Shite in Miniature II
15 hours ago, danthecapriman said:
All stuff you can do without!😄
7 hours ago, bunglebus said:
And two different colour luggages on the Fiat 1500s
Pre-Production colour trial pale yellow luggage.
Also red Fiats come with brown...
or orange luggage
New thing coming
About time we had some different 5 packs, Cosworth looks good.
Old things - didn't know these existed
Another of those things I shouldn’t have bought but did anyway!
IXO DAF 2800 low loader.
Lovely model. Big, as to be expected! I just need to find some 1:43 plant equipment for the back of these.
Here's some more from my auction lot from last week.
A small pack of Husky's.
Guy Warrior Milk Tanker.
There are two versions of this. I think this is the earlier version with the rounded tank. The other version has a squarer tank.
S & D Refuse Van
The back still works but there's a lot of rubbed off chrome
Simon Snorkel.
Again lots of wear and the middle joint of the snorkel is loos so it will not stay up on its own.
Two VW Pick Up trucks with conveyors.
One red and one yellow. Both conveyors have gone hard and no longer convey.
Finally a Jeep, a Willys Jeep. This is a slightly larger scale then the rest. It has a missing screen.
and the tow hook has been damaged.
It does have separate tyres and a metal base.
All the others have the more familiar chrome plated plastic base the incorperates the suspension.
S & D Refuse Van
Simon Snorkel.
I do have quite a soft spot for the Husky range.
  • Agree 1
1 minute ago, flat4alfa said:
Least you can burn that....
s-l1600(1).webp.90760d73c2eb274fba401d929a33cda1.webps-l1600(7).webp.99492e73739b83d3dbbee4a2b466412d.webps-l1600(2).webp.f13b57fe07aa5e90207211ffc94bc033.webps-l1600(8).webp.2ffba3efc1dddb188fe369f687255953.webps-l1600.webp.5b7c3eeb55775c21de5397a7007e7ffb.webps-l1600(4).webp.01b8bec37352bffd4f351687e2507ad0.webps-l1600(9).webp.5a284cb61a560a732b386c328d6ab5bf.webp
wait for it
Awesome, I need some.
I couldn't resist the not-a-Transit Midnight Emergency Van
Collect them all!
Four wheel drive! Working headlights! Except...it did nothing at all with the AAs inserted. Hmm. Took the base off, bridged the switch, poked about - nothing. Then while I was pondering what else to try, it burst into life. BEHOLD:
Isnt it just the shonkiest thing ever? It transmits power to the front axle, which in turn powers the rear by a driveshaft. Life expectancy of the plastic gears, about an hour
That was meant to be a gen-3 Econoline, not a Transit
1975-79, as round lights
1975_ford_econoline-club-wagon-chateau_i
Facelift square light with turn signal gained the egg-crate grille
resizer?imageKeys=40538750~SID~I1&width=
30 minutes ago, sierraman said:
Looks like an econoline?
As mentioned here a few weeks ago.
I thought I recognised those wheels
Here is a VW LT effort that was also sprunged into life
It does this quite happily
The mechanism on this one is quieter though, the main racket is a cam flicking the light circuit on and off
The screeching banchee racket on yours will be dry motor bearings.  Pop a spot of light oil into the motor can (each end, not onto the windings)and let it work in.
Just remembered I had that LT effort set up to be a 'Jam Car' as Ideal/TCR would say, on the Scalextric Digital set (when it was set up)
Drilled a small 3mm hole at centre of front axle line and threaded a short piece of plastic rod tight in there, giving it a guide for the track slot
After greasing the polythene worm gears, I then had it driving about doing circuits on its own, while two cars raced about and had to dodge it.  With a Digital set, you can switch lanes you see
Well, it stopped me going to the pub.
All this floor driving has reminded me of the New Bright Honk Kong 1:20 scale W116 Mercedes Benz 450 SE
It looked like this
It had a drive mechanism of chaos
And a mechanical switch to flash the headlights and not only that they lit up the wings as well
And darted about the floor like this
Then it got sold
I suspect the motor was stuck, which is why it didn't work initially. The far East shonk doesn't end there though. Got a smattering of no-names in the post, I think these are Summer but I don't know for sure
Really I was just drawn to the blue pickup, which is suspect is supposed to look like the Matchbox Mini Pick-Up
Confirmed by various other liveries of the same casting coming along for the ride
I already have examples of the Aspen Ski Holidays and "BORD" which is quite amusing. Don't think the others are cribbed from anywhere but I could be wrong
As for the other two, a Testarossa and an RX-7(?), maybe modelled after one of the big name manufacturers products, maybe not.
There were a few others in the box, such as this stunningly accurate representation of a BMW E30 Baur cabrio
Merc SEC - or SEL if the decals are to be believed
2X2 Porsche 959..?
And a 911 that's almost totally devoid of casting lines
Yes, reckon you're right on RX-7
Series one with spoilers and Yankee-loved louvres no less
90143d1105378665-louvre-4-rear-window-re
  • Agree 1
Looks as much like one of those Jeep based light vans they used to do in Spain up until the early 80’s.
I got a couple of boxes today...
This is what was in the smaller box, from @Datsuncog:
...and the big one was from @danthecapriman:
^Before unpacking...
^Mostly unpacked...
^And the contents of the sub-box, a collection of spare parts.  I've smuggled a few of the cars upstairs already.
Would you like to see some completed projects?  We'll start with my newly-installed flatbed, on a Matchbox Leyland Ergomatic chassis; with a previous, more standard resto keeping it company.
These two are both freshly-completed; the Escort representing an actual vehicle I drove a couple of times about 46 years ago.
Mafia staff cars don't have to be black... (the green is the fresh one)
and finally, Simon Templar chases down the ubiquitous ITC white Jag, so often seen going off a cliff!
11 minutes ago, eddyramrod said:
If I did that to the table in my local cafe, she'd throw me out ! 😆
  • Haha 5
Yes it had us pondering a while back too
This is the Carer Support Cafe, open every Friday morning for unpaid-carers to escape their duties for a couple of hours.  The accommodation address I'm having these sent to belongs to one of my fellow carers.  So they don't mind me unboxing all these old toys.  They tend to be quite amused!
Pilen did a 1/50th of the Mercedes MB100
pilen_143_mercedes_van_kereta_hiasan_154
^Mostly unpacked...
2 x Cav’s ?
