Autoshite Dealership Sticker
Here is my attempt;
WIN 8)
They're all good but that one really tickles my juices.
The one above is best overall design in my humble opinion. I love the others but they're too specific to one particular marque. I would also offer the choice of a window cling sticker, so that true skinflints can transfer them between shite.
+1
Oh, and I'd like about 10.
It's also the only two colour one so it should be the cheapest to produce.
+1
I'l like a couple of these, In cling-on format if possible...
The BL one would look utterly at home on my 800....
1000* please.
*1.
1000* please.
*1.
Surely an 800 should have a sticker from a dealership who are still trying to use up their stock from two identities ago:
1000* please.
*1.
SUPERB M8!
I was the one who made the Autoshite stickers and Minimad distributed them, If you can provide me with a pdf of your sticker I will make some up for you guys, I gave away approx 200 Autoshite stickers with free postage but obviously I can't repeat this too often, may work out to a small fee each one, I will see what the response is (God elp me) and then put some out.
Please note these do fade after approx 1 years exposure and when they are removed you will need some white spirit to remove a slight residue left on edges of sticker. I WON'T BE SUED FOR REMOVAL OF SAID ITEM :lol:
No Promises, lets see wheat happens
They fade over time? That's awesome. Hopefully they fade to unsightly combinations of almost brown and nearly blue. I can't decide which one to get, there's too many to choose from!
I don't think anyone would expect you to fork out for stickers then give them away for nowt and the last ones were brilliant.
Why you are too kind sir!!!!!!!!!!!!!!!
Right now the problem I have is I can only produce stikers on white vinyl which stick on the outside of the car, I can print on clear vinyl (reverse print) which you can stick on the inside of the car and read the right way around but I can't put a white background on to make the text stand out. I will try an experiment on Monday where I will print on clear vinyl and stick a white vinyl over the top, hopefully there won't be any air bubbles but it will make the sticker quite thick but if stuck on the rear window it won't matter and the colours will be steadfast. If i get bubbles I will try sticking them through a warm laminater to try and iron them out so to speak.
Window stickers are screen printed which is quite expensive to start but when you have so many 1000's printed become cheaper, Mine are just for fun and as you can see I have at least 1 satisfied customer, in fact I still have a few Autoshite stickers in the car door which I keep meaning to leave under unsuspecting window wipers.
I'll try and get a few quotes, usually there is a minimum order for a few hundred though, I'm not going to end up stuck with the fuckers am I?
I'm sure we can ensure that doesn't happen.
As he says above '|' I'd be happy to pay "up front" if that would help. Obtain some quotes & PM me when you can.
Right well the first quote in...
A minimum run of 250 stickers, being the internal self cling type in 250x50mm format.
Once postage is added, they would go out at around £1.50 each, the main issue for me being the initial outlay required, perhaps we could have a list of names and quantities wanted to see if this is a flyer or not?
If I get any other quotes back, I'll update this post.
Well we could run a list perhaps, just quote and add your name and the number of stickers you'd like!
rml245 - 5
rml245 - 5
volksangyl - 4
I've been getting quotes so far on the two colour one:
I'm not sure who made the multi branded one, but I could always have a go at bringing that down to a 2 colour one too, it'd bring it out at a similar price.
In that case
rml245 - 5
volksangyl - 4
Louise2cv - 1
In that case
rml245 - 5
volksangyl - 4
Louise2cv - 1
109landys3 - 4
In that case
rml245 - 5
volksangyl - 4
Louise2cv - 1
Add: Andrew353w-5
