Ten months MOT, 39 service bills, two owners and under £450!
http://www.ebay.co.uk/itm/191690162190
same as Fiat panda
it must go to a good home and regular updateds and pictures of the car are a must if you don't agree to these T&C's i will not sell you the car a bit little getting a puppy from a animal rescue centre.
It's a Marbella, parts bin special. Nobody loves this mongrel.
Wrong!  A Marbella is high on my must-have list, however that one can pass, I've seldom seen such a dreadful choice of interior textiles.  I didn't know they did a Jeans special edition but I wish they hadn't.
Except all they've actually done is whack some old tags and plates on a much newer and totally different model.
Except I think they have done it the difficult way and dropped newer running gear into old chassis and then new body on top. or, ground out the original chassis number and stamped on an older one hmmm
I'm out
Always thought the Marbella looked better than the Panda and wanted to make a 4x4 one. Had a '94 Terra van for work (technically my first new car) with the little diesel VW engine, went like stink. Hilariously basic inside but they did put a radio in at least.
A spotless, low mileage black Marbella lurking in an ex-Rover dealer's back yard was meant to be my first car, however the seller took so long to sort out its leaky fuel tank that I ended up with the world's most abused Citroen AX instead.  I absolutely loved the basic interior and how it was, in 2002, probably one of the least fashionable and stylish cars available.  Basically a rough, not-as-well-made copy of a basic, utilitarian car that hardly anyone has heard of outside of the Spanish rental car market - what's not to like?
There seems to be a small, odd following for them now in shoving bike engines in them.  I can see the reasoning, I think, but it really should have a wheezy. asthmatic engine of less than 1000cc and white steel wheels.  Trouble is, prices are going up, that one's pretty cheap but I cannot see past the nasty interior trim.
Same engine as the MK2 Polo got in continental Europe, never found it's way into any RHD models though.
That Range Rover, maybe i'm insane. But aren't those the ones where the body is bolted to the chassis with about 6 bolts?
Meaning a body swap takes about 12 minutes?
Or have I been on the absinthe again?
‘CHUNDERBIRD’ MORE LIKE! LOLOLOLOLOLOLOL
Was it made a Cat B on its looks alone?
I have a picture of this car with a blonde lady sprawled naked on the bonnet on the bonnet
Share it with us. Please!
It looks like someone was so distracted by its immense hideousness that they drove into the back of it.
I think the impact damage if anything has improved the styling . At least it's got a v8.
Mk1 Cav 2L. Comes with standard wheels as well.
Ah, lets fit low profiles, without changing the wheel size. #Circumference_fail
