirements (3.7.B.7)
    Parking brake: efficiency below requirements (3.7.B.7)
Meh...
https://www.gumtree.com/p/mazda/mazda-xedos-6-2.0-v6-se-manual-red-1999-77k-spares-or-repair-mot-failure../1251483273
Lo-mileage ticketless Rover Metro in Tomarton, just £100
MOT history of this vehicle
  • Test date6 May 2016
  • Expiry date4 June 2017
  • Test ResultPass
  • Odometer reading64,983 miles
  • MOT test number4454 7557 1628
    Radius arm has slight play in a pin/bush (2.4.G.2)
    Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
    Brake pipe slightly corroded (3.6.B.2c)
    Front constant velocity joint gaiter deteriorated, but preventing the ingress of dirt (2.5.C.1a)
    surface corrosion all inner and outer sills and steering and susp mounts
https://www.gumtree.com/p/rover/rover-metro-/1251463421
One for the late registration madness thread... WBAC as chucking this 2008 pre-facelift R75 through BCA Enfield tomorrow. Diesel Auto with just 45k.
VERY WANT
It's not in Windsor though, nearest Lidl( as in photo) is Maidenhead. Happy to test drive for an interested party!
With the 8.32 make sure that the spoiler comes up out of the boot lid, it's the only* reason to buy one
Might look shiny on top, but underneath that Dedra is seriously fucked, and for the condition, the price is stupidly salty, not been on the road for a long time either
£250 with MOT until December.
http://www.carandclassic.co.uk/car/C865292
This drives past my house on an almost daily basis, gifferish owner who does look after it well, seems to warm it up etc, deffo never been nailed in anyway!!!
It WILL require a fair bit of suspension work though at some point as the road he lives on is unmade.
Seems a fair price in all honesty.
