SiC Posted November 14, 2020 Posted November 14, 2020 What condition is the displacers in? Engine still may be worth something even full of water. I'd rip it out and bung it on eBay. Heads and the like can be re-machined. A-series lumps are getting rare now.
strangeangel Posted November 14, 2020 Posted November 14, 2020 1 hour ago, Mr_Bo11ox said: Holy hell that is banjaxed. What bits are you salvaging off it? The washer bottle and rear light lenses I reckon. HillmanImp 1
dome Posted November 14, 2020 Author Posted November 14, 2020 1 hour ago, SiC said: What condition is the displacers in? Engine still may be worth something even full of water. I'd rip it out and bung it on eBay. Heads and the like can be re-machined. A-series lumps are getting rare now. Rip it out you say? Shouldn't take long VID_20201114_150441190.mp4 No idea re the displacers, what would indicate if they were saveable or not? Dan_ZTT, Lacquer Peel, theshadow and 2 others 2 3
SiC Posted November 14, 2020 Posted November 14, 2020 2 minutes ago, dome said: what would indicate if they were saveable or not? Probably only really find out when you remove them. The canister section is hidden in the subframe. You only see the top rubber bit from up top. Don't worry if the hose/hose crimps are buggered, they're easily changed.
jonathan_dyane Posted November 14, 2020 Posted November 14, 2020 Mind I didn’t know these had a plastic fan.
big_al_granvia Posted November 14, 2020 Posted November 14, 2020 At least you wont have to worry about siezed bolts or screws.. Just use a hammer and chisel around the metal (or rust) and the bits will come off... Dont know if you know cameron Gilmour, he is a a-series specialist might buy bits from you
captain_70s Posted November 14, 2020 Posted November 14, 2020 "good condition for age" sdkrc and jaypee 1 1
brownnova Posted November 15, 2020 Posted November 15, 2020 “I haven’t put it in for an MoT but I’m sure it won’t need much to pass” sdkrc 1
Datsuncog Posted November 15, 2020 Posted November 15, 2020 "Needs TLC * " * trailered, lifted & crushed chaseracer, dome, strangeangel and 5 others 3 5
sdkrc Posted November 15, 2020 Posted November 15, 2020 "Engine light is on but mechanic says it's just a sensor" Vince70, Lacquer Peel, dome and 2 others 1 4
chompy_snake Posted November 15, 2020 Posted November 15, 2020 I see you towed it out of the environment 👍🏻 martc and dome 2
sloth Posted November 16, 2020 Posted November 16, 2020 id save the dash and trim, iirc the seats are a one off for these. gotta love the tide line on it too. dome 1
dome Posted November 16, 2020 Author Posted November 16, 2020 4 hours ago, sloth said: id save the dash and trim, iirc the seats are a one off for these. gotta love the tide line on it too. The wood trim on the body seems to be riveted on to the bodywork so is proving tricky to remove without damaging it. I can see us cutting the panels away around it, but only if they're worth saving Seats have been rescued and look saveable but the back seat is soaking wet.
sierraman Posted November 16, 2020 Posted November 16, 2020 ‘Suit enthusiast but this won’t be on the road after a weekend s DIY’ GingerNuttz and dome 2
Mr_Bo11ox Posted November 16, 2020 Posted November 16, 2020 The displacers will most likely be OK if their outer metal 'cans' are not rotted through. As mentioned the hoses can be changed over easily enough. dome 1
HMC Posted November 16, 2020 Posted November 16, 2020 “Ideal lockdown project” Vince70, dome and GingerNuttz 3
HMC Posted November 16, 2020 Posted November 16, 2020 “An excellent basis as the restorer won’t have to undo any previous work” dome, antony denman and GingerNuttz 3
sierraman Posted November 16, 2020 Posted November 16, 2020 ‘Genuine and unmolested’ Datsuncog, GingerNuttz and Vince70 3
big_al_granvia Posted November 16, 2020 Posted November 16, 2020 less rust than @captain_70s dollyshite prior to restoration Shite Ron and sloth 2
