Six Cylinders Motoring Notes - ADO16 gang out and about!
20 hours ago, strangeangel said:
Be careful... as someone who has sampled Mrs 6C's cider, it goes down easy but sneaks up on you like an assailant with a sock full of pool balls 🤣
Seasoned strong cider drinker who knows when to stop. Normally the third pint for me.
Some of my 2018 vintage might need to be drunk in smaller quantities... I had six gallons turn out at 9.8%, six at 9.9% and one very special gallon pressed on Christmas Eve turned out at 10.6%...
I have just bottled 6 gallons of a single variety batch made with Yarlington Mill apples, which was pressed on 01-Jan-20. It turned out at 5%, with a pleasant hint of sweetness and a dry oak finish. I'm rather pleased with it. It would make for a pleasant three pints, I think.
  • Like 7
Hmm.  Something tells me I might be sleeping in the back of the Iveco at the next FOD meet...
I’m used to 3 pints of between 8 & 10% cider and waking up fine Claire, I can’t see it being too taxing!
Then again, if I’m thirsty and sunburnt akin to after working on the white Gamma, it may kill me!
DVLA computer broken Again!
Not for the first time I have SORNed a car only to find a week or two later I get a threatening letter to say if I don’t SORN my car I will be fined £1000.
This time it was the Toledo that I SORNed the day I got the new V5C, 19th Dec. Screen said it was Successful and I received an email conformation. Today, dated the 26 December I got a threatening letter to say I needed to SORN my car and on using the on line checker found the Toledo comes up as untaxed since 1987. I have now SORNed it again so we will see what happens.
In a past case with email conformation when they did issue a fine, I was told it was my still my fault because I had not reported that I had not received a SORN letter in the post within 2 weeks. They did cancel the fine, but if DVLA get it wrong getting a letter to say I had not monitored there work is just offensive and I should fine them.
The Toledo case is particularly galling as I often forget to SORN a new car because you can’t do it until you get the new V5C by which time I have filed the paperwork. I would like to be able to apply for SORN at the change of ownership.
  • Sad 1
it should be safe to ignore that, but you can call the DVLA up and get them to stop the letters if they continue to bug you
due to the way the whole DVLA computer works, vehicles untaxed since before 1998, physically cannot be SORNed and the official DVLA response to that is it is safe to just leave them untaxed until you are ready to tax it again
(and you can call them up to stop the nasty letters if they continue)
(alternatively if its a vehicle a Null Rate Taxation class you can tax and just SORN right away as @egg did with the Invacar Mk12)
BTW you might want to blank the V5c reference number in the letter too!
Never ignore a DVLA letter the process is automatic and a fine will follow.
I thought change of ownership null and voided the pre 1998 no need for SORN rule?
To turn it to Historic tax I would need to insure it and I am not ready to do that yet.
Good call to loose the doc number.
This happened to me with Bob the Renault 6. I tried twice to SORN it online and got two email confirmations, followed by two threatening letters. I emailed DVLA and they told me the reason was that it had not been taxed since SORN was introduced and therefore could not be SORNed. Since then I had no further letters from them and did not receive any automatic fine, then I sold it (well, gave it away) and did an online change of ownership, at which point it still showed as untaxed. Hopefully, although the letters are obviously automatically generated, they do actually check before issuing any fines. I thought that a change of ownership voided this SORN anomaly, but apparently not. It is very annoying though. Their online system obviously knows when it was last taxed so why the hell can't they just tell you this when you apply for SORN, instead of confirming it by email then ignoring it completely and sending out threats? Bloody DVLA.
Change of owner means new owner must sorn or tax the car. Whatever previous owner did is not transferred to new owner.
no the keeper change does not change that
see for example KPL139P, that was untaxed since 1991, all through Zels and Olie's keepership, with no broken knee caps! (only getting taxed when Adam bought her)
it seems to be a bit random if you do or or do not get nasty letters (I dont THINK @Zelandeth or @OliD-E got any with KPL but I know @Slowsilver did with Bob the Renault)
like I said you can contact the DVLA and someone will put the stop to the letters :)  (as @Slowsilver had to do this Bob the Renault)
keep in mind the DVLA computer system goes back to 1974! and in a lot of regards/places its technically the same system, its just has had a bunch of extra bits glued onto it over time and as such carries with it a whole bunch of legacy stuff as well
which has been very fascinating to research, an amusing one I saw is when Fraser V888'ed  about some info on his Model 70 which was/is on SORN, and along with the info he asked for the V888 said his tax would expire on the 31st of the 12th 2049! LOL, I assume that is when continuous SORN expires, as I assume the system needs an end date because it was not coded to handle something never ending as continuous  SORN did not exist in 1974!
this is true for vehicles untaxed or SORN since after 1998, but a vehicle untaxed since before 1998, simply cannot be SORNed due to how the computer system works, so for those cases it is ok to leave the vehicle untaxed
(as they basically fall under the old Pre 1998 and 2014 taxation rules)
(although as @Slowsilver siad they really need to do something about the nasty letters!)
keep in mind the DVLA computer system goes back to 1974! and is still technically the same system, its just has had a bunch of extra bits glued onto it over time and as such carries with it a whole bunch of legacy things
which has been very fascinating to research, an amusing one I saw is when Fraser V888'ed for his Model 70 on SORN, the V888 said his tax would expire on the 31st of the 12th 2049! LOL, I assume that is when continuous SORN expires, as I assume the system needs an end date because it was not coded to handle something never ending as continuous  SORN did not exist in 1974!)
as they fall under the old Pre 1998 and 2014 taxation rules
I sorned the Daf, it had not been taxed since 1980s
thats curious as I know several people who have tried to SORN pre 1998 vehicles to no availe and even the DVLA themselves said it cant be done
so It would be interesting to see if we can figure out how you managed it! :)
do you have any more details on when exactly she was untaxed when you got her?
im wondering if she was in the "NOT LICENSED" vehicle taxation class, so would have been showing as not taxed for on road use on the DVLA checker, but would be why you where able to SORN here then as due to how the system works she would have been taxed according to the system so you could make a SORN, sine as far as the system was concerned she would have been taxed for the past 45 years
via some internet sleuthing this is your DAF right? she indeed comes up as SORN
but most curious has an import/Used on Date of first registration marker and it shows you as the only keeper?
Unless she came to you on a Buff logbook? making you the first V5 keeper?
I have now sent an email to the DVLA asking them to confirm I am not going to be fined.
Yes thats mine! I got a V5 with it, but changed it from PLG to Historic Vehicle when I got it in late 2018, hence date of latest logbook, June 2019. They took their time, as usual.  Is that the reason I easily got sorn on line?
"but most curious has an import/Used on Date of first registration marker and it shows you as the only keeper?"   @LightBulbFun Where is this extra info?
I had the same as Six Cylinder and LBF explained with the VP1300 last year in 2019.  Off road since the mid 90s, I 'sorned' then recieved the threatening letter.  Phoned and they said it couldn't be sorned, and I didn't hear anything more.  Sold to a friend and lo and behold, the same happened to them.  Again a phone call stopped any further action.  Presumably whoever's on the other end of the phone can put a marker against it to stop the letter/fine process continuing, but it's a bit rubbish that they can't sort the system out to work correctly.
ah that explains it :) , to change taxation classes you have to tax the vehicle, so when you changed it to Historic Vehicle you must have taxed it and then since its tax was brought up to date obviously you where able to SORN it
(again due to how the system works, you cant change the taxation class of a vehicle without taxing it)
The no previous keepers and Used on Date of first registration marker is showing in my Special tool and on the useful https://www.carbaba.co.uk/  website (stick your reg in and a random milage, hit value my car and it will spit out a bunch of info :) )
does the V5c say anything in the special notes section? if it does not say "Used on date of first registration" or something like then its probably just a fluke for some reason
how many previous keepers does it has, do you recall what it said on the old V5? again might be a fluke, where no 3rd party tools have recorded you as a keeper, I have seen this happen a couple times but its rare
(since you got a previous V5 then there where obviously at least 1 previous and now 2 total keepers!)
Last time it was taxed before I got it was October 1980. This V5 only has basic details, the rest blank.
must be a fluke/error with the 3rd party tools then!
when you say this V5 do you mean your current one, or the old V5? (do you still have the old V5?)
on a separate note
being a 1973 vehicle, it will have been on a buff logbook during the first couple of years in its life, so im curious if any of the V5's says "no keepers: since *date* "
since Keeper counts normally did not transfer over from a vehicles Buff logbook to its V5, the DVLC put "number of keepers since" and then a date usually from when that vehicle was V5'ed, to say that the keeper count only goes back to that date (as such this date can also be handy for figuring out when your vehicle was computerised :) )
but I am still trying to figure out if modern V5's still make that distinction on ex buff logbook vehicles or not or if they dropped it, Iv seen a 2012~ V5 with it but nothing later so far
The V5 for the 1966 Morris 1100 I bought last year just says 'Number of former keepers 5' rather than since a date, as do the both the red (issued 2012) and previous blue V5s I have for the 1973 Austin 1100 and 1972 Austin 1800 owned since 2005/06.
It seems to be a bit hit and miss.  I've had several old cars which have had the "true" total number of keepers on the V5C, and several which have shown the "since computerisation" number.  May depend on which DVLA local office was originally involved?
Shame we still can't pay a small admin fee and get a photo copy of everything they have for a car.
yeah I have noticed that not all old ex Buff logbook vehicles have it
what I have yet to figure out is on those old vehicles which dont have the "since computerisation" date, is if on those vehicles the full keeper count from the vehicles buff logbook was carried over to the V5, hence no need for the date
or if they whoever was V5ing the vehicle at the local DVLC VRO just neglected to include the "since computerisation" flag when entering the vehicles details into the computer
I guess the only way to know in that regard is if someone has such a vehicle and still somehow has its old buff logbook as well so they can compare how many keepers its had on the buff logbook with what it says on the V5!
Yeah! one thing I was surprised to learn on that front is that the DVLA did keep copies of vehicles old buff logbooks
I know of a couple of people who back when you could say "gimme a photocopy of all the V5s and info you have on this vehicle"
did so, and even got copies of said vehicles buff logbook! I really was not expecting that!
from speaking with someone who has done a lot of these, apparently with the correct wording you CAN still get copies of old V5's etc from the DVLA but they will have (previous) keeper info blanked out (although apparently sometimes they are not very good at doing so, so you get the odd one with details still visible)
im tempted to put this to the test with REV, but im fortunate with REV that I already know her full keeper history and who all the keepers where and I have a good number of her previous V5's (or copies of previous V5's) already
so there would be little point in doing so, and if it only works once I dont want it to be wasted on a vehicle which I already know the history of!
GDPR m8...
3 minutes ago, chaseracer said:
GDPR m8...
I know and I should be glad they don't give out my address  to every well down the bell curve car fanatic, but somehow it is nice to have the list of past owners for your car.
on a separate note
Dont have the old V5 I got with it, the Post Office man took it to send to DVLA when I went to get it changed to Historic Vehicle from PLG before taxing it. Otherwise according to the Post Office man, as it was still PLG, I would have had to pay 6 months (or a years) road tax. Our PO is one that normally does road tax, I have used them before, so I think he knows what he is talking about.
"This V5" is the current one, I got it in June 2019, and it was then taxed.   It says: Former keepers;2 ; Was registered and/or used; Declared manufactured 1973.
Its sorn now because there is so much wrong with it because previous owner fucked just about everything, whenever I look at it, I find more shit. I am not sure what to do with it.
 Dont know why, when I put a single post up, it ALWAYS puts 2 up if there is a quote, or attachment, so I have to go in and delete the second one.  🤬
ah thats what i was talking about in the special section, explains the Import/used on date of first registration marker
curious that it has one and the Declared manufactured 1973 bit is interesting as well, have to wonder if its year of manufacture was incorrectly recorded on the DVLA at some point and someone corrected it, but that should only get you a Declared Manufactured 1973 special note, so still leaves me to wonder where the Used on date of first registration marker came from then
its nothing to worry about really, just something I find curious thats all :) (as normally you only find these markers on either imports, or other such used vehicles being registered anew with the DVLA like Ex Military basically anything registered with the DVLA via a V55/5)
If the DVLA can make a mistake as basic as this then it amazing  anything gets sorted.
im not sure if its the same issue your having but I have noticed a similar a bug with the forum, where if im typing a response to a post thats on a previous page and im also on that previous page, I notice when I hit submit reply, the forum will post the response forward to the current page but it wont actually visually do anything, so you think you miss clicked the button etc so hit submit reply again, thinking you missed clicked only for it to post it a 2nd or 3rd time etc
