just bung some Bulgarian plates on it and nobody will be any the wiser. Inappropriate alloys just go to make it more convincing as a car hailing from east of Ipswich.
Maybe i should buy it then!
I wondered about that too
The stuff you do post on here does have a certain "warts and all" quality about them...! ;-)
All cars should be sold like that polo with a running commentary through the picture.
This the stain from when I shat myself coming back from my uncle pats wedding have eating 17 coconut creams. A good wet n dry should see it out.
Cheap 530d Sport manual
Needs a couple of things for MOT
  • Brake fluid warning lamp illuminated (3.6.G.2)
    nearside Brake pipe excessively corroded front to rear and leaking (3.6.B.2c)
    offside Brake pipe excessively corroded front to rear , and leaking (3.6.B.2c)
    Electronic stability system warning lamp indicates a fault (3.4.1c)
    Supplementary Restraint System warning lamp indicates a fault (5.4.2)
    nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
    offside Headlamp aim beam image obviously incorrect (1.8.A.1b)
    Fuel pipe leaking both front to rear (7.2.3)
    front Exhaust has a major leak of exhaust gases flexi (7.1.2)
    offside rear coil spring broken (2.4.C.1a)
    nearside rear coil spring broken (2.4.C.1a)
    offside rear Anti-roll bar attachment bracket/mounting fractured (2.4.G.1)
    offside rear Anti-roll bar linkage ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
    nearside rear Anti-roll bar linkage ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
    nearside front Anti-roll bar linkage has excessive play in a ball joint (2.4.G.2)
    nearside rear Wheel bolt(s) missing (4.2.A.1e)
    nearside rear lower Suspension arm has excessive play in a pin/bush at wheel side (2.4.G.2)
    nearside front Tyre has ply or cords exposed (4.1.D.1b)
    offside rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
    offside front brake disc in such a condition that it is seriously weakened broken (3.5.1i)
    offside front Headlamp levelling device obviously defective insecure switch at arm (1.7.2)
    Service brake: efficiency below requirements (3.7.B.7)
    Parking brake lever has no reserve travel (3.1.6b)
  • Advisory notice item(s)
    offside front Anti-roll bar linkage ball joint dust cover damaged, but preventing the ingress of dirt (2.4.G.2)
    offside rear drive shaft cv boot split
    rear brake disc worn, pitted or scored, but not seriously weakened both (3.5.1i)
    nearside front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
    nearside front lower Suspension arm has slight play in a ball joint rear most (2.4.G.2)
    offside front lower Suspension arm has slight play in a ball joint forward most (2.4.G.2)
http://www.ebay.co.uk/itm/bmw-530d-/322404078239?hash=item4b10c7d29f:g:dE8AAOSwZQRYg5iV
I think the MGA is a lovely looking car. Here's what one looks like that's had the e-merican hot rod treatment. AWfUL.
http://www.ebay.co.uk/itm/1957-Red-MG-MGA-AC-Cobra-Custom-Convertible-4-3-V6-Chevrolet-240bhp-LHD-/272535847886?hash=item3f746703ce:g:gD8AAOSwLF1X3tP3
They go to all that trouble to make it look utterly appalling then they don't even put a proper engine in it?
Dingle-brained fuckwits!
"Yes, let's put one of those really popular and well-loved for engine swaps Chevrolet V engines in it. Now what number was that? V... V... six? Yes, V-six. That's it!" The mind boggles.
Parts section OMGFIELDFIND 305 dizzler.  Not particularly cheap given how fucked it probably is, but saloons must be getting rare now.  Seller's other items are worth a look too.
This looks a bit happening until you find out that it has an MGB engine and gearbox."
Cavilling over minute details like this is most undignified. Its got two gear levers and you're still not happy.post-7547-0-40132600-1485526133_thumb.jpg
Rong engine and culler but ebay trigger finger is twitching. Shame about reserve not met as I suspect it is way out of my price range for a Toy! :D
Reckon that could be battleship grey'd and fitted with a triumph straight 6 without too many issues though
Bet that the seller was well chuffed with his JDHT certificate investment
And again, put a Triumph engine in and you'll completely ruin it. Battleship grey with a roller would make it an absolute spunker though.
